07-22-2017, 07:25 AM | #57 | |
Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
07-22-2017, 08:32 AM | #58 | |
Drives: 2016 Camaro SS Join Date: Jul 2016
Not sure what the calibration update does to the fan speed or door position. But, after the calibration update the door actuators would have to be relearned so they know the full extent of their travel. Guess we'll have to see what others experience. If the door still isn't fully closing the dealer should inspect and possibly contact technical assistance for further instructions. |
07-22-2017, 08:48 AM | #59 | |
At any rate, if I were the technician I would check that out prior to the company reinstalling the windshield. |
07-22-2017, 09:13 AM | #60 |
Drives: 1LT Join Date: Jun 2017
07-22-2017, 08:55 PM | #61 |
Drives: 2017 ss Join Date: Nov 2016
It sounds almost exactly like brake pads shifting in the calipers when changing directions but I know that's not it. I guess it's more of a loud click when clutching like going through parking lots or taking off from a stop and even letting off the throttle in gear.
07-23-2017, 11:24 PM | #62 |
Drives: 2017 Camaro 2SS Hyper Blue Join Date: Mar 2017
Someone posted this on Facebook the other day... I hate to have this done to my car but just yesterday I was driving in the rain and the fogging was so bad I had to pull over.
07-24-2017, 07:10 AM | #63 |
Drives: 2016 Camaro SS 2SS Join Date: Jun 2017
07-24-2017, 10:32 PM | #64 | |
Hung Like a Republican
Drives: 2016 Garnet 2SS Cpe Join Date: Apr 2009
PROUD OWNER (7-5-16) of a 2016 2SS,Garnet,Kalahari,A8,Sunroof,Mag Ride,NPP,
Nav,Suntek CXP 70% tint,Suntek PPF paint protection **Previous ride: 2006 Spice Red Metallic A4 GTO High end vs low end radar detectors RadarBusters.com GuysOfLidar.com RadarDetector.net Mine: v3.826 V1 (2006) **2016 SS police stealth **2015 BMW M4 vs 2016 SS Camaro MT Head 2 Head **Fav cars: Vettes [C2,C3,C7], SS Camaros [1st Gen,02,6th Gen], M6 BMW, Aston DBS **Coastal_Carolina over @ LS2GTO.com SpiceyGTO over @ CorvetteForum.com |
07-25-2017, 09:27 AM | #65 | |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
07-25-2017, 09:42 AM | #66 |
Still feeling lots of air coming out of defrost vent? I would think technicians would notice prior to returning car to customer but probably not checking.
07-25-2017, 09:47 AM | #67 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Here's what I did, because like many of you I don't trust the dealers to not **** this up.
I ordered this off Amazon: Big @ss mousepad Then I started slowly with a pair of scissors cutting it until it fit perfectly over the dash vent. I thought it would look hideous but to me, it's a cheap easy fix to throw up onto the dash to quell the fogging, and it doesn't look like complete sh*t while doing so. And only $15, and takes about 10 minutes of your time. On the muggiest of days (dew point in the mid 70's) it worked perfectly. I will say at max fan speed it may move around a little bit under spirited acceleration cornering, so you could come up with a way to tack it down but it doesn't bother me to reach up and nudge it back into place.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
07-25-2017, 01:15 PM | #68 | |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
I like this idea. Any pics of it in place? Sent from my iPhone using Tapatalk
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
07-25-2017, 01:42 PM | #69 | |
Drives: 50th 2LT RS Join Date: Aug 2016
Just purchased this. Thanks for the tip! |
07-25-2017, 07:49 PM | #70 |
Drives: 2016 Camaro 2LT/RS A8 Join Date: Nov 2009
Yes, I know exactly the procedure on how the fix will be done. Effectively tomorrow 7-26-2017 I will be taking My 2016 Camaro RS into my local Dealership to have them perform the fix on my Defroster Door.
The 3 page procedure states the Dealership will have an Automobile Windshield Company to come to the Dealership and Remove your Entire Front Windshield! Then the Dealership Technician will remove the Grille from the top of the Dash and then use a Boroscope Wireless Inspection Camera to look into the Defroster Vent and locate the Defroster Door, in which the Technician will use a Clothes Hanger Type Wire Removal Tool to remove the 2 Foam Pads that are secured to the door. Problem being with those Pads installed onto the Defroster Door, it does not close completely and lets the Cold Air push itself up to the Windshield and Cause Severe Condensation onto the Outside of the Windshield. Once the Pads Are Removed from the Defroster Door, then all to do is to Reinstall the Windshield back onto the car. There is No Other Recommended procedure for this fix. Once The Windshield is Removed The Bulletin States the total time of the procedure is 1.5 Hours from start to finish. But we all know how that works, as the Dealership hiring an outside Automobile Windshield Company to Remove it and have them come back to the Dealership later that day to Reinstall the Windshield after the procedure is completed. In closing: Living down here in Florida, it is a Royal Pain to get into my car every day and be faced with this Condensation building up on the Windshield within the first 10 minutes of driving and the only way you can clear it, is to turn on your Windshield Wipers. How inconvenient is that! NOT!!!! I will post back to this posting on my individual results hopefully by Thursday Afternoon.
Regards, wyd_trkr
2016 Camaro 2LT/RS A8 Bose Premium System My Link Navigation Onstar & Bluetooth Built-In K&N Panel Filter Lumar/Pro WindowTint Mailto: wyd_trkr@bellsouth.net |
