Old 04-09-2018, 01:35 PM   #57
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
9” might be a little to big ..
Here’s link to one of them but you may want to look at rolled one ..
https://www.carid.com/flo-pro/304-ss...yABEgLvCfD_BwE
Originally Posted by sav03cobra View Post
Biggest issue I have had is finding those Flo Pro tips, but I found some nice UPower Tips, although 9" in length...same ID/OD as yours though. Think 9" is too long?
cmeJATT is offline   Reply With Quote
Old 05-17-2018, 11:29 AM   #58
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
a little pop action
( swipe 5th post )
https://www.instagram.com/p/Bi3LNcoB...ken-by=cmejatt
Old 05-17-2018, 08:34 PM   #59
sav03cobra
SS Copbait R.I.
Originally Posted by cmeJATT View Post
a little pop action
( swipe 5th post )
Sounds so good!
sav03cobra is offline   Reply With Quote
Old 05-18-2018, 02:10 PM   #60
Spartan268
Spartan268's Avatar
Drives: HB 2SS
a little pop action
( swipe 5th post )
Sounds amazing paji. Going to do a similar build as you, can't wait
Spartan268 is offline   Reply With Quote
Old 05-20-2018, 06:17 AM   #61
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
Thank You veer 🙏🏽🙏🏽 Good luck
Old 05-21-2018, 11:09 AM   #62
SteveFrench
SteveFrench's Avatar
Drives: Summit White 2018 SS
Originally Posted by TJay74 View Post
While I applaud you for being creative, I think without seeing how Flowmaster routes the internals on those mufflers you may be choking down considerably when closing the NPP valves.
Flowmaster uses "V" shaped deflector plates inside of their mufflers in "chambers" in order to quell down the noise, I bet when the NPP closes it is forcing all of the exhaust gas out the other outlet along with the noise. That could cause some pressure issues down the road which could leave to the internal V plates breaking. They are only spot welded into place and it isn't uncommon for the welds on them to break over time.
Can anyone confirm if this is an actual issue? maybe not with the mufflers but even with the car itself if it restricts the flow enough to have back pressure issues?
SteveFrench is offline   Reply With Quote
Old 05-21-2018, 04:30 PM   #63
Spartan268
Spartan268's Avatar
Drives: HB 2SS
Well if the valves open when they need to the pressure shouldn't be built up to something that high of a breaking point. The super 10s are pretty free flowing based on the design so I wouldn't be too worried. Constant use of stealth mode could be a different story but I still have my doubts.
Considering the 'crimp' in the stock system. IMO Back-pressure is not an issue if we're just talking axlebacks. A google didn't show anything news of the welds breaking off either.
Old 05-21-2018, 05:13 PM   #64
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
Had the exhaust setup for 1 year + with over 15k miles..0 issues ( knock on wood) lol ..
Old 05-26-2018, 01:07 AM   #65
SteveFrench
who would run in silent mode with an aftermarket exhaust anyway
Old 05-28-2018, 11:53 AM   #66
BlueCamaro6
BlueCamaro6's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue
Considering I drive my vehicle for work sometimes (vehicle inspections), I try to be quiet when driving through neighborhoods and meeting with people. I do however love the sound of exhaust and the hot rod guys that I deal with don't mind the noise.
I was curious if anyone has run a setup like this, but with the muffler as a single exit and the j pipe as the switched tip? Does this work without any drone? What is the best option for 3" high flow cats? My wife hates the smell of my Firehawk non-catted exhaust, hahaha Thanks for your input
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback)
1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk
BlueCamaro6 is offline   Reply With Quote
Old 06-01-2018, 03:57 PM   #67
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
single exist shouldn't be any issue. also if you leave the stock cats it will not drone.
Old 08-31-2021, 12:31 PM   #68
OniCamaro
Drives: Camaro V6 2017
Can I use the original NPP and AFM valves in a custom setup if I change the pipe diameter of the entire exhaust?
OniCamaro is offline   Reply With Quote
Old 01-18-2022, 03:46 PM   #69
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
You should be able to
