Old 06-16-2017, 03:06 PM   #57
JusticePete
Drives: Camaro Justice
Not a fix IMO. They will come loose again. Nordlock washers and LocTite are a fix.
JusticePete is offline   Reply With Quote
Old 06-16-2017, 03:31 PM   #58
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
in my experience, it didn't come loose after 6 track events. I will check them again
glamcem is offline   Reply With Quote
Old 06-19-2017, 12:17 PM   #59
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
That the M12? or the 1/2?
is stainless steel needed?
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-20-2017, 09:52 AM   #60
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
Originally Posted by Tara Martin View Post
Well, I tighten them as much as I can. I can't squeeze my old torque wrench in there for a reading, though.
It lasted about 5k miles on a drop of Loctite Red...I guess the rattle breaks the Loctite...
All I have to do is find those Nordlock washers, I guess.
I didn't have time to mess with it last Friday, so I took it to a friend's shop. They found that my Locktite job was still holding on the bottom bolt, but the top bolt was the one loose this time. The front-end specialist mechanic went in there and tightened up everything top to bottom.
Thanks HEAVENBOUND11112 for the printout of the TSB. If it loosens up again, I guess I'll go to the dealer...
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 06-20-2017, 10:12 AM   #61
JusticePete
The TSB is not a permanent fix. Nordlock washers and LocTite are the fix.
Old 06-20-2017, 10:57 AM   #62
Tara Martin
Loves Camaros
Old 06-20-2017, 10:16 PM   #63
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Hey Pete,
Old 06-21-2017, 02:01 AM   #64
PinHead
Drives: Duramax
Here's another suggestion. This will immediately show any loosening.
Not a fix, but used more as a safety indicator
http://www.durablesupply.com/dytaprtoma.html
PinHead is offline   Reply With Quote
Old 06-21-2017, 10:41 PM   #65
Greytness
Greytness's Avatar
Drives: 2017 1SS / Daily Driver
I defintely need to check mine. I have heard a few Clunks here and there
Greytness is offline   Reply With Quote
Old 06-29-2017, 03:18 PM   #66
Vyncynt
Drives: 2016 Camaro 2SS (on order)
I noticed my 2016 2SS was making a strange klunking noise when I would make a slow speed left turn after waiting on other cars to go by. It did not sound like higher pitched metal on metal clanking. It was more of a thud, thud, thud sound which went away after I straightened out the steering wheels.
Is that what you guys are hearing?
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC,
Nav, Sunroof, Loaded
"Ahhh! Take care to get what you like or you will be forced to like what you get!"
- Lyrics from a song from Scooter: "Apache Rock the Bottom!"
Previously owned
1998 BMW 540 w/M-series package
1991 Trans Am GTA
1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn)
1985 Firebird (R.I.P.)
1976 Camaro LT
Vyncynt is offline   Reply With Quote
Old 06-29-2017, 05:00 PM   #67
Errro
Errro's Avatar
Drives: 2017 SS 1LE. GM Service Technician
Found this same issue today on a 2016 ATS-V. The customer claimed he had brought the car to a small autocross event and had came to the dealership that I work at complaining of a clunk/clicking noise while cornering and coming out of his driveway. I actually had thought of this thread before I even looked for bulletins so I checked the links and sure enough the bottom nut for the left side link was loose. The problem seems to extend to any GM vehicle that uses the same suspension/sway bar and end link set up.
Errro is offline   Reply With Quote
Old 07-22-2017, 01:29 AM   #68
Vlad
Vlad's Avatar
Drives: 2017 Camaro 1SS
At 5800 miles my SS started to clank at low speed over bumps. Checked endlessly njs and found lower driver side 2 turns loose.
You can reach it without even lifting the car
Vlad is offline   Reply With Quote
Old 07-22-2017, 07:05 AM   #69
JusticePete
Originally Posted by bobby35ny View Post
Hey Pete,
M12 or 1/2" will work. Stainless is a nice touch.
Old 07-23-2017, 01:50 AM   #70
Hipoporay
Drives: 2010 BMW M3 (Sold); 2017 SS 1LE
Same issue after 5000 miles and 2 trackdays. Stopped in a shop around San Rafael CA to diagnose before heading to Sonoma. Left low was not tight. 20 min fix but at the end of the day after 3 more sessions the noise returned. I will have to try JusticePete suggestion. Thanks for sharing!
Hipoporay is offline   Reply With Quote
