Old 04-03-2017, 12:54 PM   #57
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
Really good info dude. Was about to complain about fender gap and then I read you rubbed, yikes.
Are you running this setup on the street too? Never asked.
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 04-03-2017, 01:33 PM   #58
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I am not too worried about the rubbing as it is very very slight and should not be a case if I don't over that specific apex bump or add a bit more camber in the rears.
I drove to the event and don't mind driving around (during the summer) but since Trofeo R tires are expensive at $560 a piece and they require more camber, I will simply change to my OEM/street setup once I get back home.
If I ever put on a more aggressive street tires (PSS, RE71R and or RS3s) or cheaper R comp tires like NT01s or R888Rs, I might use them during the summer as I did previously with my other cars
glamcem is offline   Reply With Quote
Old 04-03-2017, 05:38 PM   #59
cdb95z28
cdb95z28's Avatar
Apex will start manufacturing the ARC-8 wheel in an ET44 19x11 size, which would be perfect for the rear. They are stating a June delivery
"KEEP THE FAITH"-Fbodfather
Old 04-04-2017, 02:54 AM   #60
glamcem
glamcem's Avatar
I think those offsets would be ideal for those who want to stay in 305s in the rear but not sure if it would be ideal for 325s, mine is also not ideal btw I think ideal size for 325s would be something like 33-35 offset. I think it might be easier running 325s with the upcoming Multimatic suspension. I really consider getting that once they release the new ZL1 1LE
Old 04-04-2017, 11:42 AM   #61
cdb95z28
cdb95z28's Avatar
Your car does look fantastic with those Apex wheels and the blue.
Old 04-04-2017, 12:12 PM   #62
glamcem
glamcem's Avatar
thanks
Old 04-09-2017, 11:04 PM   #63
glamcem
glamcem's Avatar
UPDATE: C7 Z06 fender flares received and will be installed soon.
Talked with Schroth Racing and order the missing end piece of my Rallye 3 ASM harness. It should also arrive soon and I will install that as well.
I found the root cause of hesitation issue that I started running into after 2nd track event and wrote this little how-to showing how it can be fixed:
http://www.camaro6.com/forums/showthread.php?t=490819
Old 04-11-2017, 08:04 PM   #64
Centerforce_Clutches
Centerforce_Clutches's Avatar
Drives: Chevy Camaro
Nice mods so far; This build is looking really nice! We're glad to see more people out there hitting the road course in 6th gens!
Centerforce_Clutches is offline   Reply With Quote
Old 04-12-2017, 02:57 AM   #65
glamcem
glamcem's Avatar
Thanks. It's fantastic for track days for sure
Old 04-12-2017, 07:13 PM   #66
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Had my eye on the same jack stands for a while now.
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 04-13-2017, 03:45 PM   #67
glamcem
glamcem's Avatar
they're very good especially if you combined with the ZL1addons lift points..it definitely looks a better built than those traditional types
Old 04-14-2017, 12:24 AM   #68
nate.the.great
Drives: 2017 Camaro 1SS 1LE
Cem, who's your mechanic in the Seattle area?
nate.the.great is offline   Reply With Quote
Old 04-14-2017, 01:01 AM   #69
glamcem
glamcem's Avatar
Doug from Chase Race. He is very knowledgeable and took good care of my cars. He may get busy at times but you may communicate via email and plan accordingly.
http://www.chaserace.com/
Tell him I said hi
Old 04-15-2017, 04:42 PM   #70
Hawk Fan
Hawk Fan's Avatar
Drives: 2017 1SS 1LE Camaro
I finally had a chance to try the new wheels/tires combo at the track. The morning sessions were disaster due to inexperienced flaggers and red flags for every little incident. After the lunch break I could finally do a couple sessions with almost no traffic.
Trofeo R tires felt really good but it took longer to heat them up compared to OEM, RE71R and NT01 tires that I previously had a chance to try in similar conditions (~50 degrees). Once they did reach the temps though, it easily passed the ideal 34-35 psi hot temps and I saw the tire temps reached to 36-37 psi pretty quickly. After adjusting the tire temps (starting with 27 psi front and 26 psi cold temps in the rear) they felt a bit more stable at 34-35 psi after a few laps.
Nice lap! Which track do you prefer? ORP or The Ridge?
Hawk Fan is offline   Reply With Quote
