Old 03-16-2017, 07:57 PM   #57
cdb95z28
cdb95z28's Avatar
Originally Posted by MatthewAMEL View Post
oh, ffs...you win.
I meant the Apex F8X that are being produced in the ~1LE fitment.
https://www.groupbuyparts.com/index....l-q1-2017.html
"KEEP THE FAITH"-Fbodfather
Old 03-16-2017, 08:23 PM   #58
cdb95z28
cdb95z28's Avatar
It appears GM may have taken into account the use of 19" wheels with the 1LE, and/or giving more room for more negative camber
2016 SS
Name:  2016 SS non 1le.jpg
2017 1LE
Old 03-16-2017, 08:40 PM   #59
MatthewAMEL
MatthewAMEL's Avatar
Originally Posted by RUQWIKR View Post
I wish the stock studs front and rear were full thread because you could use a spacer and still have good thread engagement. On stock wheels, looks to be between 14.6 and 15mm of engagement when the lug is torqued.
That's a "normal" amount of engagement with similar materials (steel stud, steel lugs) - M14mm stud and at least 14mm engagement. Depending on wheel mounting flange thickness, you may have more or less than stock engagement.
I marked a lug nut and got right at 10 full rotations to full torque after initial thread engaged fully. I also used a paint marker on a stud and got the same measurement.
If someone has different info on "normal" amount of engagement, post it up.
Hey, have at it. Mechanically speaking any more than one turn is 'fully engaged', right?
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 03-16-2017, 08:41 PM   #60
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
The 10.5" wheel and a 3mm spacer actually are further away
I used a 285 tire on both, just to eliminate the tire variable, since the talk (at this point) is on the wheel to strut clearance
Attachment 858275
Interesting, for some reason my calculations are different
20x10 +20 mm
by going 19x10 +25mm it should move it 5mm closer to the suspension
and 19x10.5 +22mm should move it 2mm + the 6mm (offset difference divided by 2) which would make it 8mm total. And with the 3mm spacer it should offset that difference
glamcem is offline   Reply With Quote
Old 03-16-2017, 08:48 PM   #61
glamcem
glamcem's Avatar
oh, ffs...you win.
Although it's the ideal offset for the stock 305 size, it's not ideal for those who want to go with wider tires in future (like 325s). The ideal offset IMO, would be something like +30-35mm so it would compensate the extra rubber, in my example it will poke out a bit (18mm) but it's manageable with 305 tires. For the 325 however, I will most likely need some sort of fender flare like C7 Z06
If that's the case longer studs in the front might be a good option. I will look into that
Old 03-16-2017, 10:15 PM   #62
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
For some reason your pics on the last page aren't showing up... Weird
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 03-17-2017, 12:30 AM   #63
glamcem
glamcem's Avatar
Thanks for letting me know. I've updated the links so that they should be visible now
Old 03-17-2017, 10:40 AM   #64
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
New wheels arrived!! APEX PS-7 (19x10.5 & 19X11 )
Im happy to help if you need some direction on them. That was my ultimate goal when I installed them but I can't find the right wheel in 19" that I like. I'm glued to this thread and wish you the best of luck Glamcem.
2017 Hyper Blue 1LE
tx6g1le is offline   Reply With Quote
Old 03-17-2017, 01:32 PM   #65
glamcem
glamcem's Avatar
Thanks I think I've seen your post before. I was thinking the same thing before even I got this car then I saw the post and made sure it can be done Ever considered doing the same for the rears? I might try doing that when I am ready to switch to 325s (after the Trofeo Rs)
Old 03-17-2017, 04:27 PM   #66
tx6g1le
tx6g1le's Avatar
I'd like to do the rears but I need to find the right wheel/tire set up. I'm like most of us in this forum hoping to find clarity on the square vs. staggered setup. I'd like to run 305's all the way around (hence the fender ext.) but I know it'll take finesse on the offset. I'm waiting to see if you make it work!
2017 Hyper Blue 1LE
Old 03-17-2017, 06:31 PM   #67
glamcem
glamcem's Avatar
Sure, I will keep you guys updated here on this thread
Old 03-19-2017, 09:14 PM   #68
glamcem
glamcem's Avatar
UPDATE: I had a chance to testfit the wheels after the track alignment (-2.2 camber up front) and it was almost touching with 3mm spacer. I then tried to use the 5mm spacer and it looks like it's going work. The camber bolt portion is not touching but a bit close for my taste so I will have my mechanic grind those areas and if I can get about 2-3mm additional clearance by doing that it will be fine for me I will also use longer studs with Gorilla lug nuts even many people use 5mm spacers without any other modifications.
IMPORTANT: Please use these at your own risk as YMMV
Hard to show in this picture but clearance is very tight it looks like it's touching but it's just the angle of the light:
These are the areas that I am planning to have trimmed/grinned
Old 03-20-2017, 03:14 AM   #69
RideZX6R
RideZX6R's Avatar
Might go about this setup myself... I don't mind a little grind (but no bumps lol)
'12 E93 M3
'25 911 (ordered)
Formers...
Old 03-20-2017, 12:41 PM   #70
glamcem
glamcem's Avatar
cool, I will let you know how it goes. I ordered my longer OEM wheel studs after seeing this thread:
http://www.camaro5.com/forums/showthread.php?t=130651
