09-27-2020, 02:47 AM | #57 |
Long hauler
The light up cup holder I’m pretty sure you’ll have to break to reach the LED chip, I ended up cutting the light tube and attaching my own LED to it. The chip is still sitting in the housing
2016 1LT v6 - Totaled Happiness: Infinite |
10-10-2020, 10:42 AM | #58 |
Drives: 2017 Corvette Grand Sport Join Date: Aug 2009
Not necessary to break the cup holder to remove the led. There is a small clip holding the led chip housing in place, use a small flathead or pick to pry out the clip a bit and pull up at the same time on the led housing. Once out, easily twist and pull the LED away from the light pipe and your done.
11-29-2020, 05:53 AM | #59 |
Drives: 2021 ZL1 Join Date: Nov 2020
Thanks, Hyper! I followed your instructions and now my 1ss 1le has the spectrum lighting both on top the radio and cupholder lamp.
In my quest to change the interior of my 2019 1ss 1le, I have obtained a cupholder lamp with the 24 color spectrum. I am looking to sell it, as I don'tneed it and will not burn a hole in your wallet. If anyone needs this item to complete this post pm me. Good luck and thanks again to all for the awesome job! Last edited by GrayGhost1LE; 01-11-2021 at 01:22 AM. Reason: Quick fix |
12-02-2020, 08:55 PM | #60 |
Drives: 2019 Camaro LT1 Join Date: Jul 2019
Hey guys, can someone please tell me the size of the light tube that is in the radio/info bezel is?
Thanks
Saying THANKS don’t cost a dime so hand it out freely!
12-04-2020, 07:59 AM | #61 |
12-04-2020, 08:10 AM | #62 |
03-09-2021, 01:30 PM | #63 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
This thread is awesome. I want this in my 1ss so bad, I swapped my LT Silverado to a LTZ interior and Denali 8inch digital cluster, this reminds me so much of that.
Since this thread has gotten so long and theres so much info, can anyone make a complete list of all the part numbers, connectors, etc thats required to get ambient lighting in a 1ss doors, radio, and cup holder? Or put together a kit? id gladly buy lol thanks in advance |
03-25-2021, 04:50 PM | #64 |
Drives: 2017 Camaro ZL1 Join Date: Feb 2019
Nice thread, going to add the footwell kit to the zl1. Has anyone found out how to source the LED chips and the plastic holders that connect to the plastic light tube? Would like to get a 6 or 8 sets of leds and some light tube and try adding some other lighting in the interior.
01-19-2022, 05:39 PM | #65 |
Drives: 2017 RS Camaro 2LT Join Date: Dec 2021
I have the 2017 2LT RS package. My light is also white around the screen. My question is what if we had the dealer install a multi LED from the SS would that work or does anything else need to be added to make it change colors?
01-20-2022, 08:12 AM | #66 |
Dyno Show Queen LOL
I never even noticed the light in cup holder.
03-22-2023, 11:46 AM | #67 |
Drives: 23 2SS vert Rapid Blue ordered 6/15 Join Date: Jun 2022
Hey fellow Camaro diyer's. So I have a few questions about swapping out my 1SS display unit for a display unit with the ambient lighting. I have a 2022. After looking around I got 84582510 display unit to replace mine. But it has 2 white and 2 Grey plugs on the back sides where as mine has 4 white plugs. Would swapping out the 2 connectors like he did be the solve or do I need to just do what he did and remove the lighting then run the wiring to the floor well lighting wire? Thanks for all the great info on here.
03-30-2023, 04:08 PM | #68 | |
Drives: 2022 SS 1LE Join Date: Apr 2022
Then you have to get: 2 led lights connectors to connect to the housing already on your 1ss display 3 wires to go from the connectors to the wiring kit you installed and had GM flash then t-taps to splice into that wiring kit you installed I hope this makes sense. |
03-30-2023, 05:28 PM | #69 |
Dyno Show Queen LOL
I have all these for sale.
03-30-2023, 10:00 PM | #70 |
