Old 03-15-2018, 07:08 AM   #57
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Ted, we have exchanged some messages and I love these threads. I appreciate all of the great info you are sharing.
So, upgrading the fuel system with LT4 components and add a cam. Why wouldn’t that also be the time to add drop in pistons/rods? I am shocked that when getting inside the motor more people wouldn’t spend the extra $1000 for drop in pistons. What am I missing?
Since it's my car, I'll explain. Short answer is back when this was done, there was no drop in kit available. It's also not just $1k, drop in kit or not. Some builders won't just literally drop the pistons in, they do a lot more manual work. So when you add up everything, the cost difference wasn't that big between doing that and building a new motor. Also considering how good Ted is at tuning, I rolled the dice and it all worked out. I've got almost 20k miles and all is well. However now that the kit is out, if I were to do it all over again, I would've gone with the kit.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 03-15-2018, 07:12 AM   #58
JANNETTYRACING
JANNETTYRACING's Avatar
You are missing
Labor, R&R, disassembly, machine work, balancing, reassembly, gaskets, bolts, and fluids, break in oils, break in time.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-07-2018, 03:23 PM   #59
Want1
Drives: 2017 Camaro SS 1LE
Originally Posted by JANNETTYRACING View Post
I thought i posted this but I can't seem to find it LOL
2 weeks ago we ran the 80 mm 11.2 PSI pulley E-85 combo and made 726 RWHP 701 RWTQ but fuel pressure was dropping at 6400 RPM along with power.
Further testing last Friday with E-85 and larger 85 mm 9.2 PSI pulley revealed more power on the LT4 Fuel system components and fuel pressure is holding steady to 6800 rpm.
AWESOMENESS!!
Want1 is offline   Reply With Quote
Old 04-08-2018, 05:24 PM   #60
JANNETTYRACING
Originally Posted by Want1 View Post
AWESOMENESS!!
Thanks.
Old 04-10-2018, 12:50 PM   #61
Drsagacity
Drsagacity's Avatar
You are missing
Care for a ballpark range for those items?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 04-10-2018, 12:59 PM   #62
JANNETTYRACING
If you are willing to ship me the car I would be happy to write you an estimate for the whole job.
Old 04-10-2018, 04:51 PM   #63
Drsagacity
Drsagacity's Avatar
Believe me, I would be happy to do that, but looking at the distance between us, I think shipping alone would cost a couple thousand $.
TBD performance
Old 04-20-2018, 12:17 PM   #64
JANNETTYRACING
It is more common than you might think. What you spend in shipping you will save on Stress and cost to do it twice.
Ted.
Old 06-11-2018, 02:26 PM   #65
Drsagacity
Drsagacity's Avatar
Needs to go to the track this spring to see if you can put that power to the ground with some slicks or drag radials.
Laynlo,
Now you will have a chance to run this setup at the track since I am doing the same thing...I just need to borrow you as a jockey.
I will probably have DR’s soon enough.
TBD performance
Old 07-28-2018, 10:31 AM   #66
JANNETTYRACING
Bump for discussion.
Old 07-28-2018, 06:38 PM   #67
Drsagacity
Drsagacity's Avatar
My buddy had a death in the family so we were delayed. We have the rack space open this coming weekend and I am expecting we will get it started on Thursday.
I can’t wait to go through the process. I will take pictures and maybe start a new thread to walk through the tuning experience Ted.
TBD performance
Old 07-29-2018, 01:04 PM   #68
laynlo15
Drives: 2022 Lt1 A10
Good deal Russ, glad to hear you are getting it done finally.
Old 07-29-2018, 01:49 PM   #69
Drsagacity
Drsagacity's Avatar
Ted, what is the difference between the power you achieved on the car in this thread and the next thread where you were at 750whp. It looks to be the same setup. Did you just run the smaller pulley and e60 instead of e85?
TBD performance
Old 07-30-2018, 07:40 AM   #70
JANNETTYRACING
They were done about a year apart.
