#57 |
Drives: '14 Jetta 1.8, '19 1SS Join Date: Mar 2010
Either another car or not. Not sure yet. Also was the oil pressure of around 11psi when the alert came on. I didn't check/notice the level before it overheated. Just only noticed it at 11 when I got the alert...didn't get around to checking the oil level. But usually pressure shouldn't be that low even without coolant.
#58 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
High engine temp, low oil pressure..... even for a couple seconds you could have scorched cylinder walls, seals, gaskets..... return it to the dealer. And for the sake of the next owner I hope that dealer replaces the engine.
#59 |
![]() Drives: 2017 Camaro 50th Anniversary 2SS Join Date: May 2016
It's great to hear the dealership stepping up and supporting you! All to often this doesn't happen. Keep us posted on the final outcome.
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016 Production Sequence: 934 |
#60 | |
![]() Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
#61 | |
![]() Drives: Nightfall, 2SS, A8, MRC, NPP,RE-71R Join Date: Jul 2016
#62 | |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Sorry to hear about what you are going thru. Aluminum blocks/aluminum heads don't like to be overheated, I would walk away. Good luck
#63 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Seems a little ridiculous that this is 2017 MY car and we're still seeing quality control issues like this popping up. Anyone else think it seems excessive at this point?
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#64 |
![]() Drives: 2017 2SS, 2000 Trans Am Firehawk Join Date: Jun 2014
You are only seeing a very small percentage of people complaining. I have no issues with my 17.
I am a sarcastic SOB.
#65 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
My job on the line was to put the lower radiator hose on the cars and secure a transmission cooler line. On average the car was moving by you and in your work area for around 50 seconds. You get very good and efficient at your job because if you mess it up or miss something and they have to stop the line it isn't good for you as a worker. Anyways doing my job and the line supervisor comes over and rips on me saying I forgot to put the lower radiator hose on a couple of cars and that they failed the vacuum fill coolant process. There was no way I forgot, just not the type of person I am. So after that I started checking how secure the hoses were after I put them on. Ended up finding some defective lower radiator hoses that were not in spec. The hose was too big and the rubber was super slick, even with the clamp on tight you could pull the hose off. So something that was blamed on me ended up being a supplier issue. So stuff happens, daily and more than people think. There is only so much the final assembly inspection workers can do to try and catch things. As far as the OP goes if the engine was shut down early it will be fine, 11psi of oil pressure under light throttle and or coasting is plenty to keep metal off of metal in the engine. I am almost for sure that the fail safe protocol in the engine will shut the engine off if oil pressure drops fully or coolant temps get over a max point. GM uses several oil pressure sensors and they are tied to the fuel system, if you loose oil pressure the ECM cuts fuel to save the engine. If the dealer swaps the car out for him then good deal, it is the dealer stepping up and doing the right thing. In reality the dealer doesn't have to, all they have to do is provide the failure information to GM and wait for GM to say either replace parts and get the vehicle back on the road or to replace the engine and get the vehicle back on the road, GM wont just offer up to take the vehicle back. I know this personally and have been down this road with GM recently, it takes an act of Congress to get a GM manufacture buyback. |
#66 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Although I am annoyed about this trans cooler line recall I have on my car. I mean, having a bolt rub against the line sounds more design related...
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#67 | |
As far as oil pressure goes, I don't know how long the psi was that low in the 15-20 minutes I was driving it. I honestly didn't pay attention as no alerts came up for oil pressure. I certainly wasn't coasting or being light on the throttle though. I was breaking it in and varying the rpm and not being shy about giving it gas. No WOT or anything but I wasn't babying the car too much either. |
#68 | |
#69 |
![]() Drives: Red Hot SS 1LE Join Date: Dec 2015
#70 |
![]() ![]() ![]() ![]() Drives: 2021 Shadow Gray 1LS Join Date: Oct 2011
I was following your original thread and how excited you were to get the car. A shame this happened.
