Old 04-27-2017, 07:36 AM   #57
Originally Posted by mxair2001 View Post
Since I had to buy new USB-C cables for my S8+ anyways (coming from S7 edge), I got a USB3 Type-C cable for the car. Now, instead of slowly draining the battery whenever I use AA...my phone is almost fully charged on my commute home from work.
So a little off subject but does the charging pad in the Camaro work with the S8?
The phone is a little too long to fit on it but not sure how that thing is supposed to work anyway.
My cables are on order.
Old 04-27-2017, 08:51 AM   #58
SSport16
SSport16's Avatar
I believe that is one of the benefits of USB-C.
Here are the benefits pertaining to power...
USB-C, USB PD, and Power Delivery
The USB PD specification is also closely intertwined with USB Type-C. Currently, a USB 2.0 connection provides up to 2.5 watts of power—enough to charge your phone or tablet, but that’s about it. The USB PD specification supported by USB-C ups this power delivery to 100 watts. It’s bi-directional, so a device can either send or receive power. And this power can be transferred at the same time the device is transmitting data across the connection. This kind of power delivery could even let you charge a laptop, which usually requires up to about 60 watts.
Old 04-27-2017, 08:54 AM   #59
SSport16
SSport16's Avatar
Yes it does. I have the S8, not the S8 +, and it fits. It charges without any modifications, but I don't trust it since it can easily slide off. I modified my pad, cut one of the little "bumps" off on the side, now mine fits great. I leave mine in a leather pouch sleeve from my S6 and the phone in the pouch fits great now. I do have another case that is supposed to arrive today, same type, but may not fit as great, so may have to cut the other bump, but should fit then.
Old 04-27-2017, 08:58 AM   #60
Thanks I'll have to trim a bump off for sure. I also have S8 not +. Didn't work with one end slightly up and not in the case
Old 04-27-2017, 09:13 AM   #61
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I'm wondering why with just using the USB Type C cable it is suddenly charging faster. From what I remember, the USB port in the car is a 2.0 port, so it should not see any boost in power for a type C cable. I'm downloading an app now to measure what the phone is getting. Will try my old S6 cable (with type C adapter) vs the one that came with the S8.
Old 04-27-2017, 10:30 AM   #62
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
your cable wont magically charge the phone faster.
What's probably happening is that it's a new phone. It charges faster due to the new battery and newer technology the battery employs to allow it to charge faster.
aged batteries will show degradation and charge slower despite also having less capacity as they age due to the internal resistance changing on top of the older chemistry used and lower current for charging the battery coming out of the charging circuit so it doesn't overheat.
Adding a usb-c cable or an adapter wont change how much current comes out of the usb 2.0 ports coming from the hmi.
Old 04-27-2017, 10:33 AM   #63
cellsafemode
Originally Posted by SuperSound View Post
You must have changed it to English (UK) in TTS right? I was messing with it today but had used maps yet.
Yes, i always change my TTS voice to some version of UK or aussie depending on which voice sounds sexier.
It's been annoying for years because google has refused to abide by the setting and forced it's network TTS voice which is determined by your network location vs whatever you have set in your device.
Finally though, it seems either samsung changed that or google finally got around to stopping that stupid override of the user's choice.
Old 04-27-2017, 09:47 PM   #64
SSport16
SSport16's Avatar
Yeah you are actually right. I know the battery in the S8 was designed differently including it to hold 95% of its orignal capacity after 1 year, not to mention newer charging speeds.
Old 04-28-2017, 04:45 AM   #65
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I was wondering how my s8 is always at 100 percent, car does charge alot faster now, go from 60 to 100 on rode home from work.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 04-28-2017, 08:40 AM   #66
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
They are accepting waze beta testers. I just got accepted.They are accepting applications now for the Waze AA Beta now. The 2016 Camaro is on the list too
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 04-28-2017, 09:11 AM   #67
mxair2001
mxair2001's Avatar
Drives: 2016 Summit White 2SS
I was accepted to be a beta tester back on April 7th, haven't heard anything since. Don't have a new version of Waze on the beta tab in Google Play, and nothing on their website. =/
mxair2001 is offline   Reply With Quote
Old 04-28-2017, 09:15 AM   #68
keon718nyc
Indeed, i joined the other day and got accepted as well, just signed up for the Waze AA Beta. Look forward to it!!!
Old 04-28-2017, 10:12 AM   #69
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
My s8+ charges way faster than my note 5 ever did using android auto.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 06-06-2017, 10:32 AM   #70
keon718nyc
Beta testing for WAZE on Android Auto starts today for those that signed up. Email just came in this morning...
