Old 12-09-2016, 09:57 AM   #57
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
Originally Posted by JulesWinnfield View Post
Yes. I make conclusions from the cts-v vs hellcat, or the z06 vs hellcat races.
a10 can help, but a little.
The ZL1 is also lighter than the CTS V and that transmission will make a world of difference. I have seen a stock video of roll on with a Hellcat vs a Z06 and the Z walked away. I think the A10 might be slightly faster than the Z06. I think the ZL1 will be faster than you think and certainly quicker than the Hellcat where it matters. Just my hunch based on reported trap speed numbers of 11.4 1/4 mile at 127mph and it is believed that the ZL1 is even faster than what has been reported.
Motortrend will almost undoubtedly have a shootout of the two vehicles and may even throw a GT-R in there just for the hell of it. We'll know soon enough how well the ZL1 stacks up. Can't wait.
snackbar64 is offline   Reply With Quote
Old 12-09-2016, 10:32 AM   #58
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
And that 11.4 was on a unprepared surface. the 5th gen they took to a track and did over 800 hard launches to test the durability and get the best time. Is there a reason they didn't do it this time? A surprise coming?
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 12-09-2016, 10:34 AM   #59
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Do we know any of that?
Don't remember reading about an unprepared surface.
All of their cars of similar "genre" typically go through the same sort of testing. clutch dumps, 24-hour track test, etc...I don't think I read anywhere that the car did not undergo drag strip testing.
Old 12-09-2016, 10:35 AM   #60
Sven59
HAMMER PILOT
Sven59's Avatar
I will have to look back, I think it was Al O. in one of his commentaries.
Old 12-09-2016, 10:36 AM   #61
Mr. Wyndham
I'd be interested to read/hear.
Old 12-09-2016, 10:44 AM   #62
Sven59
HAMMER PILOT
Sven59's Avatar
*ZL1 performance numbers achieved with a coupe equipped with the available 10-speed automatic transmission and using original-equipment tires on a non-prepped surface.
http://media.chevrolet.com/media/us/...08-camaro.html
For the fifth gen they also ran it on DRs to make sure it worked with them and they released a video, haven't seen that for the 6th gen.
Old 12-09-2016, 10:50 AM   #63
Mr. Wyndham
That's awesome! I must've missed that little disclaimer.
Old 12-09-2016, 10:51 AM   #64
Sven59
HAMMER PILOT
Sven59's Avatar
Are they sandbagging?
Old 12-09-2016, 10:53 AM   #65
Mr. Wyndham
What's a prepped surface worth in a quarter mile run?
Old 12-09-2016, 10:56 AM   #66
Sven59
HAMMER PILOT
Sven59's Avatar
Not sure but it makes you wonder what they might be holding back.
Old 12-09-2016, 11:15 AM   #67
DenverTaco07
DenverTaco07's Avatar
to play devil's advocate...
It may be to the benefit of the ZL1 (in a vs. HC scenario) to go on an unprepped surface...seeing how the ZL1 is lighter and less powerful than HC., but folks who have expertise may have more concrete opinions.
Old 12-09-2016, 11:18 AM   #68
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
The C7's made zero gains in acceleration when going from A6 to A8. I would not expect much improvement at all going from A8 to A10 in acceleration. Gearing, 0-100 mph is near identical in the A8 and A10. I doubt you'll see more than .1/1 mph gain from 100 to the end of the track.
The reality is that the bigger difference should be seen at the road course with it's improved shifting programming.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 12-09-2016, 11:24 AM   #69
Sven59
HAMMER PILOT
Sven59's Avatar
The 5th gen was a A6, so you are going from a A6 to a A10. The A10 is also much better at keeping the car in the powerband with little drop in RPMs.
Old 12-09-2016, 11:34 AM   #70
Zeke.Malvo
Zeke.Malvo's Avatar
Ugggh sounds like you're regurgitating the sales pitch. Look at the real-life gearing/numbers instead. The C7 made zero acceleration gains going from A6 to A8. The A10 has near ZERO gearing advantage on the A8 up to about 100-120mph. Simple stuff here people.
On top of all that, the LT4 does not love RPM's, so the little drop between gear changes isn't as advantageous as it could be.
