Old 12-16-2016, 11:05 PM   #57
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by HyperblueSS View Post
Went back tonight and ran slightly better on my first pass but couldn't stick the launch the rest of the night. My mph was way up though...I think it being cooler helped out alot, plus my E85 percentage was higher. When I went last time I had a few gallons of 93 mixed in so I wasn't taking full advantage of the extra timing. This time I had more E85 in there and my trap speed was 119. I wasn't launching as hard because on the second run I had some wheel hop and it didn't feel all that great...didn't want to break anything. So after that I launched at a lower rpm.
That 11.8 at 119 is nice man!
Have you tried the LC "trick" discussed in this section yet? Some have good luck with it, and it's a little easier on the car. Also, are you using no lift shift? If so, try lifting a little yourself. The logs I have seen show that no lift shifts cuts too much timing and if your good with the throttle you will go quicker without using it. If you need better explanations of either, just hit me up...
Old 12-16-2016, 11:17 PM   #58
2000form
Drives: 2000 pontiac formula
Wow that's impressive. I was at palm beach international tonight and the temperature was around 75 but I was in my firebird. My best mph in my 2017 SS was 113.5 and it was maybe 65 but it was really humid. The SS is completely stock.
2000form is offline   Reply With Quote
Old 12-16-2016, 11:28 PM   #59
HyperblueSS
HyperblueSS's Avatar
Drives: 2016 Camaro SS M6
OSW can have decent DA over the winter. I ran there a lot and have seen 200-400 a few times in December-March. -1000 isn't going to happen unfortunately lol...
Yeah it wasn't too bad out there today, i think the DA was around 800 or so. Maybe by the end of January ill be able to go out there and catch a good 50 degree night lol
2016 Hyperblue 1SS M6
"If you're not first you're last!"
HyperblueSS is offline   Reply With Quote
Old 12-16-2016, 11:30 PM   #60
HyperblueSS
Yeah those few mods really helped, I want to check out some of the other tracks in Florida one of these days. Only been to the one in Orlando so far.
Old 12-17-2016, 06:59 AM   #61
wnta1ss
Drives: 2017 Camaro 1SS
Congrats on your new personal best time.
Have you thought about installing G-Force axles?
Old 12-17-2016, 09:44 AM   #62
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Make sure you add that slip to the fast list thread...
Old 12-17-2016, 10:07 AM   #63
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Nice times!
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 12-17-2016, 10:48 AM   #64
HyperblueSS
Thanks...I have thought about doing upgraded half shafts but until I start making more power, if I break a half shaft I'd probably replace it with a stock one because they are about $200 for either side.
Old 12-17-2016, 10:49 AM   #65
GirlyNFG
GirlyNFG's Avatar
I have stock axles for sale!!
PB: 9.569 @ 151.05
Old 12-17-2016, 10:50 AM   #66
HyperblueSS
Originally Posted by GirlyNFG View Post
Nice times!
Thanks! Your car is very mean by the way...I bet it's pretty bad ass to drive.
Old 12-17-2016, 10:51 AM   #67
GirlyNFG
GirlyNFG's Avatar
Thanks as well! I can't wait to get it to the low 10s. High 9s have become a new goal. Someone needs to stop me... I've got a problem 😂😂😂
PB: 9.569 @ 151.05
Old 12-17-2016, 11:05 AM   #68
HyperblueSS
Lol I think we all do!! I just have restrained from spending big money...so far
Old 12-17-2016, 03:00 PM   #69
Fraxum
Fraxum's Avatar
Nice, backing up you earlier runs. And yes, me too I only am faster one out of three or four runs. Also your mph is right there with mine. So for all the $$ I have spent you car is making the same power.
I can't wait to add E85 to my setup.
Old 12-17-2016, 03:03 PM   #70
Fraxum
Fraxum's Avatar
That Steve2016ss guy ran 11.90's with just a tire swap don't forget...
I think all street tires of the same stock width should go on the stock list too. So the SS M6 is capable of 11s stock. Is that your point?
