Old 01-09-2017, 09:55 AM   #57
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
Originally Posted by GirlyNFG View Post
Heres the official procedure. With the cars I have seen, we have been instructed not to disassemble any. Any diagnosis has been just a guess so far. GM has requested the diffs to be sent back whole and untouched.
That being said, here, we have replaced two.
Thanks for that Jess. That helps out a lot.
pinoyscorpion951 is offline   Reply With Quote
Old 01-10-2017, 06:53 AM   #58
Bobfly
OspreyTech
Bobfly's Avatar
Thank you Girly for that info. Are these Camaros serviced with the synthetic oil on the assembly line? Seems like maybe they weren't getting the friction modifier added. For what it's worth, my dealership has been good on warranty work.
By the way, that's a kick ass SS you've built. Very nice! Got any track vid's to share?
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 01-10-2017, 10:14 AM   #59
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
The modifier should NOT be added if the proper fluid part number is used.
Thank you I have lots of videos (and other crap) on my ig: Jessssiko
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 01-10-2017, 01:28 PM   #60
lDejavul
lDejavul's Avatar
Drives: Camaro SS
So the fix is to just replace the fluid? Mine has had the noise for a while and my dealer want to replace the strut mounts. Told them no since I knew that wasnt the issue and more likely busy work to keep my from pestering them and get some warranty money. Now I'm worried it could really have messed things up by now. The sound is much louder then when it started.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 01-10-2017, 05:12 PM   #61
GirlyNFG
GirlyNFG's Avatar
The possible solution is the friction modifier/fluid change. That is the starting point. Did you road test with them? Leave the car overnight so they can hear it first hand?
These are things that help us fix cars right... the first time
PB: 9.569 @ 151.05
Old 01-11-2017, 11:42 PM   #62
Antista1974
Antista1974's Avatar
Drives: 2016 Camaro 2ss 2nd cat delete
There are several service bulletins out on this for the Cadillac, Corvette and Camaro SS that use this Differential. The problem is that the clutches are dragging or locking up in the rear end. First fix is to flush and refill the oil in the diff. If the clutches are worn or damaged you need a new differential also known as the carrier. I just picked my car up last night. It only took them 3-4 hours to change it out. No more noise! This is a warranty repair. On mine, they said the clutch packs had come apart (24,000 miles). Most dealership mechanics are familiar with the problem.
I was told to drive figure eights....REALLY? This isn't a fricking motorcycle man...
Antista1974 is offline   Reply With Quote
Old 01-11-2017, 11:48 PM   #63
Antista1974
Originally Posted by RedHot16 View Post
I'm sitting at the dealer right now and they have never had any cars with the issue come in or heard of it.
Doesn't your v6 have an open differential? you shouldn't have this problem
Old 01-11-2017, 11:54 PM   #64
Antista1974
Isn't this the purpose of the manufacturer road testing these cars for a year in all climates to help identify things like this. I'm $48,600 into this awesome car but come on GM help us out here on the basics please.
Old 01-12-2017, 11:20 AM   #65
wrankin
Camaros Of Northwest Ohio
Drives: 2023 Red Hot 2SS 1LE
I just noticed someone added a Camaro6 poll to collect data about this issue. It is located here:
http://www.camaro6.com/forums/showthread.php?t=479244
Bill R
wrankin is offline   Reply With Quote
Old 01-12-2017, 06:30 PM   #66
RedHot16
Drives: 2016 Red Hot 1LT 6 cyl M6
The automatic is open mine being manual is an LSD.
RedHot16 is offline   Reply With Quote
Old 01-13-2017, 09:00 AM   #67
Bobfly
OspreyTech
Bobfly's Avatar
When the car is low miles and the noise isn't too bad, they usually do a drain and refill with fresh oil and the figure 8's both lubricate the clutch packs and allow the mechanic to test each clutch pack for noise (when the oil is cool). This seems to be a lubrication problem more then anything else.
Old 01-26-2017, 07:30 PM   #68
Algeron
Algeron's Avatar
Drives: 2023 ZL1 Convertible, 1998 Z28
Mine is in the shop for the 3rd time for this. (Not this alone, but another issue, and I have brought this up as well.) All the tech will say is, "that noise in the rear is a normal noise for that vehicle. " It was bad enough 2 weeks ago that the whole car was shaking while turning.
2023 Rapid Blue ZL1 Convertible
Algeron is offline   Reply With Quote
Old 02-15-2017, 12:20 PM   #69
MikeDUSA86
Hi guys,
My car also suffers from the grinding noise when turning at low speeds in cold weather.
I imported my 2016 to the UK at the end of last year, and Chevrolet no longer have dealers/garages here. There are a couple of authorised repair/mechanics where I'm based, but I wanted to check a couple of things with y'all;
What is the correct fluid for rear diff. I want to make sure they use the correct one.
What did the flush involve? Did they use any special fluids?
Thanks,
Mike
MikeDUSA86 is offline   Reply With Quote
Old 02-15-2017, 02:26 PM   #70
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
Mine had the same issue with the diff groaning during turns when the car was cold. The dealer swapped out the fluid and now it doesn't groan, so far.
Wyzz Kydd is offline   Reply With Quote
