Old 11-08-2016, 09:01 AM   #57
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
and the V-6 1LE is two seconds quicker around the track at GM’s Milford Proving Grounds than the fifth-generation SS.
Ummmm.....wow....
Thor142 is offline   Reply With Quote
Old 11-08-2016, 09:26 AM   #58
Rafal
Drives: Sold - Krypton Green 1LE
Originally Posted by FNxR3DNECK View Post
As for the rotors I thought it was weird that they were different from the 6 piston kit you can get for a regular SS, but from what I keep reading I think they are basically the same as the ZL1 rotors just a tiny bit smaller, I guess the Chevy guys figured they didn't need to be slotted.
For track duty quite often is better to not have slots and for sure you do not want drilled rotors. Too big of a chance of cracking. If Plain Jane rotors work fine fade free there is no point.
Rafal is offline   Reply With Quote
Old 11-08-2016, 10:29 AM   #59
MatthewAMEL
MatthewAMEL's Avatar
Drilled are definitely a bad idea. Slotted, though...there is some use for slotted. The C7 Z51 rotor is slotted and the Z06 is drilled. The rules may be different for a carbon ceramic rotor.
I've read/heard many times that a slotted rotor helps with outgassing, which keeps the pad from pushing away from the rotor when it heats up.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 11-08-2016, 11:03 AM   #60
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
You know that any components from the factory are going to be top of the line quality wise and have been tested, thoroughly. I don't think you have anything to worry about if you use the GM slotted rotors at the track. It was probably a move to save $ and keep the cost of the car as low as possible. People are going to chew through rotors that track it regularly anyway, so I don't think it's a big deal. They do look pretty nice though.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 11-08-2016, 12:15 PM   #61
Iron Oak
Club Motorsports Track Op
Iron Oak's Avatar
Drives: STI, Land Rover and future 1LE
I'd be more concerned with a proper track pad vs the rotor. And changing out the fluid
Iron Oak is offline   Reply With Quote
Old 11-08-2016, 12:55 PM   #62
Mountain
Mountain's Avatar
Slots provide more for keeping the pad-to-rotor surfaces clean and also a tuning aid in pedal feel. From what I understand, and this is coming from a conference I went to put on by one of the major racing brake pad companies, that, YES, even new pads do create some gasing that is beneficial to eliminate in high levels of competition. In lower levels and for track days, it isn't much important as the amount of gas is considerably less than what it was many years ago when the hype for drilled an slotted rotors started.
Solid face rotors will do 99% of what is needed, the most reliably. If you need more for one of the three reasons above, move to a slotted rotor. Stay away from drilled rotors. The only ones worth anything are the expensive ones that have a lot of engineering behind them. Otherwise they are a big risk in failing on track.
Old 11-08-2016, 01:03 PM   #63
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
This.
Old 11-08-2016, 01:33 PM   #64
6spdhyperblue
Drives: 2SS 1LE
Does the patented treatment on the rotors from GM make them last any better than regular rotors?
Old 11-08-2016, 01:39 PM   #65
Thor142
Thor142's Avatar
Did I miss something? What is GM's patented treatment?
Old 11-08-2016, 01:51 PM   #66
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
Duralife Brake Rotors
http://media.gm.com/media/us/en/gm/n.../1130_fnc.html
BahamaTodd is offline   Reply With Quote
Old 11-08-2016, 03:23 PM   #67
Thor142
Thor142's Avatar
Originally Posted by BahamaTodd View Post
OK so they've been using it sing 2008. I guess if you don't track your car that'll definitely extend the life span of a rotor.
Old 11-08-2016, 04:14 PM   #68
6spdhyperblue
Drives: 2SS 1LE
Ah good info, never knew what it did specifically
Old 11-09-2016, 09:10 AM   #69
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I wouldn't be worried about slotted rotors, especially factory slotted. I have nearly 1,000 track miles on my '16 C7 Z51 with a very very aggressive race pad and I'm still on the original rotors.
BaylorCamaro is offline   Reply With Quote
Old 11-09-2016, 10:36 AM   #70
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
This.
Seconded.
Change your fluid...and the car will likely out-drive you, until you get better...
