Old 11-06-2016, 10:08 PM   #57
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
Originally Posted by 16CamaroSS View Post
Odd that since you were poking fun, you couldn't just say that the first go round but whatever.
And post count doesn't mean squat though I've gotten my thousands of posts over a variety of forums if it makes you feel better. What it really comes down to is basic forum "decorum" which is pretty universal. My guess is the the way you want to talk down to the "new guy" says a lot about you and post counts will never fix it.
So sure, I'll ignore your condescension towards someone who mistook a non-obvious joke for punkish behavior which was followed by actual punkish behavior and you can ignore anything I have to say and call it a day. Cheers.
I guess this entire drama could have been avoided if I had used instead of
My bad.
Old 11-07-2016, 07:07 AM   #58
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Originally Posted by central limit View Post
For anyone who considers the sound from the pipe to be fake:
This approach - not fake, but still artificial. You still had to add something to the intake tract that has no performance function whatsoever.
If the actual intake tract was routed along the firewall and bolted to it, that would also make the intake sound louder. Would that be fake too?
Less artificial than a separate tube, but probably more complicated than necessary. I think there's a better approach.
There's racing precedent for actually drawing intake air from the base of the windshield (1960's Trans Am). These days, you'd have to run an intake duct from there to a passenger-side filter box, though that shouldn't be all that difficult to arrange for at the vehicle design stage. That would give you the functionality and the satisfaction of having the sound along a logically and physically correct path.
Back in the 1980's I actually modified one of my previous cars that way, though only for the free-breathing and cold-air aspects. That it was a carbureted engine did not necessarily make it any easier.
Norm
Old 11-07-2016, 08:21 AM   #59
central limit
Drives: 2016 1LT M6
I'm not following how this is artificial if it is not generated by an ancillary process; it's just a medium to propagate an existing resonance. It's not like a separate sound is being generated just to feed the driver's ears.
I would agree that it does not add performance, though I would posit that it afforded the engineers some flexibility by not imposing additional packaging constraints. I believe it also does this without any consequential performance penalty, and is inconspicuous enough that many would never notice it over years of ownership.
Norm
This is intriguing.
Would this arrangement still allow for proper tract length while retaining the current rearward (almost FMS) mounting position of the engine? That immediately caught my eye when I opened the hood at the dealership and reassured me that the design team included at least a few folks who care about how a car feels both on the road and in the garage.
While I'm still unsure about the artificial part, I see why you consider the pipe to be a shortcut. I do however, feel it does its job in an efficient and discrete fashion. IMO, the car sounds positively lovely, and I don't foresee that 1.25" tube obstructing any jobs that need doing in the foreseeable future.
Thanks for the discussion, by the way. Learning from this.
OP: hoping you got your answer by now; apologies for topic drifting.
I should probably explain why I suspect that capping at the firewall might not be necessary when removing the tube. As someone pointed out, you don't want un-metered, unfiltered air entering the intake tract where the noise pipe connects. I give the benefit of the doubt that the engineers designed the noise tube and trumpet assembly to be air tight, so as not to cause this exact problem by allowing underhood or in-cabin air to flow back into the intake. I shouldn't hurt to plug at both ends though, but I would be particularly more concerned about an air tight seal on the intake tract.
This type of plug can be adjusted for proper tension, provided the hole is perfectly round.
central limit is offline   Reply With Quote
Old 11-07-2016, 08:50 AM   #60
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
I haven't personally considered doing this but after reading this thread I was wondering if it's possible to cap it off from inside the cabin without removing it from the engine compartment? Just a thought.
What's the difference in sound when it's removed? Significant or minimal?
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 11-07-2016, 09:46 AM   #61
Hyper16
Hyper16's Avatar
I have some high-frequency hearing issues and I used to hear a whining noise. When I removed the tube the whine went away. Also, in my opinion the cabin got quieter.
Old 11-07-2016, 09:51 AM   #62
sub_ETCS_ret
I'm curious because my car sounds louder with the window up than with the windows down. After reading this thread I was wondering if I removed/plugged it how much quieter it would get. Could be the crappy run flats though.
Old 11-07-2016, 10:19 AM   #63
Norm Peterson
Maybe it'd make more sense if I called it a tacked-on, artificial sound path, still a band-aid solution to interiors made too quiet for other reasons, still something that the engine neither needs nor benefits from by its presence.
I'm old enough to not want to add anything to a car that the car does not need in order to be driven in a high performance manner or made faster/quicker/mechanically better at doing so.
Funny thing is, I could actually appreciate it where a savvy racer used the sound tube as, say, part of a hidden nitrous installation. Because then it'd be functional . . . and a bit sneaky to boot (free hint for anybody who cares to experiment along that line).
Norm
Old 11-07-2016, 11:03 AM   #64
central limit
Drives: 2016 1LT M6
If someone on the design team insisted on additional induction noise, I'm glad they went this route instead of going electronic or creating a wonky intake path. Imagine how expensive that would have made aftermarket options.
I agree the addition does not benefit the engine. What it does accomplish, for some of us, is to elevate the driving experience without penalty to mechanical priorities--which is what NPP does at the other end.
I suppose you could say I'm old enough to simply enjoy a good product without letting small picture stuff detract from the experience. It's almost certain there are countless other design decisions that many would not agree with on this car, just as with any other complex device.
Diversity is the spice of life, eh?
Old 11-07-2016, 01:42 PM   #65
Hyper16
Hyper16's Avatar
They do add to the noise. I just took them off last week in favor of Continental DWS06. The tire 'roar' is gone.
Old 11-07-2016, 01:44 PM   #66
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
So if I want to test the noise diff, I got to get a plug for the tube, and a plug for the air cleaner Plenum, and zip tie the tube up, correct?
Old 11-07-2016, 01:55 PM   #67
Hyper16
Hyper16's Avatar
Yes. That should do it.
Not sure how it connects on the V6 but the V8 has a complete assembly that is bolted to the engine. Not just a tube plugged into the CAI elbow. The tube runs from the firewall to the assembly and then a smaller tube runs from the assembly to the CAI elbow. I removed the assembly when I changed CAIs but did not completely remove the tube. Just plugged it and secured it out of the way. Having the tube still connected at the firewall doesn't bother me and it will be a lot easier to replace the stock CAI in the event I have to.
Old 11-07-2016, 07:24 PM   #68
Motorin Mark
Drives: Camaro SS
So does anybody make a simple bolt on kit to eliminate the tube and cap both ends like they do for Mustang gt's? I think I paid like $20 for a simple kit last year for my 2013 GT.
Motorin Mark is offline   Reply With Quote
Old 11-07-2016, 10:44 PM   #69
webberj1
Drives: 2016 SS
I just got towards the last post of this thread and then realized I actually just read this entire thread. Feel a little weird about it.
webberj1 is offline   Reply With Quote
Old 11-08-2016, 07:00 AM   #70
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
I asked Roto-Fab if they could produce such a kit and they said that they had not considered it but are interested and will investigate. Hopefully they come up with a cheap kit for owners that aren't ready to pull the trigger on a cai but want to clean up the engine compartment.
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
