Old 06-08-2017, 04:04 PM   #57
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Originally Posted by RCF View Post
I could be wrong, but I believe that Mass Air Flow is actually calculated (not directly measured) using some constants (like maybe intake size/restriction of intake pipe, etc.) along with the info (air density) from the MAF sensor (why its called a sensor and not a meter most likely). So when you change the intake, the constants in the calculation are incorrect. If those changes are significant enough, it could cause a CEL - don't think there are any absolutes here.
I know on the 5th gen everybody seemed to do the cai mod with little trouble of any kind. I know the LT1 is different but I cant see it being off the charts that sensetive. I provided a link to the Rotofab cai which is very good and it clearly states no tune required...but who knows.
rontammy0 is offline   Reply With Quote
Old 06-08-2017, 04:08 PM   #58
MGD
MGD's Avatar
Drives: 16 Camaro SS
You're right, the values are calculated.
There are two common types of mass airflow sensors in use on automotive engines. These are the vane meter and the hot wire, (which we have). Neither design employs technology that measures air mass directly. However, with additional sensors and inputs, an engine's ECU can determine the mass flow rate of intake air.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 06-08-2017, 04:09 PM   #59
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Last I heard none of the cold air kits for the LT1 caused a CEL (including the CAI one this is based on). Some definitely threw the MAF tables off which could cause driveability/emissions issues. I'm thinking the mention of CEL is a scare tactic to push the tune and eliminate the possibility of issues down the road.
Old 06-08-2017, 04:13 PM   #60
hotlap
hotlap's Avatar
Its hard to say but this may be GMs way of dipping into the aftermarket business and adding a step {tune} that may or may not be needed. How are they telling you that they can tell if a cai has been installed? Ive never ever heard that. The maf adjusts to whatever is going on.
The article with Al's quote is below.
This unit is identical to the Cold Air Inductions but with a tune. My expectation would be that the tune optimizes for max performance.
http://www.phastekperformance.com/20...r-intake-1.htm
The man behind it? Non other than Al Oppenheiser, the Camaro ZL1's chief engineer, a diehard automotive wizard who gives credence to the "gearhead" appellation. "If you're not modifying your car and you take your production car to a track day and you have an issue with one of your parts, it's covered under warranty," he recently told Motor Authority. "We know when somebody changes their ECM calibration and we know if they changed to a cold-air intake, we can tell all that. But driving it as you break it in from the dealership, if you have a half-shaft or whatever, it's covered
https://www.google.com/amp/www.roadandtrack.com/new-cars/news/amp28688/chevrolet-will-honor-your-camaros-warranty-if-you-take-it-to-the-track/
Ronald Reagan -
Old 06-08-2017, 04:30 PM   #61
rontammy0
This I would believe. If you look at all the states the GM cai is not legal it makes me wonder what the tune auctually does that the car doesnt adjust to itself. If the tune helps emissions then it should be legal everywhere considering its a factory direct replacement. And a cai isnt going to blow you away with performance anyway.
Old 06-08-2017, 04:39 PM   #62
Waiting46
Drives: 1981 silver corvette,Hyper Blue 2SS
This assumes that CARB is a rational organization.
Waiting46 is offline   Reply With Quote
Old 06-08-2017, 04:44 PM   #63
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
CARB is rational, it's just that it's rules are inflexible and maybe overreaching.
The reason it's not CARB compliant has nothing to do with the tune. It has to do with the intake not using the carbon filter pad on top of the intake not being submitted for compliance testing.
Old 06-08-2017, 06:44 PM   #64
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Originally Posted by Ruebernard View Post
Well, it was installed today thanks to our friend Matt @ thatgmpartsguy.com They did the tune which is probably more for emissions purposes. The seat of the pants test came back a big grin and two thumbs up. Thanks again Matt!
I Don't think anyone is reading your reply.
This is PROOF FROM SOMEONE WHO ACTUALLY PURCHASED IT AND LOVES IT. I think no matter what results come back from anyone, dyno test etc. There are still gonna be those our there in denial..Congrats On glad you like bro!!!!!!!
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 06-08-2017, 10:25 PM   #65
Gen-X45
Gen-X45's Avatar
Drives: 2017 2SS Camaro
I'm going to duct-tape a chunk of dry ice to the inside of the stock box. That will let in some cool air.
Gen-X45 is offline   Reply With Quote
Old 06-08-2017, 10:57 PM   #66
cellsafemode
yea, but it'll be mostly CO2 and probably stall your engine. You'd have to find some way to vent the dry ice outside of the intake.
A viable solution would be to just implement a water injection system to cool the air. Then if you want, you could use the dry ice to cool the reservoir, if you're careful not to freeze it solid.
joke fail.
Old 06-09-2017, 02:24 PM   #67
Ruebernard
Ruebernard's Avatar
Drives: 2023 Radiant Red Tintcoat 2SS
That's ok. Thanks Killa!
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
Old 06-09-2017, 06:53 PM   #68
hotlap
hotlap's Avatar
I think it looks great and I texted your picture to several friends. Clean and I like the Chevy Performance tag on it. Warranty with tune means I'm in but will wait until fall now that temps are up anyway.
Ronald Reagan -
Old 06-09-2017, 06:58 PM   #69
hotlap
hotlap's Avatar
Ok...so the Demon is advertised as stock even though the crate, with CAI, tune and skinnies,. is provide over the parts counter. Does this CAI counts as stock? ...like other LPO options (6-piston brakes)?
Ronald Reagan -
Old 06-10-2017, 06:58 AM   #70
newmoon
newmoon's Avatar
Drives: 2019 GT350
Easy question can you order the vehicle with this as one of the options? If no then it is not stock. Think of it this way Ford offers supercharger kits for the 5.0 should these be be considered stock?
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
