#57 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I was surprised to see that in there (that matches the 2017 manual). The 2019 manual states 1st or reverse as stated above.
Also need to make sure you "firmly apply the parking brake."
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#58 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Its all about the gear ratio's. When you park you should put the car into a low gear. This is to create a large ratio between your wheels and engine to prevent your car from turning the engine.
In the case of the M6 in a 2016+ SS, Reverse and 1st will be your lowest two gears. Reverse: 2.9 1st Gear 2.66 2nd 1.78 3rd 1.3 4th 1.0 5th 0.74 6th 0.5 Generally speaking, If your clutch is bad your car can roll, steep enough hill? car might still roll. So thats why you should use parking brake ontop of putting it in gear. |
#59 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
I just strap it to the bicycle parking with a cable lock
#60 |
Nah, massive overkill. Just use this red one in the front and black in the rear. 100% secure, it even has insurance approved combo locks (2!!!)
#61 | |
![]() Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
My wife will get used to what ever. Shes a better driver than most guys I see. For me, after the first 30 years of my working life mostly being spent driving big trucks... Im going to need to learn to leave a manual in gear. When I started trucking the diesels were all mechanical governors. It was feasible that if you left it in gear and it started to roll... that the engine would fire right up and run something over. Sp I was trained to leave them in neutral.
#62 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
For the past 40 years been leaving my manual transmission cars in 1st gear when getting out. Not about to change. I don't buy the turning off more electronics, that I believe is a load of rubbish.
#63 | |
![]() Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
#64 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
#65 | |
#66 |
#67 | |
#68 | |
#69 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Yeah... handbrake... I wish the 6th Gen still had a "hand" brake like the 5th Gen did. I have had my ZL1 for just about 3 years and the e-brake is annoying AF.
I miss a real handbrake...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#70 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
This ^^^
I leave my cars parked in either 1st or Reverse, whichever direction would result in the lesser damage if the car was to unexpectedly start up with the clutch less than fully depressed but still far enough to permit the starter to turn. Mostly like, away from the house. Learned that back in the days before clutch position switches were a thing. Useful knowledge in cases where the CPP switch has either taken a dump or could not be adjusted enough to permit starting at all. I've never heard where parking with the transmission in reverse would draw less current. Norm
'19 WRX 6M (the family sedan . . . seriously) |
