Old 02-12-2017, 05:22 PM   #57
parish8
Drives: 17 SS a8
all finished up under the car
Old 02-13-2017, 08:10 AM   #58
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
Personally i would have route the dumps back into the downpipe.
Stainless is strong but will quickly stress crack from vibrations. And with a 2 foot pipe and extra weight you are deff gonna get some vibration there
Goertz is offline   Reply With Quote
Old 02-13-2017, 09:19 AM   #59
parish8
Drives: 17 SS a8
Time will tell. I was planing on making a hanger from the main exhaust pipe to the wg muffler but it was rock solid without it. I guess a hanger might help dampen vibrations.
Unfortunately the car still gets kinda loud at wot and higher rpms even in stealth mode. I think the cut outs are opening. I am not sure if that is how they are designed or if they are just pushing open.
Old 02-13-2017, 10:30 AM   #60
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
I like the way they fit down there. Is there room to route an intake tube to higher ground?
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 02-13-2017, 10:24 PM   #61
parish8
Drives: 17 SS a8
I do not see how but somehow agp gets a pair of 3" pipes up into the engine bay so there must be room. I am told agp modifies one of the engine mounts to make it work and welds elbows onto the turbo.
Old 02-27-2017, 09:59 PM   #62
parish8
Drives: 17 SS a8
The car is starting to feel fast and I am only at 4psi. My iats went from 150deg over ambient to just 20deg over.
Old 02-28-2017, 05:10 AM   #63
Goertz
Goertz's Avatar
That fawker is huge
Old 03-01-2017, 06:59 AM   #64
parish8
Drives: 17 SS a8
Let's see how these fit.
Old 03-07-2017, 05:59 PM   #65
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Looking damn good.. can't wait to run in to you this summer. Maybe the Ice Cruise
Perdieu is offline   Reply With Quote
Old 03-07-2017, 06:36 PM   #66
parish8
Drives: 17 SS a8
I took off a couple of charge pipes to have them coated but the coaters are all telling me 2 weeks. That's not going to work. I am going to just paint them for now. I should have a finished I under hood shot in a few days.
The car is running pretty good but needs dialed in a little better and a few runs on the dyno to see the results. I have been kinda busy with a couple of other projects.
Old 03-09-2017, 01:13 PM   #67
Brains
Drives: 2016 Garnet Red 2SS A8
Well hurry it up Jim, I want to see slips
Brains is offline   Reply With Quote
Old 03-09-2017, 02:57 PM   #68
parish8
Drives: 17 SS a8
Our local 1/8 mile opens April 7th. I all ready have a sitter lined up. I am ready to go right now.
Old 03-10-2017, 09:38 PM   #69
parish8
Drives: 17 SS a8
I am getting a little smoke after beating on it and for now just vented the valley but I am going to order a catch can of some kind and a quality check valve and hook it back up. the tube from the valley to the intake is dripping with oil so I am pretty sure that is where it is coming from.
here are the all finished up shots of under the hood. I think port injection is next but that is a lot of money so who knows. I am going to try and just enjoy the car with however much power I can get with the current fuel system. hit the dyno, hit the track a few times.
Old 03-11-2017, 10:41 PM   #70
Goertz
Goertz's Avatar
Run that pcv valve to a vent to atmosphere catch can ( or lazy like me and put a breather filter on ). Then cap the pcv tube on the intake and problem solved. The boost will damage a pcv valve after a while then it will leak all the time.
