#57 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Confirmed. Both types are incoming. I also secured a drop in filter
#58 |
![]() Drives: 2016 2ss Black, A8, Nav, Sunroof Join Date: Jun 2016
I ordered my CAI in July and was recently told it won't ship until the end of August. Now after watching this video I don't want it as it isn't worth installing for a small TQ gain and no HP.
This is pretty bad as CAI is claiming 11 HP and 27 tq. |
#59 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
Dodge has just introduced a new Challenger T/A with the 392 motor. Two upgrades to this car over the standard Scatpack are a true CAI, and new axle-back performance exhaust. Guess what the HP is for these additional items, nada. Don't you think if these items really worked a manufacturer would already have them and be boasting about the increases.
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#60 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
#61 |
![]() Drives: 2016 Garnet Red 2SS Join Date: Feb 2012
I should have posted this, here on sledgehammers thread.
http://www.camaro6.com/forums/showthread.php?t=464175
#62 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#63 |
Drives: Mostly Stock Join Date: Jul 2012
Sledgehammer, thanks for your independent testing of the intakes and we are glad to see our intake included in the video! Keep in mind that power claims will differ from test to test due to the difference in testing conditions. Our Camaro SS was completely stock using 93 octane pump gas. There is little chance that the mods on Sledge’s car would have a wild effect on the numbers from the intake, but it isn’t something we can completely rule out. In theory, the combination of different parts (exhaust + throttle body) along with our intake could affect the final results when compared to only testing the intake by itself, it is at this point unknown whether that is indeed the case without doing a true apples-to-apples comparison.
The order of testing in Sledge’s video can also have an effect on the final numbers. It’s possible that the computer may have been adjusting both short term and long term fuel trims for the CAI intake if that was the intake that the car was using before the test was performed. With the vehicle’s computer in the middle of adjusting for this, it would not be an accurate representation of how our intake would truly perform. Usually, as Sledge mentioned in the video, you see the plots start to decrease as more and more runs are done on the car. Given time, it would learn and adjust, and quickly swapping parts on and off could cause the engine’s computer to not learn and adjust. With that being said, we have a high degree of confidence that our results are accurate for any stock Camaro SS running 93 octane fuel. There are a few practices that we employ while we do our dyno testing. Our intake advertises max gains, which compares the stock intake vs. ours at the biggest gap in the dyno plot. Both max and peak gains are important to look at, but it must be noted that the video here analyzes the peak gains and both max and peak gains should be looked at for the entire plot. It didn’t look like the max gains were much different, but please keep max gains in mind when looking at any dyno data. As an example you might only have 3 wtq peak gain, but maybe 10wtq gains from 2000-5500 rpm which will make the car faster than just having 3 wtq for the last 500 rpms. We also always do multiple runs per test – at least 3-6 and take an average of the run, never taking the highest number run. We typically make one run, then wait 3 minutes in between runs to cool-off before making another run. In this particular test, we had 9 total dyno runs of our intake, and all of them reported higher than stock numbers. As a refresher, please take a look at our dyno plot below. ![]() Also, for those interested, please take a look at our detailed development process here |
#64 | |
![]() Drives: 2016 Camaro 2SS Black on Black Join Date: Aug 2016
So when we register our CAI you will send us eliminator? |
#65 |
I figured these CAI's would be less then advertised since GM did such a good job on theirs. I love mine because of the sound and when I open the hood. So, its all good.
#66 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
Hey Sledge, just checking how your progress is going on this project.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#67 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
We are shipping the whistle eliminator part outs over the next couple of days Did you send us and email to support@coldairinductions.com with all of your ship address and the serial number?
#68 |
#69 | |
#70 |
![]() Drives: 16 Camaro 2SS Join Date: Aug 2016
Ahhh...the CAI debate rages on, been beat to death on the Mustang, Corvette and Camaro forums.
Why is it always only about HP and dyno results...when did a better driving experience that a CAI provides become irrelevant? I encourage all the doubters to ignore the fact that any and all competitive racing circles dont use some sealed airbox with a restrictive filter and accordion style connector that impedes air flow. Ill always side with teams like Ford racing (what I grew up around) who do this for a living everyday of their lives and would highly advocate adding airflow enhancing components maxed out with proper tuning. You want better performance with ANY of your aftermarket parts...then tune the car. If youre worried about warranties or longevity, then you shouldnt be swapping out anything.. right? If all you care about is HP numbers, you can certainly Frankenstein up a wannabe ZL1 along with all the issues that come with it. Factual, unbiased info is hard to find in a forum aside from some great sponsor based testing and experiences. My Inductions CAI and tune certainly made my SS a better, more responsive drive. You can keep your HP numbers that no 2 people can seem to duplicate anyways! Last edited by DisturbedSS; 09-23-2016 at 02:18 AM. |
