#57 |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
#58 |
[QUOTE=.
Without O2 simulators there is no option but to tune out the O2s if you delete the primary cats.[/QUOTE] could just move them behind secondary cats, candy job.
#59 |
![]() Drives: 2016 SS Hyper Blue Join Date: Jan 2016
For those who have the cat delete AND NPP, how are the different modes? Really considering these, but want to make sure stealth can still be somewhat stealthy. It's nice to be quiet when you need it
#60 |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
It is still quiet in stealth mode. I have my 2nd cats cut out and I can tell a difference on startup and high rpm, but otherwise its not much louder.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
#61 |
#62 |
true dat, the oldlady's Volvo R with 3" stainless downpipe no codes till it gets cold out, then at low speed, initial start it will throw a cat efficiency code. I spaced the rear 02 out with a defouler and never had an issue after.
#63 |
I cut my rear cats and lost alot of torque.... kind of regret it to be honest.. the slight increase in sound vs the significant loss in torque just isnt worth it
#64 |
![]() Drives: 2016 Nightfall Gray Metallic 1SS Join Date: Oct 2016
Well that just changed my mind about deleting the secondaries. I think I'm just going to do an axleback until I start doing some real mods that are going to give me real power anyways.
#65 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
If someone has lost enough torque to be able to FEEL it in the seat of your pants then there is a bigger problem they are not looking at. I'd be interested to see before and after datalogs. I have my secondary cats removed via the Borla 60609 Xpipe. I have not had the same experience Nightfall1SS has. |
#66 |
It think it is rather funny that I could go thru decades and decades of racing and street performance that I used my calibrated butt dyno. I can tell you that my ride that I drive own and have launched about 500 to 1000 times works better with primary cat deletes and there is no way in hades that any deletes are going to loose torque in of themselves. I can believe in false knock. I will when I have a chance install a 2 and 3/4 stainless flex line on one side of my H pipe. Yes the factory has two really small ones already. IMO it is not enough. Also with the primary cat deletes you do lose the front hangers so there is NOTHING supporting the exhaust forward of center rear hangers just in front of the rear tires. IMO these should be hangers in front, I have LT on now and it makes it even more complicated to rig up a front hanger setup. Sure 99.99% of the vendors and mfg are going to say you don't need any flexnjoints or hangers on our LT and full (completely rigid full exhaust). GM does not think so...
#67 |
![]() Drives: 2018 ZL1 Join Date: Sep 2016
I'm wanting to run the ca pipes, currently have catback exhaust and procharger with sct tuner. can I turn the rear O2's off with the sct?
#68 |
I could NOT with mine, the vendor can with custom tune.
#69 | |
#70 |
![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
Sold
