Old 07-14-2016, 02:30 AM   #57
AlwaysAmerican
AlwaysAmerican's Avatar
Drives: 15 Silverado, 15 Corvette 2LT Z51
And now that I have a little more time... Pictures!
2016 Camaro 2SS Mosiac Black Aka-The Reaper
Build Thread- http://www.camaro6.com/forums/showthread.php?t=440437
AlwaysAmerican is offline   Reply With Quote
Old 07-14-2016, 02:31 AM   #58
AlwaysAmerican
Old 07-14-2016, 10:28 AM   #59
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I was thinking that an E force supercharger would be a better and maybe less expensive mod to achieve the torque/HP goal. I know for peak efficiency, the E Force would need headers and maybe some other improvements as well. I am going to seriously consider super charging.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 07-15-2016, 12:47 PM   #60
AlwaysAmerican
I've seen and know others with the Pro-Charger and they absolutely love them
The difference in price between the Pro-Charger and the E-Force is minimal.
So I decided to go with the option that I can upgrade for another $1,000 if need be after running E-85 to where as hp/tq numbers are concerned.. The sky would be the limit at that point.
Headers wouldn't be a bad idea, honestly I think it'll be worth it. When it's done I'll give Hennessey a run for their money as far as top speed goes.
Old 08-13-2016, 01:13 AM   #61
AlwaysAmerican
Small Update:
The block was finally bored out this week and decked, bottom end has been ordered.
So hopefully that means more pictures to come soon, then a tune for the numbers!
Old 08-13-2016, 05:02 PM   #62
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Originally Posted by AlwaysAmerican View Post
And now ARP is saying the headbolts won't be available until the end of the month.....
Damn it
i know I am behind... but I ended up using ARP headstuds since everyone was out of stock, and I'm glad I did.
what are you doing for fuel? That's been my main issue so far
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 08-15-2016, 01:37 AM   #63
AlwaysAmerican
That's the issue I'm going to have shortly.
Until someone makes a fuel pump that'll push E85 we're stuck with pump gas and meth injection (someone correct me if I'm wrong please)
That or I can deal with the headache of doing a 100 Octane tune and only being able to go to 4 different gas stations in town for it
Decisions... decisions..
Old 08-15-2016, 11:25 AM   #64
GirlyNFG
GirlyNFG's Avatar
I am running LT4 HPFP and injectors. My LPFP is being installed tonight (hopefully) from Cordes Performance. I'm running e85 full time, really trying to avoid meth.
PB: 9.569 @ 151.05
Old 08-18-2016, 01:03 AM   #65
AlwaysAmerican
What difference did you see with the LT4 injectors?
Because after talking with the shop today, I ended up ordering the LT4 fuel pump and decided we're going to tune it on pump gas at first, then do a tune with 110 octane (have it on the pump out here) and push the limits of the build after I enjoy it for a few thousand miles.
Why are you trying to avoid Meth?
Old 08-19-2016, 03:38 PM   #66
V8SS
Drives: 2017 M6 NFG
Looking forward to the results!!
V8SS is offline   Reply With Quote
Old 09-09-2016, 01:02 PM   #67
Mjae
Drives: White 1ss
How much do they charge to install the supercharger?
Mjae is offline   Reply With Quote
Old 09-16-2016, 01:43 PM   #68
AlwaysAmerican
$100 an hour is shop time.
And depending on the Supercharger is how long it'll take.
Jut don't listed to a manufacturers install time on any of them... They generally have a team of 3-5 people installing these in their advertised times. (from my understanding)
Old 09-16-2016, 01:44 PM   #69
AlwaysAmerican
The lower end has finally been built and being balanced by Callies at the moment.. Getting closer and closer and I'm getting a little more inpatient!
I suppose I can always order more parts from BMR
Old 10-05-2016, 12:18 PM   #70
GirlyNFG
GirlyNFG's Avatar
I ended up adding a Alky Control system to it... That went in last week.
Im still near the max of the LT4 injectors on e85... but it's safe.
I probably need to pick your brain... I am thinking about forging it now instead of after I break it...
PB: 9.569 @ 151.05
