#57 | |||
![]() Drives: '13 Charger Sxt+ Join Date: Mar 2013
I drove the CVT for a day and a half on a Nissan Altima, just couldnt get used to the lack of gear change.. Quote:
I even tried using the manual mode, but that takes ~ a second to shift as well.. |
#58 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
I think you need to invert that.. the high/long rpm will be from the lower gears and the upper gears will kick in AFM and you will have an exhaust sound similar to a baseball card in the spokes of your BMX bike. personally I've driven semi-trucks with 9 forward gears, I suspect the ratios for a car won't be nearly as close, but I can see the computer dumping into 10th @ 30mph and dropping back to 2nd when you get on it cause a "WTF" moment for the computer.. and a tap shift with 10 gears.. ugh...
I'm only responsible for what I say, not for what you fail to understand.
#59 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 1LE Join Date: Jul 2011
Is there anything else in the works to meet the 56mpg.... I mean beside engine, trans and weight reduction? Maybe reducing the about of friction of the tires on the ground.... or some super lube in the wheel bearings? I also envision (think cartoon) a "spring" that gets loaded when I apply the brakes that could launch me off the line. |
