05-29-2014, 04:12 PM | #57 | |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
I had Eibach Pro Kit on my previous Camaro, a 1LT/RS V6 and I had a noise in the rear as well but not all the time. My springs had rubber covers on them in areas to reduce any noise I know. I think my issue was the springs coming out of perch in the rear. It always happened and I got a hold of Eibach who gave me my money back and I ended up going with Pedder's and no more issues or noise. Now that I have a newer SS and couldn't get Pedder's I opted for Detroit Speed Engineering and love them! No noise what so ever and the ride is impeccable, the stance is perfect! The timing of the bushings should be done anytime the cars ride height has been altered either by lowering or raising. This helps the car to have a smoother ride in my opinion as the bushings had been set to the factory height and equipment. Timing basically re-establishes the bushings to the new gear and height.
Never grow up, it's a trap!
05-29-2014, 06:24 PM | #58 |
Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
Thanks for the great write up!!
05-30-2014, 03:14 PM | #59 | |
Thanks for your response! I have pfadt 1.25" springs installed. It's like a groaning or a croaking... Will it ever go away? They do have some rubber Isolators on them as well but I can't determine what would cause this. So you don't think retiming or clocking bushings will do anything? What could it be then? Sent from my iPhone using Tapatalk 2
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
06-23-2014, 10:46 PM | #60 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
Anyone know of an alignment shop in San Diego (preferably north county) where I can get this done? Do most alignment shop techs know how to do this? I don't want to go to a shop that says they can do it only to find out it's the techs first time attempting to do it. Thanks
06-26-2014, 11:34 PM | #61 |
Thanks for the help.
12-29-2014, 09:17 AM | #62 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
Subscribing to this so hard. I'll be replacing my sway bars and toe rods soon, and I wouldn't have thought about timing the bushings on the toe rods. I'll keep this in mind when I eventually get coilovers too.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
12-29-2014, 10:36 AM | #63 |
Cone Killer
Thanks! Always nice to learn something new.
01-07-2015, 08:45 AM | #64 | |
ZL1Naboz
Drives: '13 ZL1, 53 Chevy Pickup, 22 GMC Join Date: Mar 2013
I swapped SP-019's onto my ZL1 and am in the process of indexing/clocking my bushings. I am have everything loose except for the rear upper control arm bushings. I can't get a tool on the bolt to loosen it! Any tips on getting to those bolts, loosening them and then getting them back to torque? Anybody have a good way to do the upper rear control arms?
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno 559.92 RWHP 519 RWTQ |
04-20-2015, 10:26 PM | #65 |
Lets roll...
Drives: 14' Join Date: Jun 2014
Subn to this thread..
09-23-2015, 11:49 PM | #66 |
SS
this thread in my pocket training the local alignment shop
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
12-27-2015, 12:16 PM | #67 |
Drives: 2014 v6 manual Join Date: Oct 2015
Would it make sense to loose the applicable bolts then put a jack under the brake lift with jack to simulate load then retighten loosened bolts?
12-28-2015, 07:53 AM | #68 |
ZL1Naboz
All the instructions that I saw, indicated loosen the bolts and drive the car very slowly in order to settle the bushings. Tighten the bolts to spec with load on the suspension
02-15-2016, 09:33 AM | #69 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
What dhould be the alignment specs on a BMR (sp077) lowered SS when the bushings are timed?
03-08-2016, 01:36 PM | #70 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
I am about to install some bmr 1 inch bmr lowering springs on my car and I've called a couple of shops already asking if they do the timing of the bushings and none of them know what im talking about, all they say is that i just need the alignment of camber and toe and all that and they ask if what I'm trying to mean is the alignment, so does this "re-clocking" the bushings is the same as getting the alignment ?
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
Timing bushings | gtfitter597 | Suspension / Brakes / Chassis | 41 | 07-09-2014 11:02 AM |
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! | Apex Motorsports | Transmission / Driveline | 28 | 11-27-2010 10:46 AM |
clunking after bushings and lowering | rtkjadams | Suspension / Brakes / Chassis | 12 | 10-01-2010 10:56 AM |
Urethane Bushings from Energy Suspension | Bewenched | Suspension / Chassis / Brakes | 1 | 04-30-2010 05:12 AM |
