06-05-2017, 05:54 PM | #57 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Sent from my iPhone using Tapatalk |
06-05-2017, 06:07 PM | #58 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Kindness and compassion #OthersFirst |
06-05-2017, 06:24 PM | #59 |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
06-05-2017, 06:47 PM | #60 |
06-05-2017, 07:19 PM | #61 |
09-11-2017, 12:18 AM | #62 | |
I'm not 100% certain of the SS parts, the axles have different part numbers than the manual 2.0 or 3.6 axles. I THINK the SS has an electronic LSD, from what I've read? I know the manual 2.0 and 3.6 has a normal LSD. The SS has a diff cooler where as the 2.0 and 3.6 diff does not have a cooler, (but I SPECULATE the v6 1LE may have a diff cooler, could possible share the exact same diff as the SS? Speculation of course)... Just to keep it simple, the m6 2.0 and 3.6 diff and axles are larger than the a8, and are a direct swap. I'm guessing the SS stuff will swap in also, just need corresponding diff and axles. Sent from my iPhone using Tapatalk |
09-11-2017, 05:15 AM | #63 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
ELSD is only on the ZL1 and up models... Fairly certain the SS just has a 'normal dumb' diff.
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
09-12-2017, 06:35 PM | #64 | |
09-13-2017, 09:28 AM | #65 | |
09-13-2017, 07:53 PM | #66 | |
Theoretically, yes, if a guy had all the correct matching parts, anything would be possible. But any swap other than what's been documented may require more parts. For instance, I was able to swap my a8 diff pinion flange onto the m6 diff and not have to change the driveshaft. Not sure if that would still be true on an SS, zl1 or 1le diff. I would not consider an elsd diff without knowing how it's controlled, and how/if I can control it if it's swapped into a car that didn't have it. Until more gear sets are available, I say stick with the 3.27 ratio for an auto. The lower gears (especially first gear) is just too low already, and slapping a 3.73 diff would make first and possibly second basically unusable. Which is why I didn't opt for the SS diff swap. I don't r even know if I'd swap the 3.73 into a manual 2.0/3.6 car, as even the tr3160 first gear is pretty low already... If someone came out with a 3.42 or 3.55 MAYBE, but still pushing it. For drag racing the ratio can be fudged with tire size. With the height of my ghetto race wheels on the rear, it basically fudges my 3.27 ratio to something around a 3.64... Which may not even be optimal. Sent from my iPhone using Tapatalk |
09-15-2017, 02:31 PM | #67 | |
10-29-2017, 09:09 PM | #68 |
Drives: 2016 Camaro 2.0t Join Date: Jul 2017
[QUOTE=Jason@;9753933]The deed is done! I didn't have the time to do it myself with the new baby afoot, so I took everything to the local shop I take my cars to when I don't want to do something myself, or don't have time. I threw the axles and differential in the trunk and dropped it off at 8am this morning, not sure when they started it, but they called me at about 1:30 and said it was done. I asked one of the techs to take some pictures for you guys and got a couple worth sharing.
Diff out, not sure which axles are in... This shows the diff out still, but the new axles are installed Here is the new diff (left) shown next to the wimpy stock diff (right). New diff and axles installed. I can't say that I was the first one to do this swap. The ZZP boys beat me to it. I figured based on the part numbers in the Gm parts diagrams that all that was needed was the differential and axles, which if any of you have contemplated doing this type of swap in a 5th gen v6 cars, you'd know you'd also need to swap the hubs and sometimes the driveshaft, or the rear half of it, and sometimes the stock driveshaft would work fine. GM made it easy this time for us. The only extra step needed (Which I found out before hand thanks to the ZZP boys), is that you need to swap the pinion flange from the old stock rear end onto the new rear end for the stock drive shaft to bolt up. Aside from that, it's a straight up bolt in. You are welcome. That was my project. LOL |
10-30-2017, 11:28 AM | #69 |
Yeah yeah, took me almost a year of looking/searching off and on to finally find a diff at a junkyard. Someone had to be first to do it. Lucky you.
10-30-2017, 11:31 AM | #70 |
[QUOTE=Jason@;9957483]I got two units form bone yards that were supposed to be manuals that came from autos. I finally said piss on it and ordered one from a dealer.
