08-27-2016, 05:07 PM | #57 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-27-2016, 05:08 PM | #58 | |
08-27-2016, 07:10 PM | #59 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
That would be the safest setup in my opinion. |
08-30-2016, 11:40 AM | #60 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Being that it's harder than rubber, what did you splice it with? Or what style connector did you use? The hard line has gotta be at least 3/8 or 7/16ths right?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
08-30-2016, 01:02 PM | #61 |
Yes I cut it. its not too much harder than rubber. A pvc cutting tool is the best way. I think i showed the tool in the video. it is 3/8. I used a hose barb to splice the venturi valve to the can. they have them that have 2 different size barbs on each end. I will post a close up pic after work.
08-30-2016, 01:56 PM | #62 |
the clean and dirty side tubes are thin walled plastic-like. I used a dremel to cut mine.
They are completely annoying. |
08-30-2016, 03:29 PM | #63 | |
08-30-2016, 04:18 PM | #64 | |
On the clean side, i just cut the tube out completely to the connector barbs the stock system uses. I then used hose to stretch over that and clamped it. I dont know what I'll be doing on the dirty side since that tube is so big and I probably wont want to cut it all the way back to the barbs. Upside is, you dont need to worry about clamping down super tight. The pressure is negative so you only really need to make sure you are air tight. |
08-30-2016, 11:00 PM | #65 |
The dirty hose is easily and cleanly cut with a pvc cutter. You can get hose splicers that are 5/8'' on one barb and 3/8'' on the other. It is not visible in this picture but it is connecting the hard hose to the 3/8" rubber hose. The dirty air hose is the hose with the check valve in it, running away from the can. That hose is connecting to the stainless braided cable. I used stainless braided in visible areas, and rubber under the engine cover.
08-31-2016, 02:00 PM | #66 |
I should have a mishimoto universal 2 port can coming on friday along with hose, few couplers (3/8 to 3/8) and I picked up a couple reducers just in case (5/8 to 3/8). I went with the mishimoto can because it was only 20 bucks more than the prime cooling catch can which is 77 bucks but the mish has better filtration and likely still comes out shorter.
The can height was the biggest factor in deciding not to go all generic for this can like i did for the clean side (which has much more room). I'll be creating my own bracket to mount it. |
08-31-2016, 06:50 PM | #67 | |
Appreciate the tips from both of ya. I know on the lfx, the hose just slid over the hard lines. Guess it's ok to connect these with a brass adapter.
08-31-2016, 06:55 PM | #68 | |
09-02-2016, 11:38 AM | #69 | |
I ended up using 1/2 inch hose overall. That's inner diameter. It fits over all the stock barbs and stuff.
09-02-2016, 12:18 PM | #70 |
Looks good. I hope that the we folks here in this little subforum can improve performance over the lifespan of this engine. I'm glad to help always.
I am going to do a long trip soon so i will be checking the can for the first time after the trip. I will post the results.
