#6973 |
![]() ![]() ![]() Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
Yeah, that's Koenigsegg tech only at this point - though I do love the thought of infinitely variable valve events!
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT 1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
#6974 |
![]() ![]() ![]() ![]() Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
I don't care who's egg it belongs to, I just want it. And not just because it will deliver a much improved power band, it could also deliver a much improved emissions profile, which in turn, could extend the ICE for quite a bit longer.
#6975 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
#6976 | |
I do agree with your point though. Chevy is going with a traditional FPC arrangement (allegedly) and firing order, so it will have two separate throttle and intake systems, which helps this issue a bit too. So, there may not be a dramatic cliff in the torque curve like the Voodoo, the increase in torque may be more linear as it builds. And judging by how well Chevy has been at the performance aspect of their performance cars, this thing will be amazing. But make no mistake, any 5.5 N/A engine with a super high peak HP, will have less torque down low than the LT1/2 engines. |
#6977 | |||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
#6978 | |
Same as the other points - variable intake runner length can do a little, but the physics of a smaller displacement FPC capable of 8500+ rpm lend to high HP lower torque - as evidenced even with the exotics.
#6979 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#6980 | |
The LT1 puts out about 315 lbft of torqe at 1,000 RPMs. There is no way there will be that much torque down low for the 5.5L. Also, the LT1 puts out over 400 lbft (which is a touch more than the Ferrari at peak) at about 2,200 RPMs all the way up to max HP (at 6000 RPMs). That is a fat torque curve! That is why you have power available early on in the RPM range. Expect the 5.5L to have much lower torque numbers in the lower end of the rev range as compared, but it may have a similar peak number (but still might be lower), and it will build up to the peak at around 6k RPMs. |
#6981 | |
![]() Drives: Black Join Date: Jan 2017
You are also way underestimating it. It will literally reinvent the combustion and potentially set back electric cars by 20+ years. It is way way more incredible then your post is making it sound. Having full independent control of the valves to open and close whenever and however you want = the holy grail of combustion engines. A 5.5L camless v8 would make like 1000hp NA and get 60mpg on the highway, easily. |
#6982 | |
I was just saying to expect not much low-end torque from a 5.5L FPC engine with peak HP north of 8,500 RPMs, relatively speaking, of course. As said above, take a look at the characteristics of similar engines (like the 458) and extrapolate. |
#6983 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#6984 |
#6985 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I have to agree with the sentiment that whatever Ford does, GM will do much better. I do not think the Z06 engine will suffer the same failures that the Voodoo did. Although it may have the powerband features that are characteristic to these engines, it will not be an utter failure. And GM will probably find some awesome way of countering these issues. I'm not opposed to a NA V8 DOHC FPC if GM builds it even if my plans include trips to Mexico. But I would like to see how it performs against some actual Supercars. I'm done with seeing comparisons against GT500s and Hellcats. I wanna see some of these cars take on the elite classes of cars and see how they stack up even if they get destroyed. I saw a ZR1 vs the 720S and at no point in the race did the ZR1 stand a chance. And it was cool to see just how far off it is. Maybe it would have done better against the Aventador. And maybe it would have matched the 520S. But I couldn't care less about the Shelbys and how the Vette compares because it is obvious that the GT500 is only capable of beating cars with much less HP. Anyway, when the Z06 comes out I'll see what it does and how much it costs and if it is worth buying.
Incidentally, I can always pick up a stray C8 Z51 that might be sitting on a lot somewhere. Plenty of them will be available. And that might be the best bet as I'll be able to throw a blower on it if I want. So I would not say a C8 Stingray is completely out of the picture. More that I'm putting my next purchase on the back burner for now to see what happens with this virus. Plus like I said, if I take a contract for the next year or so, then I won't be able to enjoy anything anyway. |
#6986 |
I bet you wouldn't be seeing those numbers on a production camaro or mustang type of vehicle in the introduction phase of a camless engine or well after that. Perhaps boutique and hyper cars.
