Old 07-26-2013, 01:59 PM   #6735
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by PoorMansCamaro View Post
well, another possibility is the clean side getting blow by. I know there were a few people that had dry dirty side and oil in the clean side.
I thought of that but if I would have clean side Blow by at WOT then my throttle body and intake tube should have some oil residue in it but both my Throttle body and intake are as clean as a whistle. Which reminds me while at the fest i need to buy a recharge kit for my intake. Been meaning to buy one but cant justify paying 13 dollar shipping on a 15 dollar item :faceplam:
Old 07-26-2013, 01:59 PM   #6736
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Originally Posted by Monchy36 View Post
How I make sure? Checking if there's oil inside the intake?
you can take the throttle body off or just the intake tube and open the butterfly on the throttle body with your finger and look inside.
Old 07-26-2013, 02:00 PM   #6737
PoorMansCamaro
Drives: Really Slow
this is also true.
Old 07-26-2013, 02:00 PM   #6738
menendez1293
Yup. When i painted my intake and had it apart is when i found it. You just simply have to remove the plenum cover and throttle body to check though. It;s not really necessary to remove the whole intake unless you want to do a thorough cleaning.
Old 07-26-2013, 02:01 PM   #6739
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
I used to have both rx catch can and their breather. my breather also would get covered in oil. so I took it off.
Mmmm I have mine a year +, no noises, no soak breather cap... I might be lucky! But I'll be checking this since Im doing a oil change before Indy, I guess I'm coming back with a new catch can...
On mine, the breather became disconnected from the cap. It's just glued with RTV silicone. I figured some pressure built-up and popped it off (there's a check valve in the breather as well). I can understand a little oiliness due to oil vapors escaping from a hot engine, but a bunch running down the block- eh, not-so-much...
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 07-26-2013, 02:01 PM   #6740
menendez1293
I find it easier to just remove the 4 bolts that hold the TB. Because right after the throttle body is where the dip is on the manifold and it gets a little difficult to see it with the throttle body on the manifold.
Old 07-26-2013, 02:02 PM   #6741
menendez1293
The breather has never been a solid design. Heck they are just specture breathers that you can purchase at Autozone or advanced with a check valve. I didn't even know this till Lil' Nasty pointed it out to me.
Old 07-26-2013, 02:04 PM   #6742
PoorMansCamaro
Drives: Really Slow
yeah, either way. you should be able to stick your finger down through the throttle body, into the drop off.
Old 07-26-2013, 02:06 PM   #6743
pgustavson
pgustavson's Avatar
Yes, I know that as well. It pains me to think I spent $40 bucks for it when I could have modified my cap for less than half.
Old 07-26-2013, 02:07 PM   #6744
pgustavson
pgustavson's Avatar
It must be Friday, since that sounds like more fun than it should.
Old 07-26-2013, 02:08 PM   #6745
menendez1293
Yea i was considering their 1LE style separator until all the recent things went down. I think now I'm either gonna leave the clean side stock or get the GM 1LE separator. Not quite sire how to route the lines though.
Old 07-26-2013, 02:10 PM   #6746
PoorMansCamaro
Drives: Really Slow
i'm an asshole
http://www.camaro5.com/forums/showthread.php?t=309450
Old 07-26-2013, 02:10 PM   #6747
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
I'll definitely stick my finger down to feel if it's wet... I let you guys know!
Monchy36 is offline   Reply With Quote
Old 07-26-2013, 02:10 PM   #6748
PoorMansCamaro
Drives: Really Slow
