Old 01-24-2017, 03:43 PM   #631
laynlo15
Drives: 2022 Lt1 A10
Girly you need to be running slicks with the stick car. I think your car will react better then with the drag radial. It will be much easier on the drive train also. I know you've upgraded the drive train and that will help for sure with all your hp and torque.
Old 01-24-2017, 06:02 PM   #632
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Yup. for sure. but 10.9 and 134... I would guess that those DRs are spinning.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 01-24-2017, 07:44 PM   #633
laynlo15
I run the 28x10 hoosier slicks and that what I'll also run supercharged also. They will grow on the big end where a drag radial won't. I think that's one reason why my MPH NA on a few of my runs were the highest in class for my mods. I had one pass of 121.32, my only mod was CAI and drag pack (skinnies and slicks). I could hold mine in 4th where all the guys with drag radial would be hitting the limiter at 1100 feet or so. I may have to go to a wider slick if these don't hold my power when I'm done, but I think they will. I should be making about 600 rwhp when I head to the track in March. Expecting 10.80s or lower.
Old 01-24-2017, 08:57 PM   #634
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
No they aren't spinning at all. Stock coverter has us leaving at 2k rpm but peak trq is 4k. Basically we have about 1000rpm before boost then it sits back and goes.
We think we can get the converter to let us launch at 2800rpm or so by messing with the pressure at launch. We'll try and find out. Also gonna up the boost a little this time so long as afs stay good. Think we might get close to 140mph this outing.
Mainly we're getting data logs of the trans for circle d to build us the new converter. We're probably gonna end up with a 3500-4000 rpm stall converter and a ligenfelter box for pulling timing to get boost up on the line
Goertz is offline   Reply With Quote
Old 01-25-2017, 10:30 AM   #635
GirlyNFG
GirlyNFG's Avatar
Wouldn't 140 put you in the 9s?
I've been having a hellofa time launching mine. Best MPH has been 133 @10.8 with a 1.7 60. Hold 5000 RPM. Launch. Bog. Go.
Same day, 129 @10.8 with a 1.5 60. Only difference was the second pass I left at 3500 and no bog. I would of expected a 10.5-10.4 with the 133.x MPH... if it had left right.
PB: 9.569 @ 151.05
Old 01-25-2017, 11:20 AM   #636
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I'd like to know how this can be accomplished, I'm assuming something in the tune can be tweaked to make it happen?
Old 01-25-2017, 03:55 PM   #637
Fraxum
Fraxum's Avatar
Originally Posted by Merc View Post
Done for now. 3 hours of clicking and dragging and Google driving. I'm sure there will be some proofing it all, but that's it enough for one nite.
Thanks for all you do.
Old 01-27-2017, 11:48 PM   #638
Goertz
Goertz's Avatar
IOnly 1 hit tonight but was better than last time.
No changes in boost or anything, was just a cold night out (52*F on the track)
Got a gopro cam vid I'll post up when I get a chance
Car had 3/4 tank of 93 octane in it and has just driven 60miles to get to the track. Was very first hit one and done. Got our datalogs for Circle D to make the converter and packed it up and went home.
Weight with driver was 3995lbs
Track was Royal Purple Raceway Baytown Tx date 1/27/2017 and time we made the hit was 9:26pm
Old 01-28-2017, 12:57 AM   #639
Merc
In The Circle
Merc's Avatar
I need to see the whole time slip with track and date. Please delete that pic from the post and upload a new pic of the whole time slip. Please don't add a whole new post.
Old 01-28-2017, 07:07 AM   #640
Goertz
Goertz's Avatar
Done
Old 01-28-2017, 09:14 AM   #641
steelheadrob
Tactical Garage
steelheadrob's Avatar
Nice Pass Goertz!
Can't wait for this spring when all the tracks open back up to see what times all the SC & Turbo cars are making.
steelheadrob is offline   Reply With Quote
Old 01-29-2017, 07:33 AM   #642
Merc
In The Circle
Merc's Avatar
Updated!
Old 01-29-2017, 09:39 AM   #643
Goertz
Goertz's Avatar
My mph was 136.97 not 139
I would love to have 139 lol
Soon
Old 01-29-2017, 09:54 AM   #644
Merc
In The Circle
Merc's Avatar
Soon
Ill fix it later to night.
