View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier |
21 | 14.19% |
2017 |
54 | 36.49% |
2018 |
68 | 45.95% |
2019 |
2 | 1.35% |
2020 |
2 | 1.35% |
2021 |
1 | 0.68% |
Voters: 148. You may not vote on this poll |
Thread Tools |
#631 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Same here, pump and cam went in last week.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
#632 | |
![]() Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
![]() Thank you!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
#633 |
Yes, same here, mine didn't fail but as we will start with mods soon seems time to do the change...
#634 |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
You guys putting in the Katech pump are taking a pretty big financial gamble if anything ever goes wrong with your engine.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#635 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
As long as they are out of warrantee, the gamble is not bigger than with the replacement GM pump. If either fail, you are footing the bill for an engine rebuilt either way.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#636 | |
Previously CS10SS
Drives: 2017 ZL1 A10 Join Date: Jan 2017
IMO... Modifying cars is a calculated gamble, always has... always will be. I'm willing to take the risk.
'02 Trans AM - sold
'05 SRT4 - sold '05 STI - sold '96 300ZX - sold '10 2SS/RS M6 455rwhp - sold '13 ZL1 M6 720rwhp - sold '17 ZL1 A10 930rwhp - Katech Built |
#637 | |
Previously CS10SS
'02 Trans AM - sold
#638 | |
#639 |
Oil pump is confirmed bad, getting replaced, they don't suspect any engine damage at this time, but they did jot down a note of hearing a tick, but they will not dig anyfurther into the noise until after replacing the bad pump. 4-5 days for parts. Should be getting worked on Tuesday or Wednesday. Anyone have any other recommendation or things I should bring up?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
#640 |
![]() ![]() ![]() Drives: 2018 ZL1 1LE and 1991 Z28 Join Date: Jan 2009
Sorry but this thread is way too long to read in its entirety so i just scanned through a bunch of pages.
So let me get this straight, GM still has not issued a TSB to pre-emptively fix this problem and if you still have a factory warranty, replacing the oil pump with a katech or other aftermarket brand will essentially void your warranty? So essentially we just have to sit and wait to see if it fails on you and if it does fail and you're still under warranty GM will fix it?
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2016 Audi A6 Prestige Supercharged 3.0 V6 // 2002 Camaro SS (sold)
#641 | |
Modifications
#642 |
At least they should check your crank and rod bearings while the oil pan is off.
2018 Camaro ZL1 A10
#643 |
I'll mention it when I pickup my loaner today. Thanks!
Modifications
#644 |
If they check it, make sure they are using new bolts also.
2018 Camaro ZL1 A10
