#6399 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#6400 | |
At the strip the gt500 should win almost all the time.
#6401 | |
#6402 |
![]() Drives: 22 ZL1, 20 Taco, 20 Cayenne S Join Date: Oct 2019
#6403 | |
There's no denying that the gt500 won by a good .3 margin every time. At least 2 cars lengths maybemore. What I find funny is the same people that are celebrating this gapping by a more powerful car are a lot of the same people that will tell you the .3 gap the m6 ss puts on an m6 GT is a drivers race lol between cars of more or less the same power.
#6404 |
![]() ![]() ![]() Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
I just don't see any ZL1 besting the GT500 side by side unless there is an error or failure of some kind for the GT500. It's simply the faster car in a straight line as it should be some 5 years later, additional 110hp, and DCT (can't get over that terrible Ram 1500 gear selector to this day).
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT 1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
#6405 |
I mostly stick to this one and fb. This is definately better than YouTube comments lol.
#6406 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
It depends on the Camaro, the level of performance, and the price of the competition. The ZL1 was already in that price range and I thought it was a great value based on the price of the Z06 and the fact that the ZL1 had tons of standard features.
#6407 | ||
The GT500 is affected by conditions more so than the ZL1. It isn't about defying physics. We have already seen it. Ford claims 10.7 on a prepped track in optimal conditions. Usually when a Mustang runs we hear "oh well if the DA was better" or "well in cooler late year temps" and similar comments all alluding to the fact that if it is run in better conditions then it will do much better. And it has done that. Remove those conditions and it is an 11.3-11.5 sec car as we have seen. The ZL1 regardless of conditions (not conditions like rain in case someone wants to be a smartass) has maintained mid 11s in testing. In those runs we often are not told what the DA or temps were. And it is not often on a prepped track from what I understand although I could be wrong on that point. In any case we have typically seen it run 11.3 to 11.6 with even the M6 equipped versions running 11.6-11.8 I believe. So we are seeing around a 7-9 tenths difference with the GT500. Some are even saying the 500 could run 10.4s bone stock which would be a 1.1 sec difference all based on conditions. With the ZL1 we are seeing more of a 2-4 tenths difference. The testing we are discussing now showed 11.3 (GT500) and 11.6 (ZL1). Now if you were to put both cars on a prepped track and run them in optimal conditions then apparently you could shave almost a full second off the 500 based on claims of 10.4 to 10.6. With the ZL1 it might be more around 3-4 tenths. Now this is open to debate. But when a pro runs a 10.6 and then a kid who claims to have never driven on a track before runs 10.6 both on prepped tracks...but other pro-level drivers on an unprepped track and in hotter climates run 11.5 (all Base 500s), then that kinda proves the point. We are seeing much wider ranges in GT500 times as opposed to ZL1 times. (See the comment I quoted from shaffe who typically disagrees with me). Now I hate trying to explain things to Mustang guys because all you guys do is troll. But I am not saying that the GT500 is not the faster car. I am saying that if it is not in conditions that are to it's advantage, then it will suffer. The ZL1 in those same conditions will not be affected as largely. Again, see the examples above. Also of note is that on an unprepped track the C8 (not a Camaro of course) was able to run faster than the GT500. 11.1 (CF) to 11.3 (CF 500) and 11.5 (Base 500). It isn't about defying physics. Rather, physics would explain why this happens. |
#6408 | |
![]() Drives: 2011 Camaro SS, 2013 Mustang GT Join Date: Dec 2019
Related question about the whole un-prepped/prepped surface thing that comes up a ton. Where else but a drag strip can you get a 1/4 time for you car? Saying "ran the 1/4 on an un-prepped surface" doesn't make any sense because where else are you going to run the quarter mile? I mean you're at the drag strip to begin with to get the best time out of the car you came there with so I'm a bit confused about that whole line. At the drag strip there is never an un-prepped surface, you're at a drag strip. And on the street there is no tree with time traps... ![]() ------ Also to pepper in something else, talking about times on these cars that have automatically shifting transmissions can't you just take any driver skill out of the conversations? All you really have to do is keep your hands on the steering wheel. So saying "pro-driver" in an automatic car that does all the works sounds a bit off, nah mean jelly bean? What can one driver in an automatic possibly do that a trained monkey can't do? hold the steering wheel straighter? |
#6409 |
#6410 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
I could completely understand that line of thinking but not me, because all out performance isn't the determining factor to me. I have said numerous times here I wouldn't care if the camaro/mustang/challenger was faster then a vette at same price point. That is more to just having a love for Corvettes. Maybe after owning one my mindset would change lol, but a Corvette has long been a dream car of mine.
#6411 | |
https://www.mustang6g.com/forums/thr...ro-zl1.134714/ |
#6412 | |
I think it makes universal sense for internet arguments, but I see nobody has brought it up. And like I said I don't frequent there. |
