Old 10-03-2025, 08:08 AM   #603
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Update: It's official, I wired the money to Katech and moving forward with the build, no going back now! The build hasn't changed, since earlier (see below). Mike will using the existing pulley setup, 2.3" & 9.45" and get the baseline Dyno. From my understanding, after the build's completed. They will tune/Dyno with the existing 2.3" & 9.45", then pop the 9.6" lower on and tune/Dyno and see which works best out of the two combos. Mike will let me know the results and then we'll decide which combo to leave on the car!
So, after Jax Wax Street Madness drag racing this Saturday. I'll be taking the car up to Katech mid/end of October/first part of November. I got some really good feed back form Joshinator99, radz28, RobZL1, Gabe, King and many others. I realize this build could push the car to the edge of street driving and enjoyability. But, I mostly drive to/from Car's and Coffee, Car Shows, and racing. My car was and never will be a daily, so I think being on the edge will be ok. Maybe after I get the car back and start driving and enjoying it for next summer, fall may be the time I add the Maggie if I feel something needs to change with the build etc. !!!
Build as planned:
Katech Track Day CAM
BTR Dual Value Spring Kit
Katech/Johnson Drop in Lifters
GM Lifter Trays
Trend 3/8 Chromoly Pushrods
Katech VVT Delete Front Cover
CNC Port Cylinder Heads
Competition Valve Job
Hand Blending
Competition Cylinder Head Assembly
GM LT4 Head Gaskets
ARP Head Studs
DSX 9.60" Lower Pulley
Gates HD Green Belt to Proper Length
Katech AFM Delete Valley Cover
GM LS Style Front Crankshaft Seal
GM Crankshaft Bolt
Katech C5-R Timing Chain
Katech Timing Chain Guide
Katech Oil Pump / Billet Wet Sump
DSX Aux Pump Kit
Fragola Fuel Tank Fitting
Brisk Racing Plugs
Coolant, Brake Fluid, Oil & Filter
Gen-V Dyno Tuning including TCU Tuning and Street Tuning
Installation / Build
Build looks great! I have one complaint if I may: the DSX Aux pump does not belong on any car, period. Puncturing the fuel tank below the fuel line is a bad idea and not safe. Furthermore that tank was never designed to be tapped and threaded, and is not thick enough to properly seal an NPT thread. But OEMs never puncture a tank below the fuel lines for fire safety reasons so I’d highly suggest you do something different on a nice build. Both Katech and DSX make proper in tank solutions as does Fore so I’d recommend going with one of those options.
Old 10-03-2025, 09:22 AM   #604
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Good point. Should I request replacing the current Katech Dual Drop-in fuel pump be replaced with a pump capable for handling over the 900rwhp their dual pump is rated for? What pump would that be?
Thanks!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 10-03-2025, 09:43 AM   #605
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Thanks!
Ask them to put an additional bulkhead in the existing dual drop-in pump's hat, and run a hose down to the bottom with some holley hydramat and magnets on the outside of the tank to hold it in place.
Scroll through the pics here for an example of this.
This could be a nice option for their in-tank pump, in general, for higher hp builds if they aren't going to run the bigger Ti 285 or 295 Hellcat pumps.
Mods being installed-
Old 10-03-2025, 11:23 AM   #606
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Congrats on pulling the trigger, can’t wait to see the results! Super excited for you man! Gonna be a blast once Katech is done with it. I did notice the Fragola fuel tank fitting on your parts list, so it looks like they might be using a proper bulkhead fitting instead of tapping directly into the thin plastic wall of the tank. That setup should be a lot cleaner and safer.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 10-03-2025, 12:15 PM   #607
2023_ZL1-AUTO
Big RobZL1 and swisstyphoon: BINGO !!!! There are tapping it correctly!
Old 10-03-2025, 01:57 PM   #608
Joshinator99
Moderator
Still below the tank fuel level FYI… so it does fix one problem but not the main one.
Old 10-03-2025, 02:34 PM   #609
2023_ZL1-AUTO
I see and get it... I sent this along that RobZL1 posted above:
https://almperformanceanddesign.squa...p-w-aux-pickup
Old 10-03-2025, 03:54 PM   #610
Joshinator99
Moderator
Old 10-04-2025, 12:00 AM   #611
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Here's my unsolicited opinion, Scott. I'd say do whatever the heck makes you the happiest. We aren't out there aiming to break Jason Leiva's records, rather just building cool cars that make us happy on the weekend, at the strip, and at the cars and coffee. Cam or no cam, 2650 or 1740, meth or no meth, chiller or no chiller, it's all good in my book. Many people have had success with all manner of combinations of parts. So I say, choose what makes sense to you (that Katech also says will work), stroke the check, and watch your grin get bigger when you get the car back.
Well said my friend, well said!
Old 10-04-2025, 12:02 AM   #612
SOCAL.M6.ZLE
Originally Posted by clg82 View Post
I can't hear myself think with the new pulley and DSX lid I added to the magnuson with the amount whine lol....hell it sounds like my wife is driving with me every time........if you already got a shitload of money into the lil guy and aren't going to be able to recoup that cash going the Maggie route than stick with it....just know there are 1,000 different ways (as others have already stated) to achieve what you want besides what Katech says. Sure their a good shop but their looking at their invoice.....and your card number....as are all businesses as they should....before they are YOUR end goals!
I call BS until we get a video!!!
Old 10-04-2025, 12:05 AM   #613
SOCAL.M6.ZLE
arpad_m & RobZL1 ! Thanks for the input and yes, always having a grin is important !!!
clg82 - Good points I agree and I get it I feel that Katech advises me well. They also listen well, to what I keep saying I want, I want ot change and what end result I'm looking for. In fact I've run Mike through the ringer, I just courted up the build quotes he's sent me since May and I'm on #9 for how many times I've changed my mind of things! I know Katech is a big price tag, but, I'm ok with that. Also, I realize the factory blower is being pushed to it's max effort. But, yep, how loud the whine is, it's crazy loud! But, also CRAZY AWESOME! I love it, I love that people can hear me driving down the street, and know that must be "Scott"! It's kind of something I actually prefer. But, to be clear, Katech originally suggested the Maggie for my build, but, like Gabe, I really like the factory blower being max out and the with the x-ported and the lid and the whine. I'll update if I change the build obviously! Thanks again !!!
You forgot, the smile you get every time we are on the phone while your driving a you hear me say.... "holy sh*t that think is loud" ... it is literally impossible to have a conversation with how loud that damn blower is
Old 10-04-2025, 12:12 AM   #614
SOCAL.M6.ZLE
Build as planned:
GM Lifter Trays
Hand Blending
GM LT4 Head Gaskets
ARP Head Studs
GM Crankshaft Bolt
DSX Aux Pump Kit
Brisk Racing Plugs
Damn it, SCOTT... this is terrible news !?!?!?!
That means I will only be making more power than you for like 2 damn months??? that's BS.
On second thought.... challenge accepted
Congrats my friend... I wanna video of your smile ear to ear, the first time you drive her.... this is going to be AWESOME!!!
Cheers to building whatever the fu*k you want...
Old 10-04-2025, 07:28 AM   #615
2023_ZL1-AUTO
YEEEEEESSSSSSSSS !!!!!!! YOU ARE SO RIGHT !!!! It's funny, every time we are on the phone and I'm driving the ZL1, you are like : Is that your supercharger !!!
:laughabove :
Old 10-04-2025, 07:30 AM   #616
2023_ZL1-AUTO
You are my greatest inspiration bro !!! I keep climbing, because you keep pushing !!!
