Old 01-08-2017, 05:42 PM   #603
Snowblind
Snowblind's Avatar
Nice pass HyperblueSS
Old 01-08-2017, 07:46 PM   #604
HyperblueSS
HyperblueSS's Avatar
Drives: 2016 Camaro SS M6
Originally Posted by PRAY View Post
Well damn homie. Go on with your bad ass self. Good job rowing gears bro. Congrats.
Thanks!!
2016 Hyperblue 1SS M6
"If you're not first you're last!"
HyperblueSS is offline   Reply With Quote
Old 01-08-2017, 07:46 PM   #605
HyperblueSS
Thanks!!
Old 01-08-2017, 10:27 PM   #606
laynlo15
Drives: 2022 Lt1 A10
Great pass. Should put you way up on the board for M6
Old 01-09-2017, 10:22 AM   #607
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
I'd kill for some negative DA... Nice run.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 01-09-2017, 04:42 PM   #608
RacerX661
Drives: 16 1SS 6mt
Originally Posted by Merc View Post
Your pic of the timeslip does not make the grade to post your time. Refer to post #1 of this thread on how to post you time slip properly.
updated! thanks!
Tires used on the pass:Stock
Performance Mods (if any):None!
Category submitted for: (1) BONE STOCK 2016+ CAMARO SS LT-1 M6
R/T. .231
60' 2.062
330' 5.442
660' 8.126
660’ mph 92.32
1000' 10.418
1320' 12.364
1320’ mph 116.13
Name of the track: Wild Horse Raceway AZ
Date of pass: 12-02-16
RacerX661 is offline   Reply With Quote
Old 01-14-2017, 01:19 PM   #609
Merc
In The Circle
Merc's Avatar
Updated!
Old 01-14-2017, 08:54 PM   #610
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
Here's ours from just today.
Not the fastest time but I think we are pretty decent with the mph.
Setup
100% stock engine/fuel system
Rear Mount Single S475 (cast wheel, 96mm turbine 1.32ar) Turbo Kit @ 10lbs
Direct Port Meth Injection for just a touch more fuel cause stock system was tapping out at 590whp 600trq. We managed to get to 638whp 614wtrq with the meth, was going to bump the boost as long as afrs were staying good at the track but my 10 year old wideband controller died on me so no go there...
mt tires et steet r 305/45/17 rear 27.5/4/17 fronts all radials
Our 60ft we weren't up in our power launching the a8 at 2000rpm but our trq hits at 4000rpm with the turbo. Gonna start looking into either a 3000-3500rpm stall converter or a 50shot of no2 to get it out the hole a bit faster.
run 1 was 5lbs boost
videos
All the videos
Run 1 11.6
(my dad doesn't know how to read that time board haha)
Run 2 11.02
Run 3 10.98
Run 4 10.98 backup
Goertz is offline   Reply With Quote
Old 01-14-2017, 09:32 PM   #611
laynlo15
More to come. Great outing for sure.
Old 01-14-2017, 10:30 PM   #612
HyperblueSS
Damn 10.9 with a 1.9 60 ft that's not bad...drop that 60 ft and it'll be mid to low 10s.
Old 01-15-2017, 08:00 PM   #613
jeportera
jeportera's Avatar
Drives: 2016 Camaro SS A8
Category submitted for: (1) BONE STOCK 2016+ CAMARO SS A8
R/T. 2.02
60' 1.836
330' 5.189
660' 7.902
660’ mph 91.05
1000' n/a
1320' 12.195
1320’ mph 114.02
Name of the track: Montgomery Motorsports Park, AL
Date of pass: 1-15-17
Slip is on the left.
jeportera is offline   Reply With Quote
Old 01-18-2017, 11:34 AM   #614
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Code:
Tires used on the pass:         (bone stock) Stock G2 F1 Supercar rubber on stock rims
Performance Mods (if any):      none
Category submitted for:         Bone Stock 2017+ ZL1 M6
R/T..........                   .3027
60'.............                2.1533
330'...........                 5.4614
660'...........                 8.0642
660’ mph...                     94.95
1000'..........
1320'..........                 12.1573
1320’ mph…                      118.99
Name of the track:              Coastal Plains Dragway
Date of pass:                   Jan 8 2017
Weather conditions:             low to mid 50s on this run, sunny, NE wind 10mph (head), storm front approaching (DA: -940 ft. | Rel Density: 102.78 %)
Driver experience: Low - 3rd time at any drag strip, 1st time since 2014. 1st time with 6th Gen ZL1.
Car #16:
Last edited by cwebster; 01-20-2017 at 10:44 AM. Reason: Forgot to highlight date and times on time slip
cwebster is offline   Reply With Quote
Old 01-18-2017, 06:26 PM   #615
wnta1ss
Drives: 2017 Camaro 1SS
Congratulations cwebster, for posting the first stock Gen6 ZL1 dragstrip time on the list.
Old 01-18-2017, 07:31 PM   #616
trz174
trz174's Avatar
Drives: .
Here's my best 17 ZL1 M6 time after a few runs. The manual is quite difficult to hook up and the 60ft is the key. There are 2000 miles on the car. The SGMP track surface was great just like always - so no excuses there. I think there is an 11.7-11.8 in bone stock trim when I get my act together. Pretty sure an 11.5-11.6 with DRs.
Tires used on the pass: Stock front and rear that came on the car
Performance Mods (if any): None, no mods of any kind
Category submitted for: 2017 ZL1 Bone Stock M6
R/T.......... -.095
60'............. 2.077
330'........... 5.383
660'........... 7.999
660’ mph... 94.60
1000'.......... 10.211
1320'.......... 12.075
1320’ mph… 119.79
Name of the track: South Georgia Motorsports Park, Georgia
Date of pass: December 16, 2016, 6:35 PM
Weather conditions: DA from Drag Times (5:58 PM) + 254
Tire Pressure: 40 PSI Front; 22 PSI Rear
trz174 is offline   Reply With Quote
