View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 09-17-2020, 11:11 AM   #575
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by LT4Greg View Post
My plan is to keep my ZL1 stock and not do any mods. It seems to have more than enough hp for my driving habits and I need to get it paid off too!
Same with me, I have a full year left on the original bumper to bumper and added another 4 years of the platinum extended warranty. I really think its limited issue. Most people join the forum after they have a issue, there are tons of owners with zero issues. At least I hope so.
pauly1119 is offline   Reply With Quote
Old 09-17-2020, 11:48 AM   #576
IneedAZ
IneedAZ's Avatar
Originally when i bought the car 3 years ago i had thought the same about leaving it stock, but now i figure unless there is an unforeseen event, i will keep the car for at least a decade so why not make it how i want. With 14k miles on it, it still looks like it is brand new.
Old 09-17-2020, 02:37 PM   #577
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
It will be interesting to see if any ZL1`s with suspect pumps make it to six figure mileage without issue. A fairly small but certainly not insignificant number of failures are happening pretty early on.
If it's truly a design flaw it's probably a ticking time bomb. Most of these cars are still low miles (<30-40k). Hopefully 2019+ in the clear
ZX-10R is offline   Reply With Quote
Old 09-17-2020, 07:25 PM   #578
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
5/18 build date with 5500 miles. Hopefully, mine doesn't have the bad pump
SSallday is offline   Reply With Quote
Old 09-17-2020, 07:47 PM   #579
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Im 6/18 with 3700 miles hoping the same. I think 2019 production builds started 8/18.
Old 09-18-2020, 09:43 AM   #580
SSallday
SSallday's Avatar
I think we should be ok. Most failures occurred in cars that were produced in 2017. I think there was only one with a build date from 4/18, which would mean that there’s a very slim chance that we would have a failure
Old 10-05-2020, 04:31 PM   #581
Katech_Mike
Drives: 2015 Camaro ZL1
The wait for a solution is finally over.
https://store.katechengines.com/gen-...pump-p918.aspx
Katech_Mike is offline   Reply With Quote
Old 10-05-2020, 05:01 PM   #582
Mark R
Drives: 2018 ZL-1
Interesting. However, it says it may (will?) require tuning, so for stock cars, this might not be a good solution.
Thanks for posting.
Old 10-05-2020, 05:08 PM   #583
Katech_Mike
Thanks for posting.
It requires no tuning if you use a car pump in a car. If you try to use a truck pump in a car it will require tuning as the truck pump is higher pressure.
I've edited the wording on the website. Hope this clears it up.
Old 10-05-2020, 05:14 PM   #584
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Nice! Glad there's an option out there now.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-05-2020, 08:41 PM   #585
EvilZL
EvilZL's Avatar
Drives: 2018 Camaro ZL1
Sweet!!
EvilZL is offline   Reply With Quote
Old 10-06-2020, 02:57 AM   #586
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Nice! Just in time for my winter project...
Can you give us some more details about the pump.
I'm assuming that the weak points of the failing stock pumps have been changed. Do whe know which internal parts were the problem?
Any other benefits using your pump over the newest one from GM?
Are some of your pre production units already running, and tested for a while?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 10-06-2020, 10:07 AM   #587
Katech_Mike
The powdered metal rotor housing is what breaks as shown in multiple posts in this thread. The size of the housing is reduced near the locating pin which is the failure point on every single pump. We have eliminated that piece and replaced it with a 4140 billet steel piece along with other internal updates.
The newest GM pump is not a fix. The rotor housing is still powdered metal and is easily broken with minimal force.
We've been developing this pump for months and have beat the heck out of it on the dyno with countless hours of track simulation without a failure. We have pumps going into cars in house as we speak.
Old 10-06-2020, 10:45 AM   #588
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
We need a side by side.. what breaks and the fix.
ing for grip.
http://www.motorsportsne.com/
