View Poll Results: What do you think of the style of the 2015 Mustang?
Really like it. 62 21.99%
Undecided, but leaning positive. 80 28.37%
Undecided, but leaning negative. 69 24.47%
Don't like it at all. 71 25.18%
Voters: 282. You may not vote on this poll
Old 12-07-2013, 08:28 PM   #575
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
Originally Posted by King T View Post
[IMG]http://farm8.staticflickr.com/7327/11257912974_b7b9fb7dfd_o.jpg
[IMG]http://farm4.staticflickr.com/3703/11257314735_629e6c4a90_o.jpg
[IMG]http://farm4.staticflickr.com/3775/11257826503_20e8d5e17a_o.jpg
That looks much, much better. Wow. The rear with that body color valance has an almost exotic look. They should all be like that.
trademaster is offline   Reply With Quote
Old 12-07-2013, 08:30 PM   #576
King T
King T's Avatar
Drives: 2010 2SS, 2011 Buick Regal Turbo
Originally Posted by Firefighter View Post
I think this article has the most realistic info yet.
They predict + 20/10 from the Coyote, reasonable.
True. That would put the 5.0 at 440hp. Enough to be ahead of the 2014-2015 Camaro SS. Now when the 2016 Camaro comes with the LT1 at 450hp (maybe?), then the 5.0 will get a bump again in hp to probably 470hp. Just enough to stay ahead...
King T is offline   Reply With Quote
Old 12-07-2013, 09:57 PM   #577
TheReaper
TheReaper's Avatar
Drives: 2018 Mustang GT
I like the way you think.
TheReaper is offline   Reply With Quote
Old 12-07-2013, 10:18 PM   #578
72MachOne99GT
Anthrax Popcorn User
72MachOne99GT's Avatar
Drives: 2013 GT500
Originally Posted by NVmyZL1 View Post
Open your center armrest console.
I snorted when I read this.
I have actually used it to charge...pretty poorly I might add.
What can I even use it for? I dont have the EP.
2013 GT500
1999 GT- sold
1972 Mach 1- sold
...if you want to compare performance numbers, well, the GT500 retains it's title of the highest hp, worst performing car in the world.
72MachOne99GT is offline   Reply With Quote
Old 12-07-2013, 10:28 PM   #579
ford20
Drives: Boss 302
Something else that stood out to me other than it probably gained 100lbs is the fact that they still refuse to put wide tires under the Mustang and when they upgrade brakes they only mentioned the fronts getting Brembos. Does that mean they are going to keep up with the asinine tradition of keeping the same single piston floating caliper in the rear whether it be the base 6 cylinder (or 4 cylinder) or the bad assed GT5000000 or whatever the hell they plan to call it...
There are already SVT mules running around with 11's up front and 13's in the rear. Wide rubber really won't be an issue with this car. Not to mention the rear brakes really aren't that big of an issue.
ford20 is offline   Reply With Quote
Old 12-07-2013, 10:34 PM   #580
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Yes. Why is it asinine again?
Never mind that there is no way a single piston floating caliper can put perform a 4 piston fixed caliper Brembo it looks like crap to boot.
The Mustang going back as far as I can remember (at least the late 70's) has always skimped on suspension/brakes/wheels/tires. At least now they are making a concerted effort to get a suspension under the car but they still (from reading this article) are skimping on brakes, wheels and tires.
It makes no difference to me I have a 1LE with ZL1 brakes on it. So my car has paid attention to all of the above aspects of a performance vehicle. I'll add power to my liking.
Firefighter is offline   Reply With Quote
Old 12-07-2013, 10:37 PM   #581
Firefighter
It just dawned on me you have a ZL1 and a GT500 (good for you, seriously I'm a little jealous) which car stops better and more times. Everything I have read says your ZL1 does.
Old 12-07-2013, 10:39 PM   #582
Firefighter
Rear brakes aren't much of an issue if you only go 1/4 mile at a time. If you want to Road Course they need to be a little better.
I'm glad the new one can fit bigger tires. The current always seems to have trouble fitting bigger tires. Well that's what the local Mustang guys have told me at least.
Old 12-07-2013, 10:43 PM   #583
Q'smuscle
Drives: 2011 Camaro VR 2SS/RS & Impala
Huh? When did the 14 - 15 camaro ss come with more horsepower than the 10-13 ? Did I miss something?
Q'smuscle is offline   Reply With Quote
Old 12-08-2013, 12:14 AM   #584
Q'smuscle
Had a ZL1. I sold it a little while ago. I did run both cars on the same tracks, primarily Barber and Road Atlanta, and neither both cars performed great at those venues and braking was never an issue at any point.
I agree that Brembos on the rear look better, but in my experience, they really don't make any significant difference from a braking standpoint. I think if you read the press on the new Mustang, you will see it has an improved suspension and the GT is getting 6 piston Brembos and bigger discs all the way around.
As for tires, I ran a 19x9.5 wheel with a 265/30 tire on the front and 19x11 wheels in the rear mounted with 305/30's on my former Boss and have that same setup on my GT500 with no issues. If Ford chooses to run a narrower tire setup from the factory, I'm sure they have their reasons, but it's not because they can't fit them on the car.
Ahhh... Nobody waved?
Old 12-08-2013, 12:47 AM   #585
King T
King T's Avatar
No the '14-'15 Camaro doesn't have more power. I was just comparing the refreshed years because they will be the ones around the same time the 2015 Mustang comes out. But yes the '10-'15 Camaro SS all have 426hp.
Old 12-08-2013, 06:28 AM   #586
newmoon
newmoon's Avatar
Drives: 2019 GT350
Will it still be considered "skimping" when this car is showing it's tail lights to the SS in every racing venue out there, just curious.
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 12-08-2013, 07:33 AM   #587
Firefighter
That remains to be seen. As it is all the Mustang wins, are races that have no turns in them. Even then it is usually up to the driver.
Listen this Mustang will be nice but it's fatter than it was and it didn't gain much power and it's still weak on TQ. The looks are subjective too.
So until it actually wins a race don't be so smug.
You act like this is 2002 and Camaro production has stopped, and it won't get any better. You know it's just a matter of time until an LT1 is sitting between the fenders of an SS albeit will most likely be a 6th Gen.
When the next Camaro debuts I'm confident it will head in the right direction in more categories.
Sent from my DROID RAZR HD using Tapatalk
Old 12-08-2013, 09:19 AM   #588
*007
Drives: Getaway Special
Originally Posted by LostPony View Post
I agree. It may make more later but I don't see Ford unleashing everything until they see what the Camaro does in 6gen form.
I would tend to disagree. Ford likes to pre-empt GM on these things. I would not be surprised to even see a Boss "352" version that equates to what the new Z/28 does on a track along with the carbon ceramics rotors and all the other goodies.
And, possibly even a drag race specific "package"...
We shall see. The new Stang looks better than the old one, a little more progressive, and if the quality is built in, and not just cosmetics, it could give a Gen 6 a run for the money regarding front page news.
I hope and suspect GM is preparing well. It would be good to see some Camaro Disciples comment on this!!
Sip:
*007 is offline   Reply With Quote
