Old 03-02-2021, 09:48 AM   #561
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
I think I hit full throttle once. The PDR video briefly flashes 70mph as I’m approaching the little slalom on the dirty run. I think there was a little wheel spin contributing to that. The car puts down power really well. Hard to do any kind of tuning on tiny courses like this, I’ll probably tweak on it more once I get it out to a big lot.
rotis is offline   Reply With Quote
Old 03-06-2021, 04:46 PM   #562
Cjw
Drives: 370z, Srt-6
My zle should be here next week, plan on ordering a set of apex sm10’s with the 18/11 and 12 wheels. What are the current cam guys running for tires? 315 square Yokohama or falkens? I’ve read some good things on these vs 315/335 rivals, I ran the rivals once on my 370 and had delamination so I’m hesitant on this car. I’ve ready some decent reviews of a nankang but until i see people running them at nationals I’ll hold off.. thoughts from current autocross guys using these?
Cjw is offline   Reply With Quote
Old 03-06-2021, 09:24 PM   #563
Clam
Clam's Avatar
Drives: 2017 Camaro 1SS
I am currently running 295/30/18 Yokohama A052 on 18x10.5 wheels square and like them a lot because they put the power down well and are very consistent. I plan to upgrade to 315/30/18 Yokohama A052 on 18x12 square in two months when my new wheels come in. I had 305/30/19 Rival 1.5S previously, and did not like them as they required a lot of heat to work, didn’t put power down that well, and were scary in the wet.
Clam is offline   Reply With Quote
Old 03-08-2021, 12:46 PM   #564
Cjw
Drives: 370z, Srt-6
Good to know, I’ll probably stick with 315’s square Yokohama’s , just gotta do some research and see if 11.5” front will fit without any big issues. Thanks for the info,
Old 03-08-2021, 12:52 PM   #565
AustinTXracer
Drives: 20 SS 1LE
My 2nd weekend on the Falken RT660's and another PAX win. This time also taking FTD. All stock SS1LE with alignment, 275/30R19 Fronts, 305/30R19 rears. The course is hard to look at due to a literal sea of cones, but it rewarded bravery and threading a needle that was hard to see through all the visuals of the course.
https://youtu.be/rhmecrZMlII
John Hale
multi time solo nats runner up :(
AustinTXracer is offline   Reply With Quote
Old 03-08-2021, 01:42 PM   #566
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
That track looked tight with those 2 180's in it. But the front end grip of your car looked Incredible! That thing didn't push anywhere it seemed. Also I think the mph of your recorder is a tad off. 78mph in 2nd gear?
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 03-08-2021, 02:04 PM   #567
rotis
rotis's Avatar
Wow, talk about sea of cones.
What was the temperature? I think we've discovered locally that the RT660 can't hold a candle to the A052 when it's wet and 45deg. It also seemed to be off the pace of older RE71Rs, I suspect the optimal temperature range of the RT660 is just a bit higher than the old 'stones.
Old 03-08-2021, 02:28 PM   #568
clyde
clyde's Avatar
Drives: broken
Those visuals. Yikes!
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
Old 03-08-2021, 03:42 PM   #569
AustinTXracer
Drives: 20 SS 1LE
When you DNF while walking the course... :P
Temps in the 60's. Yoks would still definitely be better I think, but I'm sticking to 19's until I feel like BS is a waste of time. I switched directly from RE71 to RT660, and for this car I believe the Falkens are faster. Still have to try the Nankang at some point.
Car goes 79 in 2nd gear, so it's accurate. Minus @2MPH for the 19" tires, though.
John Hale
Old 03-08-2021, 05:44 PM   #570
joelster
joelster's Avatar
Weird that they would gear the 6th gen 1LE higher than my 5th gen Z/28. I know my engine can rev a little higher, but I don't think I could go 78 in 2nd, even at 7000rpm. I never did the math though, but little peeks at the speedo here and there at the bigger Auto-X places I run at will see 72-74.
1979 Y84 Trans Am
1986 IROC-Z
Old 03-15-2021, 03:35 PM   #571
AustinTXracer
Drives: 20 SS 1LE
Here's a different view of COTA - behind the garages in paddock :P They are using the main lot for vaccination queues so they let us have a different lot. Slow course and several safety related concerns but no drama in the end. Finished 6th in PAX out of 125 - not bad for a big car. Falkens are still doing awesome.
https://youtu.be/g4oYuxvOkmE
John Hale
Old 03-19-2021, 02:45 PM   #572
Tmcgee2010
Tmcgee2010's Avatar
Drives: 2014 SS 1LE
not to get to far off topic but i see some of you are in texas, is there a good place for me to find autox events that would be beginner friendly in the houston area?
im technically in crosby but theres nothing around me but drag racing so id be will to travel a bit.
2014 1LE
cold air inductions
kooks
BTR stage 4
UDP
GPI ported Tb & manifold
491whp pump
510whp E85
715 whp RCSB silverado for the straight line stuff
Tmcgee2010 is offline   Reply With Quote
Old 03-19-2021, 02:57 PM   #573
AustinTXracer
Drives: 20 SS 1LE
Look up Houston SCCA. Here's a link to their solo program FB page - https://www.facebook.com/groups/380868205403640
John Hale
Old 03-19-2021, 03:40 PM   #574
Clam
Clam's Avatar
Yes, you can try the Houston SCCA which hosts events monthly at either Gulf Greyhound Park or Grandsport Speedway. They get 15-20 novices per event, so very rookie friendly. Registration is found by searching for “Houston” on the event calendar https://www.motorsportreg.com/calendar/
There is also the BMW/Porsche Events, which occur every month and held at Grandsport Speedway. They only allow up to 5 novices to register since they don’t have that many instructors on hand to help out. I like going to these events because there are only 40-50 entries and we get a minimum of 7 runs and the course designs are a lot faster than the SCCA courses. Registration can be found here https://lsrpca.com/autocross/
