Old 11-26-2016, 03:05 PM   #561
Snowblind
Snowblind's Avatar
With spray or internal mods
That's why I said semantics, he cammed/convertered his car but it is still NA. I was breaking chops a little bit homie, I know you meant no internal mods 125....no offense.
Old 11-26-2016, 04:24 PM   #562
ULTRAZLS1
ULTRAZLS1's Avatar
Originally Posted by wnta1ss View Post
PRAY, it ran 11.81 on 93 gasoline before, in cooler weather than it was in yesterday. The manifold is an MSD Airforce, not ported. It does not seem to help my car (2017 A8) on the dragstrip.
Look into tony mamo. He is the only one porting the msd right now that I've seen. He claims a lot of room for improvement. 7-8 hp. He's pricey but one of the best. Been porting everything for years. I asked how much to port the stocker and he said 525 and the manifold had to be clean in like new condition as well. Thinking I'll have pray port my stocker. He hasn't done an msd yet.
http://www.mamomotorsports.com
Old 11-26-2016, 05:13 PM   #563
laynlo15
Drives: 2022 Lt1 A10
Its all good my man. I'm just gonna swing for the fences with the least of amount of mods I can. I wanted the SC but I have to retire someday and I gotta stop at some point. The mods I'll be doing will not be that costly and still produce pretty nice ets.
Old 11-26-2016, 06:26 PM   #564
PRAY
PRAY's Avatar
Drives: 2016 2SS
I have not ported a LT1 MSD yet. I have done plenty of LS MSD's though. I have a guy willing to send his in for porting but I need a stocker too. I am going to test the two against my ported stock stuff. My last H/C/Ported MSD LS7 made 627/537rw. I have another one coming together in a week or so. Should make more than the last one. I charge half what Tony charges. I bet the manifolds make the same power. You can only get so far into the intake. I can't wait till I am famous and can get $150 an hour.
Old 11-26-2016, 06:31 PM   #565
Speedy1975
FASTER!
Talking of crossing traps in 4th of shifting to 5th, what about a shorter tire?
Old 11-26-2016, 09:19 PM   #566
laynlo15
Taller tires will allow you to hold to the traps, the shorter tire is going to hit the rev limiter probably bout 1200 feet.
Old 11-27-2016, 07:36 AM   #567
laynlo15
I guess I should have said mine looses 2-3/100s when I hold it in 4th and gains 2-3 mph when held in 4th. I repeated that on all three passes I held it. Snow yours picked up so go figure
Old 11-27-2016, 11:55 AM   #568
Speedy1975
FASTER!
Right, but the shorter tire effectively lowers the final gear ratio, and usually shorter gears mean faster ETs. Was curious if anyone had experimented.
Old 11-27-2016, 06:49 PM   #569
big hammer
Drives: 2002 ws6
I'm liking the design of the MSD for higher rpm hp over the fast offerings.
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 12-03-2016, 12:17 AM   #570
HyperblueSS
HyperblueSS's Avatar
Drives: 2016 Camaro SS M6
2016 Camaro SS M6
#1. Post the details of your quarter-mile pass using this template: (cut and paste)
Tires used on the pass: MT ET Street R 305/45/17
Performance Mods (if any): DR's, E85
Category submitted for: Category #3
R/T............ .230
60'............. 1.986
330'........... 5.290
660'........... 7.968
660’ mph... 92.15
1000'......... 10.242
1320'......... 12.177
1320’ mph… 116.90
Name of the track: Orlando Speedworld Dragway
Date of pass: 12/2/16
Weather conditions: Include Density Altitude if known. (Optional not required)
2016 Hyperblue 1SS M6
"If you're not first you're last!"
HyperblueSS is offline   Reply With Quote
Old 12-03-2016, 07:01 AM   #571
laynlo15
Bracket numbers for sure which you don't see out of an M6 so your driving skills show how consistent a manual can be.
Old 12-03-2016, 10:46 AM   #572
Vade46
Drives: 2016 2SS Camaro
Tires used on the pass: Stock tires on MRR Z28 Replica's
Performance Mods: Mishimoto intake, Katech ported TB
Category submitted for: A8 bolt-on
R/T............. .935
60'............. 1.869
330'............ 5.201
660'............ 7.873
660’ mph..... 92.06
1000'.......... 10.172
1320'.......... 12.126
1320’ mph.... 115.77
Name of the track: Atco Dragway
Weather conditions: 50 degrees, -500 DA approx
I couldn't get a clean launch without spinning so this was done using the factory launch control.
2016 2SS Red Hot Camaro Coupe
2015 LTZ 6.2L Victory Red Silverado
2013 LTZ Victory Red Cruze
2007 3LT Z51 Victory Red Corvette
Vade46 is offline   Reply With Quote
Old 12-03-2016, 11:53 AM   #573
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Fasterproms also has a full porting service and will port the MSD.
Old 12-03-2016, 11:56 AM   #574
jdasnt3
jdasnt3's Avatar
660’ mph..... 92.06
That is not that bad of a launch and 1/8th mile. Seems like you may be suffering on the top end? I would have figure your car would be in the 11's.
