07-25-2018, 06:51 AM | #5587 |
Drives: 1ss Join Date: Jul 2016
07-25-2018, 09:58 AM | #5588 | |
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron Join Date: Jun 2018
I have a set I need to install. Doesn't look too difficult. |
07-25-2018, 12:00 PM | #5589 |
I was reminded today I needed to install these.
07-25-2018, 12:56 PM | #5590 |
Drives: 2018 Camaro 2SS Hyper Blue Join Date: Apr 2018
What did you have to do in order to install them?
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK | |
07-25-2018, 02:19 PM | #5591 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
Install is easy you have to reach behind from under the car and unscrew. They are only held in with screws on the back side.
07-25-2018, 05:29 PM | #5592 |
Drives: 18 NFG 1ss M6 Join Date: Mar 2017
Installed this bad ass AA front splitter
07-25-2018, 05:47 PM | #5593 |
these
07-25-2018, 06:01 PM | #5594 |
There’s one screw that holds each of them on. The best way to get access to that screw is to remove the two bolts holding the bumper cover onto the two center brackets. You will see them when you look underneath. After those bolts are off you can bend the bumper cover back to provide better access to the screw. It’s not too hard to get off, but getting it back on is a little tricky since there’s not much room to get your fingers in there. If you have a magnetic screwdriver of the right length it would make it much easier.
07-25-2018, 06:49 PM | #5595 |
Drives: 2016 2SS vert (wife's) Join Date: Jan 2018
Installed the SEMA grille and ZL1 Addons radiator screen. The screen came without installation instructions so had to do some figuring for that one. Got it all back together and realized I had left out the foam and plastic spacer/energy absorber so had to pull the bumper cover again. Then when that was back together found the passenger marker light was out. Going to do some electrical troubleshooting tomorrow.
07-25-2018, 09:54 PM | #5596 |
Drives: Black 2SS Join Date: Jul 2018
2018 camaro 2ss. Eibach springs, bravado tribute wheels, ikon blade spoiler, black ss emblems. LOVE THIS CAR. I've had it for 6 weeks. Now to decide on which splitter to go with.
07-25-2018, 11:06 PM | #5597 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Looking good! What tail lights are those?
07-26-2018, 02:14 PM | #5598 |
07-26-2018, 11:35 PM | #5599 |
Good job.
07-27-2018, 06:26 AM | #5600 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Diode Dynamics clear LED sidemarkers.
