Old 10-15-2025, 09:50 AM   #547
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by ZL1_1LE View Post
Good point lol. This is honestly the first I've read about those tanks melting with headers. Is this a common issue, or just good insurance for a just in case type problem?
We have seen it a few times on High powered cars.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 10-19-2025, 05:17 PM   #548
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Ahh I see what the tank replaces now, but wouldn't the metal tank make the liquid hotter internally vs the plastic?
YES... it would superheat the coolant inside that its supposed to be holding in and prematurely push it into the recovery side of the reservoir. This is a car-show boomer part and in extreme track use would probably create more issues than it solves.
Using a sealed aluminum cap without a pressure relief valve would also cause issues due to thermal expansion, with the weakest link being coolant inside the heater core probably failing first.
Patriot Motorsports USA is offline   Reply With Quote
Old 10-19-2025, 05:53 PM   #549
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
No worries. this replaces the OEM plastic unit. Purely cosmetic upgrade. Here are a few photos from my buddy Alex's car. We just installed his this weekend, along with a matching SC coolant reservoir.
Judging from the installed pics posted further up the thread, it looks like it’s using the OEM pressure relief cap, so there’s no worries there. It’ll operate the same as the OEM tank except it can’t melt or deform under high engine bay temps.
Also, given the mounting location and configuration, there is no way that reservoir is going to “superheat” the coolant. Perhaps if you welded fins onto it and mounted it in contact with the headers lol… but installed like the OEM one, I’ll respectfully disagree. That reservoir is not going to have any impact on coolant temps at all.
Old 10-20-2025, 05:36 AM   #550
ZL1_1LE
Drives: Camaro ZL1
Interesting, you would think with the metal type of materials being above the headers if you're already melting the plastic tank there would be enough heat to heat up the coolant in the metal tank. I may be completely off here though so who knows. I'll wait to see maybe SoCal can post up some real world experience with the new tank vs the old.
ZL1_1LE is offline   Reply With Quote
Old 10-20-2025, 05:37 AM   #551
ZL1_1LE
Drives: Camaro ZL1
Old 10-27-2025, 01:30 AM   #552
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Damn... thats getting pretty spicy! I think the aluminum one is going to be just fine. Also took the time to pull back and secure the harness below, and even tucked the heater hoses completely out of the way!
Old 10-27-2025, 01:31 AM   #553
SOCAL.M6.ZLE
Yes sir, I will let you know soon enough... also, it does retain the OEM coolant cap.
Old 10-27-2025, 01:45 AM   #554
SOCAL.M6.ZLE
Hey team, couple of quick updates on the build...
1. The Ridetech coil overs are on now, hoping to drop the car on wheels tomorrow! Stay tuned.
2. While I was waiting on parts for another part of the car, decided to clean up some of the wiring harness, repaint the valve covers, upgraded most of the hardware to ARP 12pt to match the Ridetech coil-overs, installed the new mishimoto coolant reservoir, and tucked the heater hoses...
3. After hearing their praise from another few tuners, I finally pulled the trigger on the Fi Interchiller Spacer + Blanket package! Great fit and finish so far... Just waiting on a longer belt so I can do some testing...
4. Changed out the extra IAT sensors on my blower... hoping these work better than the RIFE sensors.
5. Not sure what else at the moment.. im exhausted, stay tuned for more!
Old 10-27-2025, 05:58 AM   #555
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Looks amazing! Nothing like living the saying: "If it isn't broke, hell'ya fix it anyway"!!! Love all the updates! It's looking good bro!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 10-27-2025, 10:13 AM   #556
SOCAL.M6.ZLE
HAHA, love that! I always say... "it doesn't have to be broken, in order to fix it" super excited to get this baby back on the road!!
Old 10-27-2025, 10:42 AM   #557
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Or fix it until it's broke, lol me
D@MN!!! I've LOVING the attention to detail!!! This is VERY inspiring!!! That blower wrapping (let alone the fuel lines under it) my how I left mine look like Steven Wonder did it with his feet... I gotta' step up my game BIG TIME.
MANY KUDOS AND RESPECT!!! GORGEOUS!!!
'20 ZL1 Black "Fury"
Old 10-27-2025, 03:26 PM   #558
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Nice work on the wire harness and heater hoses. You know how I personally feel about that nonsense in the stock config. Now that my clutch is here, I can get around to getting the engine back in mine and doing the same kind of stuff. I'm going to have to get some pretty stuff to try to keep up though.
Mods being installed-
Old 10-27-2025, 04:11 PM   #559
Absolute Perfection!!!!!!!!!!!
Love it..
Old 10-27-2025, 09:46 PM   #560
SOCAL.M6.ZLE
thank you sir... for me, it's so hard not to try and improve everything I get my hands hands.... it's an illness im sure
