#43 | |
![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Mine took 6.25 qt, with spillage. The hard shifting has also never happened on the street. The dealer was unable to replicate (of course)
#44 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I had hard shifts with the standard pan anyways. It's been pretty well noted that the A10 shifts hard between 3-4 and 4-3 gears because the ratio is so close to each other. I also believe that it may be a learning behavior characteristic which is not programmable in the controller itself because if you do a reset on the learning parameters the trans will shift soft for some time but then will go back to shifting hard which you cannot tune out.
758 HP/ 804 TQ |
