Old 10-21-2025, 10:21 AM   #43
JSH
JSH's Avatar
Drives: '20 ZLE
What didn't you understand about my post asking members to take your Anti-Hennessey posts to some other or a new thread?
Originally Posted by Patriot Motorsports USA View Post
However, as you had a good experience turn bad, I too am marveled by your good experience with Hennessey as I am from the Houston Area and for decades our shop was one to fix such FauxPas from said shop. As for the numbers they claim, its the many hundreds of Trucks & SUVs getting the floor mats and stickers at dealerships with a snazzy exhaust and a tune to make burble just a little bit more racking up those numbers..
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-22-2025, 10:04 AM   #44
JSH
JSH's Avatar
Drives: '20 ZLE
Got the car out of shop #2 about 2 weeks ago. As far as I can tell, they fixed all the issues that I mentioned in my lead in post. At this point I would give them 4.5/ 5 with the only uh-oh being, I had hoped that when the heads were off the engine they would clean the lower areas of the engine compartment that are larger than inaccessible when it was all back together. They cleaned it but not as well as I had hoped. I realize that's pretty nitpicky.
The tune is not 100% but it's ready for the dyno which I'll try to get done next week. I don't see any reason it should take more than three or four pulls.
It looks like the timing of all of this is such that I will miss the last few weekends of the racing season.
2020 ZL1LE A10.
Old 10-22-2025, 10:26 AM   #45
ZL1_1LE
Drives: Camaro ZL1
Well that's great news that you got it back with some work that seems like you're heading in the right direction!
Sucks about the end of racing season though.
ZL1_1LE is offline   Reply With Quote
Old 10-22-2025, 12:37 PM   #46
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Bro ! Glad it turned out better than is started out to sound ! Exciting to see you get on the dyno !!! It only takes one small good thing to turn the whole day good! Congrats!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 10-29-2025, 05:14 PM   #47
JSH
JSH's Avatar
Drives: '20 ZLE
It made one pull this morning on the starter tune and made 1040/977 with the preset 6/7 shift at 6500 with 20* advance, 20# @ 6500, AFR 12+, Lambda 0.82-84. Boost was still rising at 6500 as was AFR.
But the rest of the story is my tuner uses HPT Beta, so I have to update mine each time he sends me a tune, or, as happened today, I can't open it. To make things still worse, I couldn't update mine at all because the HPT website was down.
Two hours on the dyno but only one pull on a conservative road tune. I'll be back.
2020 ZL1LE A10.
Old 10-29-2025, 05:52 PM   #48
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nice, that’s a solid first pull for sure.
Old 10-30-2025, 12:54 AM   #49
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Damn... how frustrating. I feel your pain on the HPT delay, at least you have a solid first pull number! Can't wait to see the # with some timing in it!
How much boost was it making?
Old 10-30-2025, 05:08 AM   #50
ZL1_1LE
Drives: Camaro ZL1
That's odd, I noticed the same thing as well. My tuner sent me a new tune, and I tried logging into the TDN app and it kept crashing, I did end up deleting it off my phone and reinstalling it and eventually later in the day was able to login. Not sure if it was the deletion that helped or the servers were working again. Great numbers none the less.
Old 10-30-2025, 09:58 AM   #51
Stoner
Drives: 2017 ZL1 HBM, M6
Glad you got your car together and running well! My 2017 ZL1, still sits in the garage, even after I had Cordes Performance in Tempe AZ install the new oil pump. I think I am just over 3K total miles now. I will say Cordes was a great shop to work with. Not only good work, but their scheduling, phone call reminders, and follow up worked great for an old guy like me.
Stoner is offline   Reply With Quote
Old 10-30-2025, 11:01 AM   #52
JSH
JSH's Avatar
Drives: '20 ZLE
20# and increasing at 6500rpm
2020 ZL1LE A10.
