#43 | |
I'm now thinking a colder plug, better heads, .7xx cam, Jet Hot, and a baby shot of Meth (Gain 3) and race gas.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#44 | |
https://www.camaro6.com/forums/showp...9&postcount=31
#45 |
OK, the 6510 is HR 7, so the next step would be an NGK 8 or Brisk 12.
2020 ZL1LE A10.
#46 | |
Moderator
So, Stock SS: HR 5 650 HP stock ZL1/supercharged SS: HR 6 750-800 HP: HR 7 900-950 HP: HR 8 (Brisk RR12S) 1050-1100 HP: HR 9 1200-1250 HP: HR 10 (Brisk RR10S) Since 1250 HP is 1050-1100 WHP, that’s why I went with the RR10S.
#47 |
The type of fuel used plays a factor as well. Best bet is to use the chart as a reference and physically read the plugs after a hard pull.
#48 |
We just put 6510s in it, but now I'll use a one-notch colder plug.
2020 ZL1LE A10.
#49 |
We pulled the heads off today and I've definitely punched out a head gasket. We're going to look at everything else to see if anything else needs freshening up.
I have to admit that I'm disappointed that an engine rated at 1400 bhp would give up head gasket so easily. I didn't think we were asking that much of it, but obviously we must have been.
2020 ZL1LE A10.
#50 |
A head gasket failure doesn't mean the 1400hp rated engine is at fault. For starters, you were running too hot of a plug imo. A 6510 is a projected tip 7 heat range. At your power level you should have a non-projected tip 8 heat range. At bare minimum a Brisk RR12. With Meth and Ethanol fuels, you won't always get knock when cylinder temp and pressure is getting excessive. You could have also been running too much timing. Hard saying without looking at the plugs after a pull to see where the timing mark is on the strap. Last log I had seen of your old combo, the blower was maxed to make the power you want. Maybe consider putting a 427 in it and run 15-16psi instead of 19-20psi. You can't do at 6000ft what everyone else is doing at sea level. You are dealing with a 20% loss in efficiency due to air density.... everything has to work harder to make power.
#51 | |
The ground strap was burned off about halfway back on a number of plugs this time and my guy put the same NGK 6510 back in it. He's convinced projected tip is the way to go and it's the one that he runs in his LT4 also with meth. I'll buy a set of brisk 12s non-projected tips
2020 ZL1LE A10.
#52 | |||
Petro-sexual
![]() ![]() ![]() Quote:
#53 | |
2020 ZL1LE A10.
#54 | |
King has me at 12, and you at 10S. I need unanimity here!
![]() Quote:
2020 ZL1LE A10.
#55 | |
Is the RR10S non-projected tip?
2020 ZL1LE A10.
#56 |
Petro-sexual
King' knows better than me! I was only throwing that out there
