Old 02-23-2025, 11:38 AM   #43
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
The reasonably expected calibration write count for the ECM flash storage is less than 10 for the lifetime of the vehicle. If you get your car tuned, then maybe 50 total, again, throughout the car's entire lifetime. Knowing that and how GM likes to pinch their pennies, I'd be surprised if these chips were able to withstand 1-2 tune writes per day for long.
WOW ! I did not know this. I've flashed as many a (4) when I was having remote tune done. I find that troubling since I know guys that go to "Tune and Test" days at our local drag strip and write modified tunes for the duration of their day at the track. But, maybe they will end up getting an unpleasant surprise ?
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 02-23-2025, 12:54 PM   #44
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Ha I've flashed some cars that are test mules many hundreds of times without an issue. Maybe if you get into the 10s of thousands range, but I don't see anything happening otherwise. It also helps that you are flashing the calibration changes instead of a write entire.
GM Gen V Calibrator
Old 02-23-2025, 02:34 PM   #45
That's good to hear from a professional I'm just a bit paranoid, having seen several areas where GM decided to save a few bucks, this would definitely fit the pattern. The chips themselves that they use must be prehistoric, the programming models they show in their SDKs are easily 10+ years behind the state of the art. (I'm a software developer.)
Old 02-23-2025, 03:57 PM   #46
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I flashed my old ZL1 over a thousand times with no issues while I was learning and experimenting. No ill effects. This one probably has 200 so far
Mods being installed-
Old 02-24-2025, 09:23 AM   #47
2023_ZL1-AUTO
For what it's worth this is from multiple sources, including HPTuners support: "The ECM can be written an unlimited amount of times"
Old 02-24-2025, 10:39 AM   #48
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I have about 200 on mine, but am buying a back-up, lol.
'20 ZL1 Black "Fury"
Old 02-24-2025, 10:54 AM   #49
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
All flash chips for anything have a finite life. But its ridiculously high in anything built in the last 10 years that there is no reason to worry. The car will be in the scrap heap by the time you have an issue.
GM Gen V Calibrator
Old 02-26-2025, 11:11 AM   #50
farrk007
Drives: camaro
Originally Posted by Dabjbr View Post
F*ck man. I'm so sorry! I have no guidance just condolences.
If it was in a secure garage, think they have cameras? Maybe that'll help. I also wonder if there's video of anyone scoping your car out prior to. Doubt there's much you can do with it but I'd ask just in case.
probably an inside job....Bastards! someone had eyes on that car, knew how long it was being left alone for. Sorry this happened OP, Get the best out of insurance and goodluck.
farrk007 is offline   Reply With Quote
Old 03-02-2025, 09:11 PM   #51
KamZL1
KamZL1's Avatar
Drives: Z06
Well, I picked up a 19 Z06 a few days ago, it's getting an IGLA installed in the AM so this one can't be stolen. Thanks for all the advice over the years!
KamZL1 is offline   Reply With Quote
Old 03-02-2025, 10:41 PM   #52
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Attachment 1161683
Nice car, however I don't believe you ever answered my question, did your Camaro have any anti-theft deterrents installed and if so, what? This information could help the Camaro Community immensely as if you had several things installed and they thwarted them, we would now know they aren't potentially effective... Any info you can provide would be extremely valuable to the rest of us with 6th Gen Camaro's that we'd potentially like to keep...
Old 03-04-2025, 08:07 AM   #53
KamZL1
KamZL1's Avatar
Drives: Z06
I had nothing, I only paid for OnStar. fool me once, shame on me....
I have Compustar, IGLA, and a stand-alone GPS now.
Old 03-04-2025, 12:17 PM   #54
2SS Capt
2SS Capt's Avatar
Thank you for the info, again sorry this happened to you.
Old 03-05-2025, 03:18 PM   #55
LuckZL1
Drives: Camaro ZL1
Attachment 1161683
Congrats! You definitely got a nice ride!
LuckZL1 is offline   Reply With Quote
