#43 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Oh yeah, I figured it was pullied a bit now that you have the corn. Super sweet, dude!
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#44 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#45 | |
Moderator
#46 |
#47 |
Petro-sexual
DAMN NICE!!! It's good to see this combination validated. Another Vendor showed similar numbers on a similar combination, so it's nice to see other show what a stock LT4 can do with a bigger blower, fueling, intake, boost, and E' can do.
Good job on your combo'!!! KUDOS!!!
#48 |
At that boost level the blower is pulling pretty hard on the stock crank. It starts to beat up the thrust bearing. I personally would turn the boost down if you want longevity out of it. Heads/Cam, less blower rpm might hold up longer and make more power, But that is killer power none the less!!
#49 | |
Petro-sexual
Thanks!
#50 | |
#51 | |
Petro-sexual
#52 |
I apologize, I tdidn't realize the 80mm produced 20psi on a stock cam heads setup. Most heads/cam cars make around 16-17psi with that pulley setup.
The LT4 weak point is the half thrust bearing. When you spin a crank driven supercharger really hard it stresses that bearing. The 80mm is probably as small as I would go. Tuning plays a factor too.
#53 | |
Petro-sexual
#54 |
![]() Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Are you aware of anyone that has had their block remachined for a full thrust bearing, and what bearing was used?
Finally on the way to 1K.....
#55 |
Petro-sexual
LME and those kinds of big boys do that, if I recall. Probably, any, competent machine shop should be able to.
#56 |
TBH I haven't tuned a SLB LT4 at 20+ psi of boost. Most ain't trying to party that hard and I don't really mess with port injection which is the only way to get a stock heads cam car to have enough fuel for that. But I do think 23-24 degrees should be no problem on E85. The amount of boost or timing isn't really the issue. It's the supercharger pulling on the crank when it's being spun hard. Back in 2017-2018 guys like Andrew @ CSP were saying anything above 800whp out of a stock blower setup was rolling the dice far as thrust bearing failure. Then porting programs extended that number to 900 since you can make more power without increasing blower speed, the 2650 even further, and turbos even more. I just seen the 20psi and that came to mind but I forgot he was stock heads/cam. SLB will show 3psi more boost at the same pulley ratio because it's boost stacking vs a heads cam car. Really just need to know the actual blower RPM. Either way I think the OP tuner is spot on.... It's near it's limit. I believe Mike Sitar made like 900+ SLB in his Z06 but said he didn't plan to leave it there for longevity sake. I can't remember if that was with the 2650 or X port. I know he swapped back and fourth when testing port injection. on his car.
