#43 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
P2635 should be disabled with this setup just like it is with Aux pump setups.
GM Gen V Calibrator
#44 |
Petro-sexual
Understandably, but I believe that will not work for what I need to do...
#45 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
758 HP/ 804 TQ |
#46 |
![]() Drives: 1985 Oldsmobuick Join Date: Oct 2012
Anyone know what happened to this kit? It is no longer on Katechs website.
#47 |
Petro-sexual
I think they are going under re-evaluation... I hope that's all it is. Otherwise - that's not a good sign for us that have spent time and money on the product.
I just installed a replacement for the one I got earlier in the year, so I'll be seeing what's going on soon I guess.
#48 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I'm sure Katech Mike will jump in on this. It's probably a $0.05 cent part from China that is not alliable! They are a quality company and wow do they have a very impressive operation up in Detroit! When they gave me a tour of their operation. It reminded me of the Willy Wonka Chocolate factory, but for higher performance car parts/stuff vs chocolate!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#49 | |
Why did you have to replace your new pump already?
#50 | |
Petro-sexual
I couldn't get near a commanded pressure from the primary pump, even after replacing it with a new one. So far - the new one seems to be following commanded, but I haven't gotten out on the road yet. It would be nice to hear what was found. I'm just curious. What a PITA... The thing I know I don't like is the tangle of fuel lines in this module. That was part of the problem. I know and appreciate why it is the way that it is, but it's a real PITA in connect the lines after that thing is in the tank. There is a new competitor that's out there, but at the price, I'm not sure it's worth it. I think it might be easier to install, but pictures only tell part of the total picture, and I don't know if my presumption is right. It's definitely a lot beefier. I don't know if it would fit all my conditions as close as it seems this Katech will though. My case is more "special" than 99% of the people here though.
#51 | ||
Super Stock
758 HP/ 804 TQ |
#52 |
I emailed Katech and Mike said its a supply issue and to check back the website.
#53 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Our current supplier was recently acquired by a larger company. This created some uncertainty on the supply as we have quite a few on order with no firm ETA.
I took them down for the time being until I have a more clear view of when we will begin to receive them again. |
#54 |
Petro-sexual
Thanks for updating us!
#55 |
Petro-sexual
I haven't gotten out on the street yet (because of some other testing I'm still trying to do), but everything I'm seeing, this module is following the OEM-commanded pretty closely. Again - this is really just at idle, but the Katech/DW pump is running with the OEM tune very closely. I think Josh' determined the DW400 pump doesn't move much more fuel than the OEM ZL1-pump, so this shouldn't be a surprise I suppose.
I'm going to follow-up with the rest of my review on this module in my thread later, after I get some drive time on it, but I am confident, this time, I've done nothing to impair this module, like could be the case the last time.
#56 | |
Super Stock
758 HP/ 804 TQ |
