Old 07-03-2024, 08:59 AM   #43
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Originally Posted by Megahurtz View Post
How do they feel taking corners or going fast when entering/exiting the highway ramps vs the SC3's?
Honestly, they hold the road great while cornering! I actually take off ramps and on ramps with a lot more speed than I did with the stocks on. Also I use very minimal or no breaking for the cornering. It's really crazy cause I feel I'm getting pushed to the outside toward my door in my seat when taking corners as fast as I do now and that's the only reason I actually slow it down a bit. I'll try to do a dragy video of a few on/off ramps! and post a video link!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 07-03-2024, 09:14 AM   #44
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Toyo RR is a fantastic tire. No tread pattern though. Recently pulled a 5.1 60-130 with a little tire spin with a 315/30/20.
CamOnlyJabroni is offline   Reply With Quote
Old 07-03-2024, 09:52 AM   #45
2023_ZL1-AUTO
Drives: 2023 ZL1
Hey is that log already built into Dragy or do you need to add it custom?
Old 07-03-2024, 10:51 AM   #46
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
^^ You go into settings and select the options you want. You can have it do all or none or one.
Select 60-130 and 1/4 mile and it will show a new separate graph for each "option" you complete.
Example. You set 1/4 mile and 60-130. Then you go to the track and make a 1/4 mile pass. You will get one graph that shows the 1/4 mile. And then if you hit 130 mph, you will get a separate graph showing 60-130 since you met that criteria as well.
GM Gen V Calibrator
Old 07-03-2024, 01:39 PM   #47
2023_ZL1-AUTO
Drives: 2023 ZL1
Thank you sir !
Old 08-21-2024, 09:45 AM   #48
KamZL1
KamZL1's Avatar
Drives: Z06
Originally Posted by KamZL1 View Post
good to know, I will be going with the 305s
I have now had:
2 sets of PS4S (315)
1 set R888R (315)
1 set NT555R2 (305)
and in my honest opinion R2 blows both of these out of the water. in many different aspects.
PS4S is an expensive tire that will not offer you any kind of real-world straight-line performance. If you plan on using 2nd 3rd or any kind of hard launching, you will just spin these things. even the 315s when I was stock. Better in rain and great cornering but not worth it IMO.
R888R - I bought into the hype and tried these (10k miles out of them maybe less btw)
These weren't exactly cost effective either but hey a lot of people run these they must be great right? sort of. I did the 315 and was initially happy. I was stock at this time also. To really make these shine, they HAVE to be warm. And I mean HOT. which to me was the biggest drawback and reason not to go with these again. They already do not come with a lot of depth. couple that with having to do a pretty good burnout every single time you want them to really work, these really wear out very quickly and are one of the most expensive tires you can buy for this platform. They are also quite loud, the mud tire analogy is not an exaggeration. Also, once they are close to the end of their life, they fall off of a cliff. I think the 345 is where these tires shine and have gained their reputation on really high hp stuff. But if you are normal working person like me and cannot justify changing these every 5-10k miles along with the other issues mentioned, skip on these.
555RII - Been having these for about a week now at about 750 hp. Very impressed so far. Did the G2s on the front and like those as well. These things WORK. No need for the excessive heat cycling, they just hook and book. Obviously heat makes them better but seriously the stability and traction at lower rpm launches now is night and day. Point and shoot. No observed sway at high speeds either. These things are awesome AND they are the cheapest of the three options by quite a significant amount. Have not tried rain yet so can't speak on that but I can say this thing turns good as well. not a soft sidewall. This is by far the best all-around performance tire and bang for your buck out there right now for our platforms in my opinion, and it's not really close...
KamZL1 is offline   Reply With Quote
Old 08-21-2024, 10:52 AM   #49
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I have now had:
1 set R888R (315)
1 set NT555R2 (305)
Excellent info on the Nittos. Thank you for sharing. That's enough glowing reviews to convince me.
'20 ZL1 Black "Fury"
Old 08-21-2024, 11:21 AM   #50
KamZL1
KamZL1's Avatar
Drives: Z06
@Z OH 6 has been shouting this from the roof tops for a while, I should've listed a long time ago when he advised me before i got the r888
Old 08-21-2024, 11:31 AM   #51
JSH
JSH's Avatar
Drives: '20 ZLE
Just put a set of 345/19 on the rear for the street. Much better traction than R888R.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-21-2024, 11:58 AM   #52
Vettethret
Vettethret's Avatar
Drives: 2023 ZL1 1LE
I have now had:
1 set R888R (315)
1 set NT555R2 (305)
I love the way the R88Rs' feel on the street screwing around in corners, but I get spin in 2nd when I stab the throttle with the R888rs in 345/19, and I just have an intake right now. With the 2650 on the way, it's going to make it much worse.
For those running the R2's on the rear, did you notice deterioration in the handling of the car, having mismatched tires?
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 R888R, KPMF Satin Pearl Wrap, 2650/Heads/Cam/3200 stall/Meth- 918 rhwp/842 rwtq, Girodisc/Carbotech AX6, Race louvers.
Vettethret is offline   Reply With Quote
Old 08-21-2024, 01:22 PM   #53
Z OH 6
Drives: 2024 CT5-V Blackwing
Yea, everyone sleeps on the 555R2 because they love to justify getting the R888R for the cool tread pattern.
Old 08-21-2024, 02:09 PM   #54
clg82
Drives: 2020 Camaro ZL1
Are these specific to straight line stuff, or are they good for the corners too, mines not a daily driver but I do like to take it on some back twisty country roads occasionally.
Old 08-21-2024, 03:01 PM   #55
KamZL1
KamZL1's Avatar
Drives: Z06
Good for both, this is not a micky. I would almost call it a hybrid radial. Stiff sidewall. feels planted in corners AND can-do straight line very well.
Old 08-21-2024, 04:07 PM   #56
Z OH 6
As long as you don't have them on the front, they do very well cornering. The sidewalls are much stiffer than the 555R2 compared to the original 555R or any other drag radial.
This.
