View Poll Results: Have you experienced partial or full oil pump failure in your LT4 powered vehicle?
Yes, chevrolet serviced it and warranted the work 7 11.11%
Yes, chevrolet denied warranty service 3 4.76%
Yes, I had it fixed but not by chevrolet 5 7.94%
No 48 76.19%
Voters: 63. You may not vote on this poll
Old 03-17-2024, 02:13 PM   #43
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by george View Post
@OP, is there a way you can check to see if another dealer in your area has done this kind of work? If GM approves, which I'm confident they will, they may insist this dealer do the repairs at their cost if they ran the engine with a failed pump.
I've had problems with dealers in my area as well. I caught them putting 0w/40 European oil that was not DEXOS in the ZL1. They acted oblivious but charged me the expensive price of the 0w/40 DEXOS2. When insisting that the correct oil be used, it became a huge issue. Long story short, I don't go there with the ZL1. They wouldn't let me in the shop with the usual safety excuse. So I stayed outside and peaked through a garage window to verify the correct oil was used. It's difficult to find a reputable dealer
I'm unsure how to go about it.
I've only lived here for a bit over 2 years. I took it to a different place when the radio screen stopped working. They wanted $1600 to fix it but I ended up buying the HMI myself for 1/3rd thier price.
The dealer in CA that caused this mess wasnt any better but at least they didnt price gouge me every time I walked in there.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 03-17-2024, 05:48 PM   #44
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
So is it the current dealership and technician saying they believe the oil pan is full of metal ? If a new or a used engine is put in go ahead and do a billet pump.
Revalot is offline   Reply With Quote
Old 03-17-2024, 06:47 PM   #45
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I know it’s a stretch, but you might want to go for the lemon law, make it a walk away thing.
Old 03-22-2024, 02:26 AM   #46
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Any update
george is offline   Reply With Quote
Old 03-22-2024, 06:55 AM   #47
nighttowl
nighttowl's Avatar
Any update
Nothing that will make you feel warm and fuzzy about owning a ZLE or a ZL1.
Customer service rep said that thier field engineer reported that the "oil filter was installed incorrectly" and the wrong oil was used. Then brought up that the car was tracked; a car advertised by gm as a track vehicle.
I've changed thousands of filters in my life. I dont see how its even possible to install a filter incorrectly and if it was it would leak all over the ground. I stated that as for the oil the oil listed in the manual was used.
The local dealership admitted to gm that they did not do any actual diagnosis other than it has no oil pressure, then reported to gm that they have no authorization to work on it when I have an email chain between me and the service advisor that says to pull the pan and if the bearings are ok then fix it. Before the car was dropped off I told them about the TSB and that it had no oil pressure. I dont think they even looked into it. I sent them the TSB and never heard from them again.
They seem to be unreachable at this time. I would say that they should bow out, but they already repeatedly ran an engine for an amount of time that they will not disclose to me. At this point it wouldnt surprise me if they drove the car into the bay.
Old 03-22-2024, 10:10 PM   #48
george
ZL1 Driver
george's Avatar
Sounds like excuses to not follow through. Did you talk to an attorney?
Old 03-23-2024, 12:47 PM   #49
Fenmore
Drives: 2017 Camaro ZL1
Sounds like you are not getting anywhere with GM, I would take the money they offered you and get a lawyer to write a letter to the dealership or do it your self if you have the ability. State you will be picking the car up and if any damage is done to the engine beyond the oil pump from them running the engine they will be responsible for it and your attorney fees to collect the damages.
I would NOT keep my car at that dealer for one more second.
You need to do all this via certified mail so you have receipts. You are in Texas you can do this all in small claims court I would assume, which you can try yourself but they have lawyers so it can get hairy with all the legal nonsense in filing claims and responses.
If its just the oil pump its a $3-4k job TOPS with most performance shops from prices I have seen.
It sucks but this dealer isn't doing the right thing.
I would talk to a local performance shop and see what they tell you. See if they can read the logs to see how long it was ran after you got the low oil message. Get the proof and go after them.
Fenmore is offline   Reply With Quote
Old 03-23-2024, 01:04 PM   #50
nighttowl
nighttowl's Avatar
I did contact a few lawyers about it.
I'm supposed to have a conference call on tuesday with GM rep and the Service manager for the dealer where the car is at now.
Old 03-23-2024, 01:18 PM   #51
JTRJSS
THE GREEN GOBLIN
JTRJSS's Avatar
Drives: 2020 ZL1 Rally Green Met.10 Spd AT
I have a 20 zl1 and the oil pump went in 2022 with 15000 miles. GM replaced it under warranty..
This thread below is also about the oil pump failures.
https://www.camaro6.com/forums/showthread.php?t=532479
Rally Green Metallic, Sun Roof, 10 Speed Automatic.
Mild 2 Wild exhaust controller, Brandmotion Curb Alert. More to come.
JTRJSS is offline   Reply With Quote
Old 03-23-2024, 03:52 PM   #52
Tyrolblue67
Drives: 2019 ZL1 Camaro
Angry
WOW....A 2020!
Obviously the problem really hasn't been fixed even though there are many more 2017's and 2018's that have been reported here.
Very disturbing.
Tyrolblue67 is offline   Reply With Quote
Old 03-23-2024, 04:11 PM   #53
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Electric Camaro won't have an oil pump failure!
Seriously, this is a load of BS on their part, I hope it works out for you.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 03-23-2024, 06:32 PM   #54
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Wonder if problem extends to other LT4 powered cars too... cts-v, escalade, isn't there lt4 truck too ?
ing for grip.
http://www.motorsportsne.com/
Old 03-23-2024, 07:00 PM   #55
Originally Posted by Tyrolblue67 View Post
WOW....A 2020!
Very disturbing.
Katech tested all GM fuel pump revisions and stated that 2019+ revisions were stronger, but all of them failed their torture test in the end.
I think what GM probably did was just a few slight alterations to the pump to make the weakest part a bit stronger, but no significant design revision, possibly due to costs associated with testing and/or recertification. Another potential reason I can think of is that since the Camaro team got disbanded and replaced by caretakers in late 2018, there was not enough expertise left to drive a more substantial design change for newer model years.
Old 03-24-2024, 12:01 AM   #56
Kamero6
Drives: 6th Gen LT1
Joke but no so much, since the other posts where we found out GM is selling all of our driving info, every start and drive, if the 3rd parties already have your data, you can get the report and see how long they run the car with the oil pressure issue....
Kamero6 is offline   Reply With Quote
