Old 12-28-2023, 05:12 PM   #43
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Originally Posted by taylorforschool@gmail.com View Post
That’s awfully kind of you!
Do unto others as you would do unto yourself I always say!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 12-28-2023, 06:09 PM   #44
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by 2018ZL1 View Post
Its gonna sit around here taking up space so you pay for shipping and I will give it to your for a whopping fee of $0
That's a deal thanks. I'll pm LME's contact info to you
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-28-2023, 06:17 PM   #45
2018ZL1
2018ZL1's Avatar
I will keep an eye out for it! It doesn't have the cooler on the side of it if that matters...
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 12-28-2023, 07:03 PM   #46
2018ZL1
2018ZL1's Avatar
My bad... it does have the cooler on it! Its complete. PM me your number and I can text you some pics if you would like... It came off of my LT4 that spun a bearing. I cleaned it really good but I am sure LME will clean the crap out of it!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 01-04-2024, 01:27 PM   #47
JSH
JSH's Avatar
Drives: '20 ZLE
Continuing the story...
I learn something new every day. As we pulled my engine we found pieces of a diamond coated washer that was supposed to be between the balancer and the crank timing gear, but it had been installed behind the crank timing gear. The washer is there to bite into the surface of the timing gear and the balancer so that all the load isn't on the keyway. Probably caused the hub failure in my opinion. Hennessey originally installed the bottom assembly in June '20, but it's been removed and reinstalled since then.
I took the windage tray off the pan to remove the big pieces, and found metal in oil and in the pan. The washer was in 3 pieces and when the crank hub broke it put some metal into the oil as well. Also a lifter was stuck and made some grooves in the lifter bore. It had LS7 lifters but LME is installing Johnson lifters. We now have to clean the oil cooler out or replace it.
This entire saga began as I pulled into my garage following some very ... spirited driving, and heard new and strange metal-on-metal noises. I had no idea about any of this at the time.
All of this might only be helpful if you find yourself taking one apart.
2020 ZL1LE A10.
Old 01-04-2024, 01:42 PM   #48
2018ZL1
2018ZL1's Avatar
Was the balancer dual keyed?
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 01-04-2024, 02:50 PM   #49
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, but it was an ATI super balancer with a pulley, not a solid balancer, which is what I'm putting on it this time, which is the ATI CTS-V & ZL1 LT4 balancer, with the hardened HD hub and dual keyed.
2020 ZL1LE A10.
Old 01-05-2024, 10:59 AM   #50
JSH
JSH's Avatar
Drives: '20 ZLE
I thought some might like to see LME's short block and heads specs. I think they're sending their startup dyno sheet next week.
2020 ZL1LE A10.
Old 01-05-2024, 11:03 AM   #51
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I thought some might like to see LME's short block specs. I've asked him for one for the heads too.
Great stuff! Out of curiosity, what oil viscosity are they specifying that you run?
Old 01-05-2024, 11:19 AM   #52
JSH
JSH's Avatar
Drives: '20 ZLE
It will be broken in on the dyno using either Driven 10W40 Breakin oil or the Valvoline VR1 10W40. When I receive the engine they recommend I put another 500 miles on the engine with a quality non-synthetic oil, then after I put the additional 500 miles on the engine, switch to synthetic oil.
2020 ZL1LE A10.
Old 01-05-2024, 11:50 AM   #53
2018ZL1
2018ZL1's Avatar
The tolerances on my new motor has me using 20W-50 Valvoline VR1
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
Old 01-05-2024, 12:12 PM   #54
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Is the camshaft that is shown spec specifically for your application by LME or is it from a shop?
Nimair.ZL1 is offline   Reply With Quote
Old 01-05-2024, 02:43 PM   #55
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, specd and supplied by LME. It turns out they did the motor that I bought from Hennessy. This new engine has a lot more cam in it than that one did
2020 ZL1LE A10.
Old 01-06-2024, 10:37 AM   #56
Nimair.ZL1
Do you have the part number for the oil cooler by any chance? My motor blew and i need to get a new one but I have no idea which to get
