Old 10-30-2023, 12:00 PM   #43
23Redrocket
Drives: Chevy Blazer, Corvette, Camaro
The part number is 84224813. The spoiler is marketed by Chevy accessories as an upgrade for the SS to a ZL1 spoiler, which is larger and wider. It's a real ZL1 spoiler. And the SS and ZL1 spoiler have the same mounting points.
I will say that breaking the adhesive loose holding the spoiler on is the hardest part of removing the spoiler. The nuts are fairly easy to remove from the inside of the trunk. I had to use a heat gun to soften up the adhesive. If you use a heat gun be careful not to get the paint too hot. The new spoiler comes with new nuts and the adhesive already installed.
Let me know if you have any other questions. Changing the color certainly improves the look and Mosaic black matches the other trim pieces.
Thanks for the info!
23Redrocket is offline   Reply With Quote
Old 10-30-2023, 04:35 PM   #44
ZPirate
ZPirate's Avatar
You are welcome.
I took today off so I decided to do a little painting. Went by my local commercial auto parts store this morning and had them mix me up a aerosol spray can of Mosaic black metallic. I had previously purchased some gloss black door handle covers for my 1LE that I ended up not using. When purchased my ZL1 I ordered a set of gloss black mirror covers. However, I didn't like them in gloss black.
So I decided to sand both and paint them Mosaic black metallic. Over the years I have dabbled in painting small parts for my cars. I already had a new can of clearcoat and some 800 and 1200 grit sandpaper, so while I was at the auto parts store I picked up a 2000 grit wet/dry sponge.
I sanded all the pieces then put 4 coats of paint on the parts. Then I sanded them again with the dry sponge. After that I applied 4 coats of clearcoat and lightly sanded them again before polishing the parts. I think they turned out pretty good. I know that I going to use the mirror covers. But I’m still undecided about the door handle covers.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 10-30-2023, 04:42 PM   #45
Nice Job...
Old 10-30-2023, 05:14 PM   #46
ZPirate
ZPirate's Avatar
Nice Job...
Thanks mlee! I'm pleased with how they turned out.
Old 10-31-2023, 09:51 AM   #47
Odabo
Odabo's Avatar
Drives: 2023 2SS 1LE
I like it. Looks way better than the gloss black IMO.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
Odabo is offline   Reply With Quote
Old 11-02-2023, 07:39 AM   #48
Ryanbabz71
Ryanbabz71's Avatar
Thanks for the comparison about what I figured. I found a low miles 2018 ZL1 in hyper blue. Tempting
Sent from my iPhone using Tapatalk Pro
Ryan
Old 11-02-2023, 07:54 AM   #49
ZPirate
ZPirate's Avatar
You are welcome. My thought process on the ZL1 was that if I wanted one now was the time to buy one with production ending in December. Once GM stops producing them they are going to become harder to find and possibly even more expensive. And I expect those that have a ZL1 will be more likely to keep them.
Old 11-05-2023, 04:08 PM   #50
ZPirate
ZPirate's Avatar
This weekend I installed the Mosaic black side mirror caps and door handle covers that I painted last week. Today I also installed gloss red hash marks with gloss black edges that I picked up from Screaming Chicken. I have matte black hash marks on my 1LE and really like them. So l thought gloss red and black would look good on my Summit White ZL1.
Old 11-05-2023, 05:16 PM   #51
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
Not really a fan of the hash marks, mainly because of the color. It would have made more sense if the car had red calipers or something else red to go with it. That's just me though... I like the door handles/mirrors though, looks fantastic!
That said, you gotta make your car your own, and nothing wrong with it!!!
Old 11-05-2023, 05:46 PM   #52
ZPirate
ZPirate's Avatar
Thanks. I like the Mosaic Black pieces too. I went with the gloss red hash marks mainly because red goes so well with Summit White. I also considered gloss black with red pinstripes on the hashmarks. I think that would have been a good combination as well. I was just wondering if that would be too much black with all my other Mosaic black parts.
Since the hash marks are vinyl I can easily remove them and change colors if I want to later on. The red does help accent the red 1 in the ZL1 emblem and when I get around to putting my SS 1LE wheels on the car next weekend, the red 1 on the brake calipers will be much more noticeable too.
Old 11-12-2023, 06:47 AM   #53
ZPirate
ZPirate's Avatar
Finally got around to switching out my wheels for the takeoff set of 1LE wheels I bought a couple of months ago. In my opinion the 1LE wheels are the best looking oem Camaro wheels. More pictures to come of the entire car with the 1LE wheels.
Old 11-12-2023, 09:19 AM   #54
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Attachment 1140514
Attachment 1140515
Are the wheels set in further than the stock ZL1 wheel offset? From the pictures you look to have more wheel well clearance or maybe it’s just the angle of the photos.
Old 11-12-2023, 10:28 AM   #55
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
From what I’ve read the SS 1LE and ZL1 wheels are the exact same size and offset
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-12-2023, 02:34 PM   #56
paradigm
Drives: 2022 Camaro 1SS 1LE
Attachment 1140514
Attachment 1140515
Looking fwd to seeing the ZL1 with the SS 1LE wheels.
I think the SS 1LE trunklid spoiler is the best looking for these cars - would be neat to see it on a ZL1.
paradigm is offline   Reply With Quote
