Old 10-18-2023, 05:36 PM   #43
gatewayracer
Drives: Chevrolet Camaro
Originally Posted by Nimair.ZL1 View Post
Piston and sleeve is pretty much done as far as I know. I think the valvetrain is still intact. I highly doubt it was the intercooler bricks but it could be a possibility that they leaked. I did see a shit ton of white smoke come out of my tail pipe. All the coolant drained pretty much instantly as far as I know. Before it blew it was full
When the cam was installed, was piston to valve clearance checked?
gatewayracer is offline   Reply With Quote
Old 10-18-2023, 07:01 PM   #44
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Don't think so but not completely sure
Nimair.ZL1 is offline   Reply With Quote
Old 10-19-2023, 10:07 AM   #45
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Not the first time intercooler bricks have leaked and caused a failure. I have seen it reported on at least 2 other ZL1's. Don't think it's related to a defective part. I think it's more related to installation error from when the supercharger was removed. Pinched O ring or something of the sorts. I didn't see the full break down of the other failures...
Old 10-19-2023, 10:14 AM   #46
Nimair.ZL1
Pressure tested the bricks and no leaks. It was the exhaust valve head that broke off
Old 10-19-2023, 10:31 AM   #47
KingLT1
KingLT1's Avatar
I guess I missed the post, but where did all the coolant come from in the supercharger? I do agree with others that already posted that it's pretty uncommon for IC bricks to leak, but was just stating that I have seen it reported a couple of times over the years. Broken exhaust valve is odd at your power level. Something must have been off on the valve train setup as previously mentioned.
Old 10-19-2023, 12:23 PM   #48
Nimair.ZL1
That is still a mystery to me. If I had to guess I think a O-ring must've been a little worn. A broken spring would explain the valve contacting the piston and breaking off but tbh not sure what went on
Old 10-20-2023, 04:18 AM   #49
gatewayracer
The two most important things when installing a new cam are to degree the cam and check piston to valve clearance.
Too far advanced and Intake makes contact, too far retarded and exhaust valve makes contact.
After the valve dropped it would only take a split second to crack the head or block and cause the coolant leak.
Did you install the cam yourself?
Old 10-20-2023, 08:12 AM   #50
Nimair.ZL1
No sir I did not. It was installed by a reputable shop whom I will not take to name of
Old 10-20-2023, 08:19 AM   #51
Z OH 6
Drives: 2024 CT5-V Blackwing
Fair enough as long as their owning up to it and paying for the damage, as any reputable shop should do.
Old 10-20-2023, 08:22 AM   #52
KingLT1
KingLT1's Avatar
I would agree on an engine more extensively modified. But installing a stage 1 or 2 cam kit in a stock head/compression LT4 usually doesn't necessitate those measures. There is normally plenty of PTV just needs to be lined up dot to dot on the gears. Now if the heads were milled and/or thinner gaskets were used, then yeah PTV should definitely be verified.
Old 10-20-2023, 10:50 AM   #53
JSH
JSH's Avatar
Drives: '20 ZLE
I broke something major yesterday but haven't taken it apart to see what. Most likely the SC
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-20-2023, 11:10 AM   #54
Nimair.ZL1
I do pray that you don't have a major problem like I do. If you do long block is the only thing you can do. If you want you can message me on Facebook to talk about it. My name is Nimair Ghulamani
Old 10-20-2023, 11:45 AM   #55
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
That sucks! Hopefully it is the blower and nothing else! Fingers crossed for you!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
