#43 | |
Hot Camaro
#44 | |
![]() Drives: 2000 WS6 Join Date: Dec 2014
After watching the video again... If I have no priority on mpg/epa ratings, never drive below maybe 30 degrees F, don't want to harm my cats, not going to track my car but do generate some decent lateral G's from time to time... i could run the cheaper 15W-50 all the time, even without the vaunted DEXOS tax stamp on it. Or will repeated "cold" starts in AZ with 15W wear my bearings like cheese in a grater? It seems like if you don't care about mpg, then 50 weight is advantageous for all situations at full operating temp? Or am I over simplifiying? Basically, the guidance about putting 0W-40 back in after track day is just something they to have to say for mpg/epa conformance and in practice probably its not something (most) consumers actually are about? |
#45 | |
![]() Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
There are a couple reasons I wouldn't use 15w-50, or 5w-50 year round: 1) higher SAPS (sulphated ash). This generally known to be bad for DI and intake valves build up. https://www.mobil.com/en/lubricants/...mobil-1-15w-50 2) the CAT converter considerations are not baloney, although it would probably take well past the warranty to affect anything. In the document below, you can see the Phosphorus and zinc PPM, respectively. As you can see, even the c8 z06 oil doesn't use that much zinc and phos. Mobil 1™ ESP X3 0W-40 900 990 Mobil™ 1 Supercar 0W-40 900 990 Mobil™ 1 Supercar 5W-50 1100 1200 Mobil 1™ 15W-50 1200 1320 Mobil 1™ FS X2 5W-50 930 1000 https://www.mobil.com/lubricants/-/m...-v2-9-1-22.pdf 3) What matters is HTHS. HTHS with ESPx3 is already 3.8 vs 4.5 for 15w50. "Regular" GM dexos1gen3 is ~3.0. IMO GM is wanted a more stout oil around the weight of a 5w30. The have been spec'ing 5w30 for the small block forever. With fuel economy regulations the way they are affecting oil, they could only get around this with going to a Xw40 weight. However, they didn't want a "euro" high SAPS oil; because it is bad for DI and intake valves. If you notice, Xw40 oils mostly are not certified API SP or SN+. This is because of fuel economy considerations. Also, the germans are going away from high SAPS oil too now....in my lady's boxster GTS4.0 with the flat six, it takes the same ESPx3 oil (although this is probably mostly because of the gas particulate filters in Europe). 4) M1 15w-50 is an old formula, there are newer methods for reducing wear than just high zinc and phos. These are not flat tappet engines. Finally, If you are modified and catless only then would I consider it but #1 above still applies. Edit: I missed the part about the ZL1 1LE. I recall this being due to the wet sump oil system and lateral G's. If I exclusively tracked that car I'd probably try to use the Supercar M1 5w-50 stuff. It looks like a newer formulation with less phos zinc and more organic anti-wear components.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 Last edited by haggler; 08-02-2023 at 01:48 PM. |
#46 |
Yes, what youre saying is true with one caveat...oil regulations have been going towards fuel economy. So the 5w30 mobil 1 synthetic of 20 years ago isn't the same as today for good and bad. There is a benefit to using Xw40 oil if you're car sees the track.
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
#47 | |
![]() ![]() I read alot on that site during covid...then got sick of the crowd so now I am here
#48 |
Electrical Engineer
Haggler and I discussed these differences a while back, https://www.camaro6.com/forums/showt...t=bitog&page=3
I was convinced that the ESP X3 0W-40 is suitable; as noted above, it adds Porsche C40 certification (and others) to the GM DEXOS 2 certification. Given that this oil seems to provide the best combination of high spec compliance and lower cost (I also just paid $6 a quart), I don't understand why it was dismissed in the video.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 45k mi. @ Mar 2025 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#49 | |
Hot Camaro
The specs of the engine didn't change one bit but the requirements for the oil did? That's specifically where I'm calling BS on this. Let me put it a different way... Let's say you own a 2016 Camaro SS with the LT1 motor. What does your oil fill cap say? It say "SAE 5W-30 DEXOS" on it. That was the factory fill for the motor at the time. Now, let's say that your oil fill cap got damaged or lost and you need to buy a new one. Do you know what the new one will have printed on it? Even though you specifically ordered the part for your 2016? It will say "SAE 0W-40 DEXOS" on it because that is the CURRENT factory fill that GM uses for that motor. Somehow your oil requirements have magically been changed by GM? No. And neither did any of those requirements get fundamentally changed on any model year after 2016 even though GM has been shifting things around in the background (and in the manuals) the entire time. |
#50 | |
#51 | |
Electrical Engineer
The AFM lifters are actuated through oil passages, as I detail here: https://www.camaro6.com/forums/showthread.php?t=617893 This correlation is my suspicion. It's also possible the new spec is associated with concerns with the PCV system and challenges with direct injection motors when compared to port injection for intake lifter build-up.
#52 | |
Driver for Hire
I had direct conversations with members of the small block team when I did the research. It wasn't personal opinion based, it was professionally guided information directly from the team who designed and engineered the LT engines. Because of that, when they said "you can use it in a pinch, but I would stick to the Supercar 0W-40" that is the info I provided in the video.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat 2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
#53 | |
Driver for Hire
Luan Zeqollari
#54 | |
Driver for Hire
Luan Zeqollari
#55 | |
Hot Camaro
In other words - they previously claimed that 5W-30 dexos1 was fine for use on the street. If someone runs that in their 2023 and there's a failure, the onus will be on GM to prove that the oil was the root cause of the issue. |
#56 | |
Electrical Engineer
I used Supercar for the first two changes and ESP X3 for the last two. This is my daily driver and it sees a lot of highway miles. AFM is still active. The difference between Supercar and ESP X3 is not so much an issue of cost as availability and my schedule. I do the oil change myself and while I should just order the next fluid set now so it's ready, I'll likely wait until a day or two before and then find it. ESP X3 is readily available most places, Supercar is not. I will stick with 0W-40 and do not see myself ever using 5W-30 given the updated recommendation by engineering. I think the real question is the difference between DEXOS R and DEXOS 2 - and if both are acceptable, then either oil is acceptable. This is where I would love to see some long-term testing results, including engine torture results and intake build-up results when using either spec.
