Old 05-23-2023, 05:40 AM   #43
walkerheaders
walkerheaders's Avatar
Drives: 2023 1SS Radiant A10 63 427 Impala
Originally Posted by Gen6cyl View Post
You just use on crankcase.dirty side? On the v6 did you use the factory intake tube connector for vaccum or tap into the intake manifold? My v6 intake tube stays oily. I use crc di cleaner evey 15 -20k miles.
There is a line from the right rocker cover to the intake. I clipped that line and connected to each end. worked great. the LT1 is much simpler.
walkerheaders is offline   Reply With Quote
Old 05-23-2023, 07:30 PM   #44
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I didnt have one - I do now.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 05-23-2023, 08:35 PM   #45
ZPirate
ZPirate's Avatar
Originally Posted by NYTMARE23 View Post
Fair points and thank you for the perspective. . On another note, are catch cans hard to install? Don't really feel like screwing something up with the install should I happen to get one.
No, catch cans aren't very hard to install if you have basic mechanical skills. Most install with a few hand tools. And most catch cans come with directions or have an install video on the manufacturer's website. I went with a Mishimoto catch can. I've installed Mishimoto brand catch cans on several vehicles I've owned.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 05-23-2023, 08:41 PM   #46
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
Ok, thank you for the info. I'd LIKE to THINK I could install one since I work on big military planes for a living(as a civilian).
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 05-23-2023, 10:10 PM   #47
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
How do you know that GM didn’t design the engine to burn a minuscule amount of oil for lubrication? Everyone assumes that because the catch can caught oil it’s saving their engine yet its normal for an engine to burn a small bit of oil. Its known that many engines consume oil as part of normal operation including porsche engines. The makers of the engine oil know this and that’s probably why chevy recommends dexos oil is it has additives to keep the valves etc clean and lubricated.
Briland_1LE is offline   Reply With Quote
Old 05-25-2023, 11:46 AM   #48
Capricio
Drives: 2000 WS6
Sounds like Microsoft renaming bugs they can't resolve "features". Any unmetered air/fuel/other going into a combustion chamber is not desirable. Modern 4-stroke synthetic oil is not made to cleanly combust and will result in soot/ash/carbon on your valves. Venting the PCV to the atmosphere would be best for your engine, but not the environment, so a closed loop catch-can is a good compromise.
Capricio is offline   Reply With Quote
Old 05-25-2023, 04:39 PM   #49
ZPirate
ZPirate's Avatar
You shouldn't have a problem installing a catch can then.
Old 05-25-2023, 05:11 PM   #50
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Thank you!
Old 05-25-2023, 07:14 PM   #51
FarmerFran
FarmerFran's Avatar
Here is a Mustang Catch Can
<Insert Cars You Own Here>
Old 05-25-2023, 09:39 PM   #52
Easiest install ever, that's for sure. Much less drastic consequences if you forget to empty it, too.
Old 05-26-2023, 12:17 AM   #53
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
That's about as fast as a Mustang as well... At least that one can probably stay on the street!
Old 05-26-2023, 07:19 AM   #54
Briland_1LE
your right, PCV was vented to the intake for emissions.
Old 05-26-2023, 07:30 AM   #55
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Does the suction of venting to the intake relieve internal pressure better than venting to atmosphere? The lgx takes crankcase pressure to the intake tube rather than the intake manifold which has more suction.
Gen6cyl is offline   Reply With Quote
Old 05-28-2023, 12:57 PM   #56
Capricio
Drives: 2000 WS6
Negative pressure (relative to atmospheric) in the intake manifold will reduce the pressure in crankcase required to open the pcv valve, since the valve opens according to a static difference in pressure. Likewise, positive pressure in the manifold will raise the relief pressure threshold of the pcv. But, I imagine that when crankcase pressure surges, it does so by a lot, so the margins you're asking about are probably negligible.
